Drive to Drags on Traction Tires ? - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 23 (permalink) Old 04-18-2017, 07:10 PM Thread Starter
GXP-G8's Avatar
Ok, I've been reading about tires for drag use that I can drive to the track on, 100 miles away.
Seems the more I read the more confused I become.
I like to take her to the track as often as I can, but I NEED TRACTION !
So looks like I need to go 17", is this correct ?
I'd like it to be a 295 or larger, on stock height GXP.
I've looked at weld, race star and seems all I find is 9.5" wide.
So the question is, what dang wheel and tire should I run ?
rears only for now.
09 G8 GXP Auto, 4dr GTO 13.60@105.8 6177DA... tvs2300 13.2@110.2 spinning all the way !
07 G5 GT 2.4T Auto, Baby GTO 13.20@106.4
@ 4200' in the sky !
Originally Posted by andrewbrooks87 View Post
towing stuff with cars is cool !
GXP-G8 is offline
post #2 of 23 (permalink) Old 04-18-2017, 07:42 PM
MGMGXP's Avatar
Forget the tires, did you only pick up 4.4 mph after you added the blower?
MGMGXP is offline
post #3 of 23 (permalink) Old 04-18-2017, 08:03 PM Thread Starter
GXP-G8's Avatar
Yes Sir,
but without the blower she would get some traction and go.
With it she just blows the tires off, 3 gears.
295 Toyo proxies +4
This is only with 5 psi @ 4200'
GXP-G8 is offline
post #4 of 23 (permalink) Old 04-19-2017, 09:24 AM
MGMGXP's Avatar
Something is wrong.
MGMGXP is offline
post #5 of 23 (permalink) Old 04-19-2017, 11:13 AM
17x9.5 will be big enough to fit a tire you need to hook..
Strykerblue09GT is offline
post #6 of 23 (permalink) Old 04-19-2017, 02:55 PM Thread Starter
GXP-G8's Avatar
Something is wrong.
YES it is.....it is called TRACTION !
GXP-G8 is offline
post #7 of 23 (permalink) Old 04-19-2017, 03:07 PM
One of my customers got down when he ran the same exact ET with and without the blower. lol. Only difference was he gained 15 mph in the 1/4 on 6 psi.
I have some very light Greg Weld wheels I'm selling for 180.00. They fit my G8 perfectly. They are 17x9.
PBM G8 GXP M6-Self flex fuel tune,OBX LTs, Kooks A/B, Monster Stg 3 clutch, LSA S/C, cam, fuel system, stock block and stock heads.
Best e.t 10.81/ best mph 135 Half Mile: 166.9 mph
2007 TBSS-Self tune, bolt ons 13.06@106.7, 2,200 D.A
1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
2002 Bonneville SSEi- Self tune, 3.4" pulley, FWI. The beater
post #8 of 23 (permalink) Old 04-19-2017, 08:03 PM Thread Starter
GXP-G8's Avatar
pics ? 5 spoke wheel ? what is the widest tire I could fit ?
GXP-G8 is offline
post #9 of 23 (permalink) Old 04-19-2017, 09:44 PM
MGMGXP's Avatar
he ran the same exact ET with and without the blower...he gained 15 mph in the 1/4 on 6 psi.
This is a traction problem.
This is not.
MGMGXP is offline
post #10 of 23 (permalink) Old 04-20-2017, 05:50 AM Thread Starter
GXP-G8's Avatar
This is not.
What is the problem then ?
GXP-G8 is offline
post #11 of 23 (permalink) Old 04-20-2017, 07:19 AM
BlueG8GT's Avatar
How much throttle do you give it down the track. I'd have to imagine with the traction problems you're describing that 3/4 throttle may be all you can use during your run.
2009.5 SBM GT: Lots of show with some go.
The garage queen.
2008 IOM GT: Some go, working on the show.
The daily driver.
2004 Blazer Xtreme: Lots of go.
Sold and will be missed.
