Widest tires? - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 45 (permalink) Old 07-02-2008, 10:35 AM Thread Starter
Widest tires?
Anyone in the 295+ widths?
04 C5Z - only things stock are some of the body panels.
04 Avy 2500 - Daily driver gas annihilator.
09 G8 GXP*** constantly lurking for one when the prices get nicer then off for road race mods.
OKsweetrides is offline
post #2 of 45 (permalink) Old 07-02-2008, 11:20 AM
Dog Diggity
Mr. Sandog's Avatar
To do that you would have to get a 10" rear rim with a +50 (or so) offset. I have yet to find or see a rim with those specs. You would likely have to do custom.
Mr. Sandog is offline
post #3 of 45 (permalink) Old 07-02-2008, 01:17 PM
I am a monkey
topperge's Avatar
The guys down at CCW are experimenting right now, they're the ones who got my offsets on the GTO perfect so I can run my 335s. I'll see if I get a chance to call John and find out what size they are up to.
topperge is offline
post #4 of 45 (permalink) Old 07-02-2008, 03:02 PM Thread Starter
^^^ I had no idea 335's could fit on a goat.
oddly enough, I was actually contemplating some CCW classics or 550's in 18" wheel size assuming that they should work with the forthcoming GXP version.
I assume it'll be a bit on the funky side when it comes to wheel specs, but I think that wide of a tire would look very good on a G8.
post #5 of 45 (permalink) Old 07-07-2008, 02:24 PM
GroupAWheels's Avatar
We have exactly that part number in stock.
GroupAWheels is offline
post #6 of 45 (permalink) Old 07-07-2008, 11:14 PM
I am a monkey
topperge's Avatar
Well, my GTO is far from stock. I run flares front and rear that allow me to run the wider tires. 275 is about the largest you can go on a stocker. I've got 12 months left on the Silverado lease and then I get to start playing with the G8.
topperge is offline
post #7 of 45 (permalink) Old 07-08-2008, 01:37 PM
TriShield's Avatar
Would 275s in the back rub or bottom out with two people in the rear seat any stuff in the trunk?
TriShield is offline
post #8 of 45 (permalink) Old 07-08-2008, 02:04 PM
TireDoc's Avatar
We've done the following with no issues (assuming offset is correct);
285/40-18
285/35-19
295/35-19
285/30-20
the 275/35R19 will not fit the OE wheels, neither will a 255/40R19
TireDoc is offline
post #9 of 45 (permalink) Old 07-08-2008, 02:05 PM
TriShield's Avatar
What is the widest size that will fit on the front without rubbing lock to lock?
post #10 of 45 (permalink) Old 07-08-2008, 03:37 PM
TireDoc's Avatar
On the OE wheel, just the 245/40R18. On an 8.5" wide (or wider) wheel 255/40R19 is biggest based on our conservative measurements.
TireDoc is offline
post #11 of 45 (permalink) Old 07-08-2008, 04:27 PM
Wife said no Vette
Why do you say the 255/40/19 does not fit the OE 19's, is it rubbing or are you saying it wont fit the wheel?
tntempest is offline
post #12 of 45 (permalink) Old 07-08-2008, 04:43 PM
Dog Diggity
Mr. Sandog's Avatar
A 255 fits the car (no rubbing) but is too wide for the stock wheel.
At least that is how I am reading it.
post #13 of 45 (permalink) Old 07-09-2008, 09:20 AM
TireDoc's Avatar
Yep, 255 needs an 8.5" wide (or wider) wheel, OE is 19x8.
TireDoc is offline
post #14 of 45 (permalink) Old 07-11-2008, 01:03 PM
Wife said no Vette
Uh, Ive run 265's on a 8" wheel, The 245's don't even poke out enough to protect the wheel, a 255 or 265 should fit no problem.
Some tire companies 255's are equal to some companies 245's. Nitto's run terribly small in width. I would think a 265 would fit, maybe hard for the tire guy but well worth it. Most tire companies give a suggested wheel size and some list 8" for 255.
Edit,
Just looked up several tire mfg's and they list a 255/35 or 255/40 to be acceptable on a a 7.5" rim
2008 Panther Black G8 GT with Sport, Premium, RotoFab CAI, VMS HSRK and Cortex Tuner 93 octane
1969 Tempest Custom-S, Full Tubular suspension, 4 wheel disc brakes
post #15 of 45 (permalink) Old 07-11-2008, 04:58 PM
TireDoc's Avatar
Edit,
Didn't look at all 16 of my suppliers, but Bridgestone, Continental, Dunlop, Goodyear, Hankook, Michelin, Pirelli, Sumitomo and Yokohama require a 8.5" width minimum for 255/35R19 or 255/40R19. The tire would mount up to an 8" wide wheel without too much problem, but the tire manufacturers couldn't say how long they'd stay on.
TireDoc is offline
post #16 of 45 (permalink) Old 07-11-2008, 06:20 PM
Wife said no Vette
Here is a Pirelli P-zero 255/45/19 recommended on a 8"
http://www.wheelenhancement.com/tirespecs.php?tireid=21
Tire rack shows 275/35s rear optional.
I cant find the other site that showed 7.5" for all the mfg.s
post #17 of 45 (permalink) Old 07-11-2008, 06:30 PM
TireDoc's Avatar
Sure, a 255/45R19 will fit an 8". You are correct. Its just taller than we can guarantee to fit.
TireDoc is offline
post #18 of 45 (permalink) Old 07-11-2008, 06:34 PM
285/40-18
285/35-19
295/35-19
285/30-20
What was the offset on the 295's? I'm assuming they were on a 10" wheel, right?
Overtorque is offline
post #19 of 45 (permalink) Old 07-11-2008, 10:50 PM
TriShield's Avatar
I'm looking at getting wheel sizes 20x8 for the front and 20X9.5 for the back. 245/35/R20 up front and 275/30/R20 out back.
I'm guessing I should have no rubbing issues with the wheel turned lock to lock and no rubbing in the back even with rear passengers and luggage in the trunk.
post #20 of 45 (permalink) Old 07-12-2008, 12:05 AM
TriShield's Avatar
Would it be possible to run 275/35/R20 on 9.5 wheel with no rubbing or bottoming out?
