I have called aem to see if this od2 wide band,it piggy backs on to the obd port and would like to know can be used with the standard mpvi inter face ,, I have called tech support at aem and they couldn't answer that question ,,,,may be some can answer that or even better if they have this product ,shed some light on the performance ,, I had a innovate lm2 and was glitchy as hell ,here is the you tube video from them ,, thanks gmonde
From how it's described, HPTuners can read AFR directly through the OBD connector piggyback thing and no longer needs to be wired to the interface. So now either the PRO version or the reqular version of HPTuners can read AFR inputs. I'll bet it works.
after I posted this ,I found all the info on the hpt forums,, hopefully the AEM 30-0300 comes with the update flash ,,, this will be great if it works from the get go,, and it suppose to work with the mpvi-standard ,,,
