Steering Wheel Shake - Page 50 - Pontiac G8 Forum: G8 Forums - G8Board.com
Closed Thread
post #981 of 1001 (permalink) Old 11-10-2012, 09:34 PM
Originally Posted by G8Silbllt View Post
Just a thought....Could the boat ride over or shipping manner caused premature wear or play in the racks to many of our cars? It's a common thread to all of our cars with the issue of course....
Well, we do know a lot of them show up with collapsed strut mounts...so anything is possible I suppose.
35W HID, LED fogs, custom front/rear Pontiac symbol badges, sharkfin, BlueStar Bluetooth, GXP front end, GXP diffuser, x-pipe, straight through mufflers with helmholtz chambers, RotoFab intake , Eibach springs, FE3 shocks/struts, BMR rear subframe inserts
romeyjdogg is offline
post #982 of 1001 (permalink) Old 11-10-2012, 11:32 PM
TheStevo's Avatar
Maybe the swaying side to side putting force on the rack since they are tied down?
TheStevo is offline
post #983 of 1001 (permalink) Old 11-11-2012, 07:43 PM
BTWS6's Avatar
That's a great thought, I know that back in the early 80's GM had a problem with a specific car line that was being damaged on long train rides because of the way they were chaining them down.
Sport package, performance package,
Vararam CAI,Kooks 1 7/8" headers, Magnaflow exhaust, Cat delete,electric dumps, Pat G. tune, 4D's 20" AO6 wheels, custom L.E.D. interior/exterior light package,Polk audio subs with Kicker door speakers,3,000 watt amps. Full HID light set up, 8" SS stripe set,
BTWS6 is offline
post #984 of 1001 (permalink) Old 11-12-2012, 11:24 AM
I have another follow-up regarding my car (see post #969 for my previous update). The dealer called and said the vibration was cured by replacing the engine mounts. According to the trouble-shooting procedure in TSB 10-03-09-001, the mounts become suspect after tires, wheels, and brakes have been ruled out. The only problem I have with this fix is that I thought mounts are a solution to excessive vibration caused by the AFM, which was not my issue. My car also vibrated with the AFM disengaged via manual transmission mode.
I am going to get the car now and go for a ride with the tech. I really hope this works.
c1054 is offline
post #985 of 1001 (permalink) Old 11-12-2012, 04:49 PM
How'd this go?
post #986 of 1001 (permalink) Old 11-12-2012, 07:07 PM
Supercharged Moderator
SMSO966's Avatar
Fixed my steering wheel shake today!!!
DD: 08 White Hot G8 GT Best E.T. 12.698 @ 109.1 MPH
VMR 20's 4 Wheel 04 CTS-V Brembo's
FE3 & Eibach,
Roto Fab,Doug Thorley LTs Magnaflow
1 of 1,086 2008 White Hot Pontiac G8 GT's
Garage Queen:
09 Stryker Blue G8 GT (No ET Under construction)
TVS1900, GXP 19's, 4 Wheel 09 CTS-V Brembo's
Rotofab, Solo, More to come soon!
Sold!
SMSO966 is offline
post #987 of 1001 (permalink) Old 11-12-2012, 08:09 PM
Originally Posted by smso966 View Post
fixed my steering wheel shake today!!!
ಠ_ಠ
post #988 of 1001 (permalink) Old 11-12-2012, 08:34 PM
Now it's a Party
SpeedRacerX's Avatar
Got rid of the car???
2009 GT, Kooks 1-7/8 Mids, RPM Tune, Borla, Vararam, HSRK, P&P TB, UPR CCan, Mobil 1, Speedhut Gauges, FE3, Whiteline, Pedders, Summer MRR on 255/295, Winter Beyern on 245, CTS-V Fr Brembos, SS Rotors, Akebono Pads, Rolled/Pulled Fndrs, BMR Sways, Spohn Links & Arms, Sprt Pedals, Pont Shifter, Camaro Trans Pan, Pont Mats, Glove Box Light, MSM Lower Grills, CF Tail, GXP Diff, VG Fin, 20% Tint, 6000K HIDs, LED Fogs, GrafxWerks, Black Trim/Mirrors/Grills, Diffusr Lens/Amber Lens/Lowr Tails Tint
SpeedRacerX is offline
post #989 of 1001 (permalink) Old 11-12-2012, 08:36 PM
SMSO966's Avatar
I changed my lower control arms and radius rods (replacing the new stock bushings with Super Pro radius rod bushings from BMR) and re-aligned the front.
