New PB : stock gears/stall, all motor - Page 4 - Pontiac G8 Forum: G8 Forums - G8Board.com
post #61 of 91 (permalink) Old 12-12-2012, 07:05 AM Thread Starter
Super Moderator
Troy Trackbeast's Avatar
Originally Posted by The Yeti View Post
You guys out there in NC are ripping it up. I wish the Cali contingent was as active.
you said it right in another thread the other day. Rick has G8's ripping it up from coast to coast, and that seems to be one of the common denominators between us.
Troy Trackbeast is offline
post #62 of 91 (permalink) Old 12-12-2012, 03:17 PM
dctg8's Avatar
We try
D1sc, Meth, Cts-v fuel pump, 223/235 cam, RCR Heads & intake, obx 1 7/8 headers, custom Corsa axle backs, Circle D 2800, 305/35/19 DRs, and more mods that I can't remember.
Dyno #s TBD
D1sc Best 6/6/14 *hot & muggy*
10.63 @ 132 w 1.69 60ft
P1sc Best 11/24/13
10.36 @ 133 w/ 1.51 60ft.
N/A PB 1/05/13
11.45 @ 120 w/ 1.62 60ft.
dctg8 is offline
post #63 of 91 (permalink) Old 12-12-2012, 06:46 PM
HPT Pro Tuner
bluegoat06's Avatar
Very nice Troy, what are you cam specs ? that trapping speed is awesome. I agree with Yeti, you won't see many G8's running at the track around here, much less now that we don't have a 1/4 mile track to race. Every other Mustang, Mopar, Camaros and my G8 are at Irwindale almost very Thursday, but is only 1/8 mile, half of the fun, but awesome when you're able to measure your car against others similar modded.
By March/April i'm expecting my car to be cammed, so in the meantime, i can only be jealous of you guys setups and track times. Hopefully our 1/4 mile track would be open by then as well.
Have fun, btw, if you want some very good tires for your car, without going through a DR setup, try the Nittos NT05's, the Z06 vette crowd in our local 1/8 mile track swear by them, they can launch, and corner very well according to their conversations.
2012 Mustang GT, M6, 3.73's, Base/Brembo Package
3" H Pipe/Stock cats, Res!/3" pipes, Magnaflow 14419's AB, UPR Catch Can
HPTuners Pro v2.25 | Street Tuned
2010 Silverado 1500 LT Crew 5.3L
Magnaflow 14619, K&N Drop Filter, Airraid MIT, UPR Catch Can, American Outlaw Deputy 17x9, BFG 285/70/17 TKO, Bilstein 5100's
Hptuners 2.24 Pro / Street Tuned
bluegoat06 is offline
post #64 of 91 (permalink) Old 12-12-2012, 06:57 PM Thread Starter
Super Moderator
Cam is COMP Custom Grind 223/231 .610/.617 112+0
Got the NT05r's sitting in the garage with GTO front runners (damn I love craigslist). She will go 11's my next pass on the track, I know she has it in her. Right now shooting for the first Saturday after Christmas!
post #65 of 91 (permalink) Old 12-12-2012, 07:31 PM
'Mod'erator
The Yeti's Avatar
Damn troy you are not playing! With my big brembo setup I couldn't fit something like that up front. Hell I am going to be breaking bread on a drag setup.
LSA, Pat G DOD cam, RCR TB, 4.5IN Intake/MAF,
CNC LS3 Heads, OBX,
H&Rs, Konis, BMR, Brembos, Slotted/Drilled Rotors
3.27 Gears, 2600 Stall, ZL1 pump, Ice tank
Tuned By Pat G and Luis at RPM Speed Center
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.2 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
second gear pull
The Yeti is offline
post #66 of 91 (permalink) Old 12-12-2012, 07:44 PM
HPT Pro Tuner
bluegoat06's Avatar
Awesome, that should put you in the 11's, i have the GTO drag pack as well, GTO rears with Toyo DR's, and GTO spares wheels with the stock donut tires. I've only used the spares once, but didn't like the feeling when i was trying to stop the car at the end of our 1/8 mile track, Ran them at 40 PSI, so perhaps that's why they're feeling loose while breaking, i'll be buying a pair of M&H front runner tires, install them in the GTO spare wheels and call it a day. I want to run in the 7's before i do the cam, mostly cause i don't have the dove now, so i've set to get in the 7's first
Btw, is that FZ8 in the pic ?
post #67 of 91 (permalink) Old 12-12-2012, 07:50 PM Thread Starter
Super Moderator
Originally Posted by bluegoat06 View Post
Awesome, that should put you in the 11's, i have the GTO drag pack as well, GTO rears with Toyo DR's, and GTO spares wheels with the stock donut tires. I've only used the spares once, but didn't like the feeling when i was trying to stop the car at the end of our 1/8 mile track, Ran them at 40 PSI, so perhaps that's why they're feeling loose while breaking, i'll be buying a pair of M&H front runner tires and call it a day. I want to run in the 7's before i do the cam, mostly cause i don't have the dove now, so i've set to get in the 7's first
^R6
Should I balance the skinnies? I hadn't thought about them making the car squirley .
Sent from my iPhone using AutoGuide.com App
post #68 of 91 (permalink) Old 12-12-2012, 07:56 PM
HPT Pro Tuner
bluegoat06's Avatar
Originally Posted by Troy Trackbeast View Post
^R6
I did, but that wasn't the problem, they ran straight and planted, but i felt them skidding when i was trying to slow down, i normally take the first exit past the beams at the end of the 1/8 file run, and normally slam the brakes and turn right, no way i was going to make it with the spares, lol, she was just locking and (unlocking because the ABS) and not slowing down that fast.
