219/223 112+0 am results (E85 results too!) - Pontiac G8 Forum: G8 Forums - G8Board.com
  • 1 Post By ls1frc
  • 1 Post By ls1frc
post #1 of 16 (permalink) Old 04-17-2017, 07:11 PM Thread Starter
219/223 112+0 cam results (E85 results too!)
Took my car over to Complete Street in West Chester to do some tuning on my car. I drove there with half tank of BJs 93 and 5 gallons of E85 ready to pour in. First dialed in the tune on 93, and hit 431/418. Then I poured the E85 in (which amounted to E52.5%) and made several pulls trying to get anything out of it. It made the best power @ 437/424 on E50 with the same tune config as the 93. Tried leaning it out as well as adding timing, but the 93 tune was still optimal.
Mods on my 6.0
-Cam motion 219/223 112+0 .612 .595
-Milled stock heads .030 with .040 cometic and ls3 valves (no porting)
-Johnson linkbar lifters (these are nice)
-ATI 25% UDP
-ARH catted headers into stock mufflers
-Rotofab with big pipe
-Flex fuel sensor
This is on a load bearing dynojet tuned by me. Needless to say, I was thrilled with the power curve. Peaking before 6k and making that much power is great. It does rip on the street. I may try to get some track times as well, but it's my only car ATM and is a baby hauler, so I am a bit hesitant to take the risk.
I'm trying to figure out ways to eclipse 450. I was thinking of trying that RCR AirRam intake manifold job, as I heard some positive things about it. I also think the stock mufflers become a restriction at this power level, however, I already tried Chevy SS mufflers and I had to take them back off because they were way too loud for my 2 year old, so I am not sure there is anything I can do here.
pir4te likes this.
ls1frc is offline
post #2 of 16 (permalink) Old 04-17-2017, 07:33 PM
cstmg8's Avatar
Good numbers
Sent from my XT1585 using Tapatalk
09 panther black G8 GT
Show:19x9.5's rear w/rolled fenders, 18x9.5's front, 20% tint, trim/lense tint in progress, sub rewire, amp adj, VIM w/ dvd in gb, interior blackout in progress.
Go: spectre, hsrk, lpm, pacesetter LTs, full 2.5" cat/mid/res delete, flowmaster ABs, INTENSE tune.
97 Red GP GTP- ECM, headers, custom exhaust, ported blower, heads, TB, CAI, etc....... sold
91 GP GTP- L67 swap, tranny, headers, exhaust, ECM, and a few more.... ;-) sold
cstmg8 is offline
post #3 of 16 (permalink) Old 04-17-2017, 11:47 PM
Nice
post #4 of 16 (permalink) Old 04-18-2017, 06:38 AM
G8GTLVR's Avatar
Excellent numbers! Torque curve is awesome also and well above 300 from 1500 to 6500 RPM. How is the driveability with this cam? How is the idle? Was this an off the shelf cam or a custom grind? I am contemplating a cam for my G8 and was thinking of the Cam Motion LS3 Stage 1 but looking at your results, I might have to reconsider
As for hitting 450 HP, I think your best bet would be a ported intake and TB or a FAST intake. You could also have your heads ported.
2006 GTO
G8GTLVR is offline
post #5 of 16 (permalink) Old 04-18-2017, 06:46 AM Thread Starter
Originally Posted by G8GTLVR View Post
Excellent numbers! Torque curve is awesome also and well above 300 from 1500 to 6500 RPM. How is the driveability with this cam? How is the idle? Was this an off the shelf cam or a custom grind? I am contemplating a cam for my G8 and was thinking of the Cam Motion LS3 Stage 1 but looking at your results, I might have to reconsiderloop
Rick Crawford came up with the specs using Lunati lobes a few years back. I just put it on cam motion lobes because had bad experience with Lunati and whining cams in the past.
