MAF Question? Possible HP gain?? - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 22 (permalink) Old 04-17-2008, 04:32 PM Thread Starter
Auto paint specialist
Ausstar's Avatar
hey guys.
I have been told that if you take that mesh screen out in the MAF you get better flow and therefore more HP. The theory is sound but will it mess comp codes up??
Thanks guys.
When i put my CAI on a couple of days ago I noticed that the screen is in there pretty good and would not be easy to pull. My local speed shop can port the MAF and TB. I would assume they will do it then anyway... so... ??
#845
2008 Pontiac G8 GT, prem+ Sport pkg.
mods: all round tint, axle back magnaflow, NE CAI, VMS ECM, TCM tune
Ausstar is offline
post #2 of 22 (permalink) Old 04-17-2008, 04:37 PM
Owner / Operator
TomPierce's Avatar
That screen is there to smooth the airflow so that the Mass AIRFLOW Sensor can do its job correctly. Removing the screen will screw up the signals that it sends to the computer which will then screw up the amount of fuel thru the injectors.
2008 MGM G8 GT - #615 of 888 - Premium/Sport - 12.6 @ 111 on stock tires
SHOW - Chromed Wheels - Color Matched Splash Guards - Debadged - G8 Tail Lights - GXP Diffuser - Painted Calipers - Under Hood Lights - too much Zaino
GO - ARH Long Tube Headers / Midpipes - BMR Front / Rear Swaybars - Camaro 3.45 diff - Custom non-DOD Cam and Valvetrain - Homegrown PCM / TCM Tuning - K&N Filter - Pedders 'Fruit' Suspension - Yella Terra Intake - Stealth Airbox
TomPierce is offline
post #3 of 22 (permalink) Old 04-18-2008, 04:08 AM
Internet Police
that is PROBABLY true, but do you have any data to back that information up from another G8?
2003 Mustang Cobra Convert.
TrickStang37 is offline
post #4 of 22 (permalink) Old 04-18-2008, 07:47 AM
Site Sponsor
GTPprix's Avatar
Leave the screen in
Chris White
www.GTOShiftLight.com
2006 Spice Red GTO - Stock
2012 Cherokee SRT8 - Tuned
2013 XTS4 Platinum - Custom BCM/IPC/HMI
2013 Enclave AWD - Stock
2015 Yukon Denali #1 - Custom IPC/BCM/HMI
GTPprix is offline
post #5 of 22 (permalink) Old 04-18-2008, 07:59 AM
CCG8 / FLG8
G8V8's Avatar
The screen is there to make sure the sensors in the MAF see a true picture of the average condition of the incoming air. If you remove the screen you MIGHT, see a very small increase in max flow, the MAF and screen are typically not the main restriction in the intake system. The trade-off for a pretty meaningless gain at high flow rates is poor measurement at low flow rates and difficulties metering correctly at idle and low speed operation.
Not worth it. Leave the screen intact. There is no free lunch.
*3rd in Class,GM Nationals 2008,2009
*Award of Excellence, GM Nationals 2010,2012
*Celebrity Pick, GM Nationals 2010
*G8Board G8 of the Year, 2010
*3rd in Class, WTW Fall Classic Pontiac Show 2013,2015
*Top 40/487, Cruisin' to the Creek Show 2015
*1st in Class, Southeast G8 Extravaganza, 2016
*1st in Class, WTW Show, 2016
*1st in Class, WTW Fall Classic Pontiac Show, 2016
RCR Intake/TB
Lunati Cam
ZL1 Brakes
Circle-D 6L80
Kooks+Solo
Pedders SC Coilover Track 2
BMR LCA
G8V8 is offline
post #6 of 22 (permalink) Old 04-18-2008, 09:37 AM
Basically the others summed it up, the screen helps smooth out and evenly distribute the airflow across the MAF wire which helps it achieve more accurate readings.