Took a total of two hours.
FE3 & Eibach,
Garage Queen:
Sold!
SMSO966 is offline
post #990 of 1001 (permalink) Old 11-13-2012, 07:59 AM
Originally Posted by romeyjdogg View Post
How'd this go?
I picked up the car yesterday (see post #985). The vibration seems to be gone (or at least masked) by the new engine mounts. I maintain that there is a deeper issue with the vehicle that is likely not 100% solveable, but it is hard to continue raising hell based solely on my intuition. The casual rider in my car would not notice anything, but I, like most G8 owners, am not a casual rider. I love driving and the feeling of being immersed in the vehicle.
The mounts will do fine, at least for now. Given what has happened, I am obsessing about every little noise and shake; if you look for trouble, you often find it. The big test will be when I do my next tire rotation. Rotations seem to upset the machine's delicate balance.
I have to give a credit to the Coleman GMC service department for their patience and willingness to get things right.
c1054 is offline
post #991 of 1001 (permalink) Old 11-13-2012, 10:26 AM
That's great news. The improved engine mounts are designed to do just that...mask normal engine vibrations so they don't transmit though the frame/steering rack/etc causing unwanted vibrations and other harmonic pulsations. As an FYI, my car still has the original transmission mount(s). It is my understanding that GM also came out with an improved trans mount to better dampen/isolate both normal vibrations emanating from the trans/engine at that subframe connecting point + dampen/isolate a mildly unbalanced driveshaft. I still get the minor pulsating vibrating that comes in and out at highway speeds - if I really wanted to go through the hassle and potential cost of upgrading the trans mount, I guess I'd do that too but my biggest issue was the steering wheel vibration and like I said before, the revised new engine mounts did the trick for me as well. At my next oil change, I'll ask the SA how much it would cost to replace the trans mount. If it's not terribly expensive, I may do it.
2008 G8 GT (SOLD on 1/11/13)
New ride: 2011 BMW 335i XDrive MSport
BMan is offline
post #992 of 1001 (permalink) Old 11-14-2012, 10:36 AM
GMCustomerService's Avatar
@TheStevo, I’m sorry to read about your vehicle concerns. I’m curious if you have any further updates to share; were you able to get the vehicle into the dealership and things of that nature.
Michelle, GM Customer Service
Have you checked into GM Owner Center? You can maintain service history, check on warranty or recall information, and more. Visit my.gm.com!
GMCustomerService is offline
post #993 of 1001 (permalink) Old 11-14-2012, 12:44 PM
@c1054, would you like me to forward a compliment to the dealership on your behalf?
post #994 of 1001 (permalink) Old 11-14-2012, 02:06 PM
Just put on another set of tires for the winter. No shakes. Appears the deal was entirely balance and related.
EMS Guy is offline
post #995 of 1001 (permalink) Old 11-14-2012, 02:06 PM
Glad to see GM with a voice on here about issues.
EMS Guy is offline
post #996 of 1001 (permalink) Old 11-15-2012, 01:47 PM
Thank you, EMS Guy! I’m happy to be on the forums with all of you. Please, don’t hesitate to contact me with comments, questions and concerns or to just say hello.
post #997 of 1001 (permalink) Old 04-21-2013, 10:48 AM
Now it's a Party
Sorry to revive this notorious old thread.
New tires and a road force balancing has eliminated 90% of the steering wheel shake I had at 60-70 mph.
After 4 years, two sets of wheels and tires, the full dealer TSB for this, etc; I finally have some resolution.
post #998 of 1001 (permalink) Old 04-21-2013, 08:58 PM
GR8WHIT
johnson05711's Avatar
Okay so I just got my '08 White Hot G8 GT yesterday and today I noticed that the front end shakes when turning left and right and when I brake it shakes pretty good then too. I'm sure the braking issue is from the rotors but what would cause the shake only when turning?
johnson05711 is offline
post #999 of 1001 (permalink) Old 04-21-2013, 09:04 PM
Back in a Pontiac's Avatar
For now, lol
Back in a Pontiac is offline
post #1000 of 1001 (permalink) Old 04-21-2013, 10:38 PM
Now it's a Party
Originally Posted by Back in a Pontiac View Post
For now, lol
I hear ya. LOL.
Closed Thread