I think 40 psi is too much for the track, everybody else with real front runners run them between 28-32psi, i'm just to chicken to go that low on a damn donut tire.
post #69 of 91 (permalink) Old 12-12-2012, 08:01 PM Thread Starter
Super Moderator
I have plenty of slow down room and shouldn't have to get on the brakes hard. I feel like if I tried to take a turn at any speed they would explode under my fat girls weight LOL
post #70 of 91 (permalink) Old 12-12-2012, 08:08 PM
HPT Pro Tuner
bluegoat06's Avatar
Lol, in that case, you shouldn't have any problems, they would hold up, they hold more weight than a regular street tire, but i think you have to pump them up in order for them to do that. I'm not really sure, i asked several times from the guys who run them in here, and never got an answer on how much PSI is good for them, so i'll just get the real front runners for piece of mind. The wheels themselves won't have any issues.
Here is a view of what i did to make them "Tech" friendly, i didn't know if they were going to allow me to use this combo with all the Temporal usage, Spare only, etc, etc labels and tags in the wheels and tires.
"I did a little bit more grinding today because i was obssesed with the temp only use lettering, and removed those messages from the tires as well as the one that said convenient spare and the T before the 145/70/17 , i need to see if i can smooth out the finish in the rubber, but oh well, it's done, i also put some primer on the wheels first to make sure the temp only use letters were gone (english and french words), left the rest untouched "
Uploaded with ImageShack.us
after this i painted the wheels with primer and black gloss to match the stock color, and also painted the GTO rears as well so i have a matching drag pack , came out pretty good.
post #71 of 91 (permalink) Old 12-13-2012, 12:02 AM
dctg8's Avatar
I'll try to be there that sat. See if I can hit 11.4s or even 11.3s if i get some weight off the car
Dyno #s TBD
P1sc Best 11/24/13
N/A PB 1/05/13
dctg8 is offline
post #72 of 91 (permalink) Old 12-13-2012, 06:15 PM
dctg8's Avatar
I got some gto spares aswell Troy. We shall see if these will get me closer to the cam on record!!!!
Dyno #s TBD
P1sc Best 11/24/13
N/A PB 1/05/13
dctg8 is offline
post #73 of 91 (permalink) Old 12-13-2012, 06:40 PM Thread Starter
Super Moderator
Good deal man. We will get up after the holidays and make some runs. In the meantime Me and Rick are working on getting a full 2.5"-4" exhaust installed, I'm thinking I'm highly restricted with hacked stock mid section. Hoping for at least another 10-15 ponies. I hate knowing I have power left on the table...
post #74 of 91 (permalink) Old 12-13-2012, 06:52 PM
HPT Pro Tuner
bluegoat06's Avatar
Rick is the man, i'll also have his ported intake when the time comes
post #75 of 91 (permalink) Old 12-13-2012, 07:49 PM
Super Moderator
DRUMSBH's Avatar
His ported intake is on sale from now till 01-01-13 then the price goes up. Just letting you know.
Sent from my EVO using AutoGuide App
08' Pontiac G8 GT PBM
11.323@121.66 Rock Falls Raceway 10-11-14
N/A RCR car.
DRUMSBH is offline
post #76 of 91 (permalink) Old 12-14-2012, 12:26 PM
HPT Pro Tuner
bluegoat06's Avatar
Nice, thanks a lot for the tip, i've just emailed Rick to know about the price and how to get it
post #77 of 91 (permalink) Old 12-23-2012, 01:24 PM
450ish DA
Sent from my iPhone using Autoguide.com App
Where do you find your DA info? I always end up using Drag times and have had good luck with it. Looks like the DA around your best pass was 15DA( i am jealous of you east coast guys with the awesome DA and Tracks staying open most all the year)
2009 G8 GT-10.55@134.3 1.60 - SOLD!
2008 C6 A6-Cammed/Stall 10.62@126.7 1.44' SOLD
2013 CTSV WAGON- in the works....
shane is offline
post #78 of 91 (permalink) Old 12-23-2012, 01:50 PM
'Mod'erator
The Yeti's Avatar
I hear you! I would love to get a run with temps in the 40-50s. We have a track out here that stays open in the winter, but they don't prep it at all so it is super dangerous. You end up aborting a 1/4 of your runs out of fear of spinning out. You have to roll into it real smooth, and lift just a tad in second when it gets loose. It is what it is though. I just wish they would stop messing around with the mpg measure ment. One week it will read one thing, then the next week it will read 2mph slower lol
CNC LS3 Heads, OBX,
After Stall
Zex 125shot
second gear pull
The Yeti is offline
post #79 of 91 (permalink) Old 12-23-2012, 02:09 PM
Yea some tracks measure MPH different that's for sure.
For example last year when my G8 was just the blower no cam or anything i went to a outlaw 1/8th mile track and trapped 102 in the 1/8th, one week later i went to a 1/4 track where the mph was timed different and trapped 96 in the 1/8th.
MPH all depends on placement of sensors/wiring/Different timing companies.
NHRA tracks are supposed to use the 66 foot measuring rule.
shane is offline
post #80 of 91 (permalink) Old 12-23-2012, 05:03 PM Thread Starter
Super Moderator
We were using the drag times app that day, and that's the number it was spitting out. But you are right, pulling it up via track and time that day is 15'.
I still want that 50 deg day pass. I'm desperate for an 11s pass. Should see it with the drag radials and front runners; I will also be trying some different launching techniques.
We will find out the next Saturday hopefully!