The cam had -3 overlap, so can drive close to stock if tuner knows what theyre doing. It did take a lot of massaging to get it right though. Hardest part is getting the downshifting smooth coming to a stop.
ls1frc is offline
post #6 of 16 (permalink) Old 04-18-2017, 06:54 AM Thread Starter
Here ya go. Idle with two different mufflers.
https://youtu.be/Hx_2xMVePHI
https://youtu.be/tewMDqjtzKM
ls1frc is offline
post #7 of 16 (permalink) Old 04-18-2017, 06:51 PM
gmonde's Avatar
are you running a stock A6 converter?
kook 1 7/8 long tubes, ls3 cam,dod delete,tuning school transmission tune,cai,corsa exhaust,lowered 1",staggered wheel set 19x8.5 19x9.5 breyton gts av,3.45 gear ,BMR rear control arm/w poly bushings
12.86 @ 109.00
gmonde is offline
post #8 of 16 (permalink) Old 04-18-2017, 06:54 PM Thread Starter
Yes, stock.
ls1frc is offline
post #9 of 16 (permalink) Old 04-24-2017, 08:48 AM Thread Starter
Sending my intake out to get the rods put in. Will have back in a week or so and will swap it right on the dyno. Stay tuned for results.
ls1frc is offline
post #10 of 16 (permalink) Old 04-24-2017, 02:19 PM
100. Shot.
450 eclipsed.
2008 G8 GT - Grey / Black - stock with a tune - 13.30 @ 105
2002 Trans-Am - Navy Blue Metallic / Black - M6 - Heads, Cam, N20 - 11.23 @ 127 - 525 RWHP
1991 Corvette - Black / Black - M6 - 383 - 11.37 @ 122 NA - No nitrous times - 415 RWHP NA - 550 RWHP N20
1989 Mustang LX - Gun Metal Grey / Black - M6 - Heads, cam, some other stuff - 12.57 @ 109
Josh Kinzey is offline
post #11 of 16 (permalink) Old 04-25-2017, 04:08 PM
In for results. I've been thinking of doing the same.
Strykerblue09GT is offline
post #12 of 16 (permalink) Old 04-25-2017, 05:55 PM
Naturally as-pirated
pir4te's Avatar
As an aside @ls1frc in the second clip there is a light drone evident at idle, like a hollow tin rainwater downpipe. With the radius bars tumbling correctly that will turn louder and more deeper into a 'whooo' type of Owl signature sound.
There are a couple of work around if that bothers you.
pir4te is online now
post #13 of 16 (permalink) Old 05-15-2017, 10:58 AM Thread Starter
-Rod mod arriving tomorrow
-Getting hooker VR304 muffs put on with magnaflow midpipe as well
Hopefully this gets me to 450+
pir4te likes this.
ls1frc is offline
post #14 of 16 (permalink) Old 05-15-2017, 12:57 PM
Looking forward to it, thanks for sharing.
post #15 of 16 (permalink) Old 05-15-2017, 03:20 PM
CG8GT's Avatar
Nice Numbers. Good luck getting to 450. It'll be close.
2009 Panther Black Metallic G8 GT
Mods: RCR milled and ported heads, RCR Air Ram Intake and Ported TB, 223/231 Lunati Cam
Yank 3200SS stall, B&M Trans Cooler, SLP UDP, LS7 MAF
SOLO Mach Shorty, SOLO HFC's, Kooks 1 7/8" LT Headers, Roto-Fab CAI
Tuned by Rick Crawford
20" TSW Nurburgrings with Nitto's
CG8GT is offline
post #16 of 16 (permalink) Old 05-15-2017, 07:57 PM
BarnesGN's Avatar
I've got Full bolt ons catted, with ported ls3 heads milled using 93 octane 442 hp. RCR ported heads should get you over 450. Have you thought about LSA heads ported or LS7?
08 MGM GT RCR Tuned ported TB/Intake Kooks Lt 1 3/4 Vararam Beautiful powder coated OEM 18's Magnaflow exhaust Magnaflow 12468 X pipe Ran 13.03 @ 108 mph. GTO 17 s with 275/40/17 Mickey Thompson et street Drag Radials.
SLP Underdrive pulley25% 3.45 Rear gears Mighty Mouse Catch Can Little Lunati plus with Psi 1511 valves titanium retainers, Gmpp LS3 heads milled.030. Dyno at 442 hp 413tq. Track time!
BarnesGN is offline