BUT, just about every modded f-body and Corvette on the road probably has their MAF descreened and has not had any issues with it. I personally have not seen any difference in MAF reading having the screen on vs. having it off.
Unless you are spraying a dry shot I don't see any reason to take it out at this point.
08' Blown G8 GT | 01' Formula M6 | 02' C5 Z06 | 09' Crew Cab LTZ
HANNlBAL KING is offline
post #7 of 22 (permalink) Old 04-18-2008, 10:41 AM
Internet Police
do you have data to back what your saying? On all my friends f-body's and b-bodies they all have ran a descreened MAF with zero issues.
Personally, I don't know if I would do it because a car like mine has a very sensitive MAF. Just a CAI or adding tubing from the fog light area to the air fliter can make it start stalling. But im not going to sit here and pretend to say descreening a MAF will affect a G8 negatively as fact when there is ZERO proof/data out there to back up that statement. Nobody can even comment on the flowrates/horsepower gains at this point either.
post #8 of 22 (permalink) Old 04-18-2008, 11:11 AM
CCG8 / FLG8
G8V8's Avatar
There are number of guys with grand prixs that removed the screen to gain more flow at WOT. Some of them experienced poor idle performance and slight off-stumbles. The guys with power Tuners and HP Tuners could fiddle with the MAF table in this area and make it better. Others didn't care and just lived with it. I found on my '04 GTP that the very small increase in max flow and the very small HP gain were easily overshadowed by other changes and, in my mind, not worth the hassle.
I'm an engineer and we use MAFs in several non-automotive related products. If you screw with the flow pattern of the air moving across the element, you will go through flow rates that are pretty close and other that are not. It makes getting accurate measurements across the intended flow range pretty difficult if not impossible.
RCR Intake/TB
Lunati Cam
ZL1 Brakes
Circle-D 6L80
Kooks+Solo
BMR LCA
G8V8 is offline
post #9 of 22 (permalink) Old 04-18-2008, 01:05 PM
I know on the B-body's most of the guys strongly recommend against doing it. I assume the F-body's are the same. They say it's harder to tune it to be consistent without the screen I believe.
The new Corvette (Z06?) doesn't have a MAF screen. What I heard the story is with that is because the filter is inline with the MAF, and the distance is so short the air doesn't need the screen. But, wherever I read that may be wrong.
BSmith is offline
post #10 of 22 (permalink) Old 04-18-2008, 03:28 PM
Z06's haven't had MAF screens since 2001.
post #11 of 22 (permalink) Old 04-18-2008, 08:46 PM
Its not going to hurt anything to take the screen out of the maf.You will not see a big increase in airflow but every bit helps mine was out of my G8 the second day I had it. It will lean the car out a bit I have seen that on a A/F meter.I have 4 cars with lsx based motors in them and not one of them has a screen in the maf.
I have # 887 out of 888
U LUZ is offline
post #12 of 22 (permalink) Old 04-18-2008, 09:10 PM
SOcaliG8's Avatar
you say it leans out the AFR right?
from what i have read that by putting a CAI on it richen's the AFR...
So by taking off the screen in the MAF help HP when having a CAI?
thanks
SOcaliG8 is offline
post #13 of 22 (permalink) Old 04-19-2008, 09:13 AM
I pulled the screen on my 2000 Z-71 and my LTRIMS (Long Term Fuel Trims) went up 2% showing me a richer mixture.
'08 G8 GT #456:6L80E
'10 Camaro 2SS/RS:TR6060
vhato is offline
post #14 of 22 (permalink) Old 04-19-2008, 02:46 PM
carsuperfreak's Avatar
The screen removes the turbulence in the air and makes the flow more even. Since air behaves like a fluid, in a pipe it will have a velocity profile like so:
Without the screen, in a pipe of a consistent diameter that bends, turbulent air can play with the sensor, giving incorrect air readings. The screen effectively turns the large diameter pipe into many, small diameter pipes, allowing consistent velocity and laminar flow, and assuring good readings.