BlueG8GT is offline
post #12 of 23 (permalink) Old 04-20-2017, 08:34 AM
G8 GT GUY
Norm8332's Avatar
If you are spinning all the way on 5 psi then you are right, your tires are junk or the track prep is bad.. I'm running street tires..285r18s goodyear supercars and it just barely spins in first at the track. Make sure traction control is off..it actually made any spinning worse for me at the track.
2008 G8 GT: Magnacharger TVS MP1900 @10psi, LS9 cam, 72# injectors,SLP Headers, Corsa catback
Norm8332 is offline
post #13 of 23 (permalink) Old 04-20-2017, 01:24 PM
MGMGXP's Avatar
At only 5 psi at 4,200' elevation, the car isn't making enough power to spin all the way through third gear unless the driver is either, 1. doing it on purpose, or 2. really doesn't know how to drive/shift/race. Yes, I'm sure the car would benefit from some drag radials. That is an easy fix. The fact that the car picked up < 5 mph tells me that something isn't right, probably in the tune.
I suggest a smaller pulley, fuel system parts as needed, some drag radials and seat time. For comparison, my car trapped 117+ NA, with intake, exhaust, heads and a mild cam. Albeit at close to sea level.
MGMGXP is offline
post #14 of 23 (permalink) Old 04-21-2017, 06:22 AM Thread Starter
GXP-G8's Avatar
FULL THROTTLE
Traction control is on, tires must be junk, track prep maybe bad.
When she shifts to third she spins crazy and wants to head for the wall. Gotta get out of it, almost like a pedal fest, on, off, on, off.
Mr. Pat G is the tuner and said we are good !
BlueG8GT likes this.
GXP-G8 is offline
post #15 of 23 (permalink) Old 04-21-2017, 11:36 AM
BlueG8GT's Avatar
Originally Posted by GXP-G8 View Post
FULL THROTTLE
That must be one heck of a ride. Good luck finding a set of drag radials that work for you. Let us know what you run when you finally get some traction.
The garage queen.
The daily driver.
BlueG8GT is offline
post #16 of 23 (permalink) Old 04-21-2017, 01:17 PM
MGMGXP's Avatar
I guess you just need to buy some traction tires then.
MGMGXP is offline
post #17 of 23 (permalink) Old 04-21-2017, 06:07 PM
I ran Toyo Proxes R888 315/30ZR20 on the rear and they were great. They are a bit expensive and considered a street legal race tire, perfect for driving to the track and back.
My G8 is LSA SC at 13psi then, drove on them daily even in the rain and never had a problem, including two trips from S. FL to NY and back. Just had to be careful when it was wet out or sub freezing temps. Prob lasted 9k miles
Sent from my Nexus 6 using Tapatalk
G8eraid is offline
post #18 of 23 (permalink) Old 04-21-2017, 07:42 PM Thread Starter
GXP-G8's Avatar
Thank You !
So if I went with a 17" wheel 9.5" wide....Do I need 54 offset wheel ?
GXP-G8 is offline
post #19 of 23 (permalink) Old 04-22-2017, 10:06 AM
gmonde's Avatar
can you post a picture of the wheels? I am interested in purchasing
kook 1 7/8 long tubes, ls3 cam,dod delete,tuning school transmission tune,cai,corsa exhaust,lowered 1",staggered wheel set 19x8.5 19x9.5 breyton gts av,3.45 gear ,BMR rear control arm/w poly bushings
12.86 @ 109.00
coming soon LSA
gmonde is offline
post #20 of 23 (permalink) Old 04-26-2017, 11:45 PM
Didn't know the sea level would make that much difference to how much speed the car would pick up. Is there a good gauge for what we would have to take into consideration when it comes to that effect on the car? Hope the OP can continue to update us with how things are going once he tries out some suggestions. Hopefully he'll see the pickup he wants with some of the advice here.
webbrowan is offline
