Pacesetter Install Problems - Page 2 - Pontiac G8 Forum: G8 Forums - G8Board.com
Exhaust Tech Headers, Catbacks, Mufflers, lack of mufflers
post #21 of 41 (permalink) Old 12-31-2012, 03:55 PM Thread Starter
OK Guys I got everything done. Here is what I found.
Dipstick: Once lined up correctly in the pan, go underneath with a 3 foot pry bar. Rest the end of the bar on the collar of the dipstick tube (the collar is what triggers you to know its not in far enough) find a good fulcrum point and pry. "Click" says the dipstick. Done
Passenger side clearance: Loosen everything underneath. The only bolts that should be tight are on the ones holding the headers to the heads. Align and realign and realign. It seems that my Driver side header was pushing the mid-pipe to far back causing the flange to hit the floorboard. Once everything was loose, The mid-pipe slid forward just enough to clear everything.
Thanks for the pics they really helped. I was able to look at your pics and say; "How the Heck are his so far forward. My flange is now where the floorboard ends and the tranny tunnel fire wall begin.
2009 White Hot G8 GT
HPT Tuned-Bluegoat has been telling me what buttons to push
Vararam with Vector HSRK
Pacesetter Long Tubes
Partial Debadge
Window tint 20% back 35% on the sides
Camaro 20's.
Next mod-1.85 Rockers and LSA Blower
87 Buick T-Type-My fast car Gone
87 Buick Grand National
2005 Avalanche
2003 Impala- Winter Warrior
mtocrs1 is offline
post #22 of 41 (permalink) Old 12-31-2012, 04:08 PM Thread Starter
One last question, Do these headers have a natural "Tick" sound to them? I for the life of me cant find a leak but it seems there is a tick noise that can be heard from under the car. I cannot feel anything leaking at the joints. No steam coming from anywhere but the tailpipes. The tick cannot be heard inside the car. With a stethescope it sounds like every joint under there is leaking. Seeams to go away at around 1,000 RPM.
Partial Debadge
Camaro 20's.
2005 Avalanche
mtocrs1 is offline
post #23 of 41 (permalink) Old 12-31-2012, 04:22 PM
MotorCityG8's Avatar
The headers will make your engine bay more noisy if that's what you mean. If that's what your referring to then that's normal.
13' Ford Focus ST2
2008 G8 GT PBM / No Roof - SOLD
Go: Livernois Stage 1 Cam / Circle D 3000 Stall / Ported TB & Intake / Roto-Fab CAI / Pat G Tune / SLP Powerflow Axlebacks / OBX 1 7/8 LT w/3in midpipe / LS7 MAF
Show: Avant Garde M310 / Eibach & Fe3 set up / Plasti Dipped Wheel and Kidney grills / Debadged / Tint (20% windshield, 5% sides, 20% on top of 5% on the rear) / Bathurst Stripes.
MotorCityG8 is offline
post #24 of 41 (permalink) Old 12-31-2012, 04:30 PM Thread Starter
Not so much the engine bay. If you are standing next the car it sounds a little "tickey" but not like full force exhaust tick sound. If that makes any sense.
Partial Debadge
Camaro 20's.
2005 Avalanche
mtocrs1 is offline
post #25 of 41 (permalink) Old 12-31-2012, 04:49 PM
Gotcha I think mine sounds like that too. I'll check it out next time I go out to the car
13' Ford Focus ST2
post #26 of 41 (permalink) Old 12-31-2012, 06:25 PM
Bo White's Avatar
The beloved header ping. Love it!
Bo White is offline
post #27 of 41 (permalink) Old 01-09-2013, 06:10 PM
holdenG8GT's Avatar
If it is close to the floorboard it only rattled in reverse but after almost 10 months it don't do it anymore
holdenG8GT is offline
post #28 of 41 (permalink) Old 01-13-2013, 12:40 PM
I have that same tick I think its the connection pipes that go at the end of the header. I want to get that welded
red281gt is offline
post #29 of 41 (permalink) Old 01-13-2013, 01:43 PM Thread Starter
Honestly I don't think it is a leak. I went so far as to dissasemble and apply rtv to everything. Reinstalled and it sounds the same. I think it is just the nature of the headers at this point. Let me know if getting them welded changes anything. I have a welded sitting in the corner.........
Partial Debadge
Camaro 20's.
2005 Avalanche
mtocrs1 is offline
post #30 of 41 (permalink) Old 01-13-2013, 01:53 PM
Super Moderator
Troy Trackbeast's Avatar
Mine are welded and I have the same sounds as described above. Nature of the beast...
Troy Trackbeast is offline
post #31 of 41 (permalink) Old 01-13-2013, 02:26 PM
Bo White's Avatar
Its called header ping. I love it.
Bo White is offline
post #32 of 41 (permalink) Old 01-13-2013, 02:31 PM
Super Moderator
Me too! Sounds even better with cam lope
post #33 of 41 (permalink) Old 01-13-2013, 03:02 PM
ok i have the pace setter long tube headers/no cats on my 09 G8 GT and what i did was take the motor mount bolt loose on the driver side and disconnect the strg shaft from the rack to clear to install mine i jacked the engine up on the drive side with a floor jack and a block of wood
09G8GT6.0 is offline
post #34 of 41 (permalink) Old 01-13-2013, 06:06 PM
Bo White's Avatar
Yes, a lopey cam makes it even better- adds to the kachunkachunk!
Bo White is offline
post #35 of 41 (permalink) Old 01-16-2013, 05:14 PM
I just finished installing mine last night. I didn't need to touch the motor mount or the steering shaft. I almost didn't even need to take out the dipstick tube; it came out accidentally when I was installing the header.
Sent from my Galaxy Nexus using AutoGuide.Com Free App
2009.1 SBM G8 GT
LSA SC 2.85, ZL1 lid, LS9 cam, OBX, Dual Squash 450s, FIC1000s, Flex fuel, HPT
10.8 @ 130
1/4 mile: https://youtu.be/uVBMAh_ULTc
1/2 mile: http://youtu.be/EudOyV9dSnU
brentsten is offline
post #36 of 41 (permalink) Old 01-16-2013, 05:26 PM
BLKG8's Avatar
Is your #1 primary on the drivers side like 1 mm from the motor mount shaft? On mine I can fit no more than 3 pieces of paper between that spot. That's how I checked to make sure there was clearance haha
BLKG8 is offline
post #37 of 41 (permalink) Old 01-21-2013, 07:30 AM
No, thats odd. I'll have to recheck, but as far as clearance goes it fit surprisingly well compared to all of the install stories of read with Pacesetters/G8s. The only problems I had was lining up the rest of the exhaust again since it was already pushed back a little from my X-Pipe install. I also had to sleeve 4 plug wires because they were touching the primaries.
2009.1 SBM G8 GT
10.8 @ 130
post #38 of 41 (permalink) Old 01-25-2013, 11:30 AM
notice any leaks with those connection pipes?
First 888 # 216
55w 4500 HID, SOLO axlebacks, Pacesttter LT's, debadged, plasti dip, 35/20/20 tint, roto-fab, FAP tune
888Adam216 is offline
post #39 of 41 (permalink) Old 01-25-2013, 11:48 AM
I did i had to get them welded, they are good now, sound better also
red281gt is offline
post #40 of 41 (permalink) Old 01-25-2013, 12:10 PM
So, the connection pipe gets welded to the header? I have heard of the mid pipe having to be shortened because it would push the cat back back to far...any issues there?
First 888 # 216