As a side note, the air is kept non-turbulent through the intake manifold and heads by "trumpeting" the runners to accomodate for the variation in velocity across the width of the pipe.
So having no screen in the corvette is acceptable because of the straight flow to the MAF, as well as a very un-restrictive induction. On the G8, with it's curved pipes for packaging, and resonator sections in the pipe for noise, you will get more consistent performance by leaving the screen in.
carsuperfreak is offline
post #15 of 22 (permalink) Old 04-15-2010, 10:15 AM
What about just changing the MASS AIRFLOW SENSOR to a aftermarket(high performance) one instead of taking out screen?...is that safer and wha bout HP gains?!?
RUNNING IN, WHILE THEY'RE RUNNING OUT!...
OUTASGHT is offline
post #16 of 22 (permalink) Old 04-15-2010, 06:54 PM
Aaron407's Avatar
FYI, an increase in your LTFTs (i.e. +2 instead of 0) means that you were actually running lean and the computer is commanding an additional 2% to bring it to stoich. To me that means you saw a leaner mixture rather than richer.
2009 PBM G8 GT
TVS 1900 Maggie w/2.8" pulley (9-10 PSI), Maximizer LTs, High Flow Cats, LS9 injectors, Rotofab CAI, LC-2 WB, 40A KB BAP, TR6ix plugs, self tuned [250+ flashes], Camaro Paddle Shifters, UPR catch can, 4300k HIDs, Remote Start Heated Seat Control Module , Aeroforce Interceptor Gauge, JBL GTO628's, JL 8w3v3's w/JBL P180.2, Bridgestone RE-11 tires
Aaron407 is offline
post #17 of 22 (permalink) Old 04-15-2010, 09:23 PM
simple typo. thanks. But it was richer. Computer was constantly fighting to get it inline after I tuned it. It was richer.
vhato is offline
post #18 of 22 (permalink) Old 04-15-2010, 10:46 PM
mi04se1's Avatar
I had a JET maf sensor in my old G6 GXP. At wot I got a cel with 2 lean codes. Chris was my tuner at the time and told me to put the stock one back on and I did and never had problems. Now you might beable to get a tune specific for a maf, dont know. My dad put it on his stock 08 GP and didnt have any issues. Its been on there all winter. But he doesnt do wot runs.
8000K hid lows, GM 2-way remote, BT from 09.5, VIM, Rotofab rad cover, GXP fascia & diffuser, Inalfa sunroof
Rotofab CAI, VMS ecm/tcm 93 octane dyno tune, Mobil1, Solo Mach Shorty, Solo hfc's, Kooks 1 7/8 LT's
BMR subframe connectors, trans brace, diff bushings, subframe bushings, trailering arms
Summer rims/tires- 19X8.5 FR (245/40 Hankook), 19X9.5 rr (275/35 Hankook)
Winter tires/rims- 18X8.5 all the way around (245/40 Michelin)
339 WHP
mi04se1 is offline
post #19 of 22 (permalink) Old 04-15-2010, 11:10 PM
jhue's Avatar
Sounds like a waste of time to take out a screen that is considered a part of the Factory Emissions system so it would or could have an affect if there is a problem while under warranty.Just my opnion. My trans Am is missing the screen and has always had a stumble when trying to speed up and it is a Ram Air factory car.
jhue is offline
post #20 of 22 (permalink) Old 04-16-2010, 03:02 PM
SANman1911's Avatar
It's what you would call a "lateral" upgrade. I would do nothing for you other than run a bit richer, better upgrades to spend your money on for sure.
You can de-screen the MAF yourself with a screw driver since it is only a thin aluminum mesh. You may affect daily driveability, talking from exp. you will not notice any gains. I purchased a spare MAF on flea-bay, it was de-screened so I ran it. No difference one way or the other for me.
FYI - LS2 GTO, not the G8.
SANman1911 is offline
