So we've been having an issue where the car has been knocking like crazy up top and now more recently a report that the car had 2 degrees of timing at 45 mph. We have exhausted just about all possibilities that we could think of that would cause this issue, and now have turned to you guys. So the back story.....
Changed tuners and cam's, when the last cam was pulled, we discovered the car had a bent valve and a nice little impression in the top of the piston, however, the car ran completely fine with in that condition with the last cam. After the new cam was swapped in, troubles started. Decently rough idle and of course the knock up top (3-7 degrees at 4500 rpm and up). I'm not understanding how it ran fine, bent valve and all with the last cam but with the new cam, were getting headache. Any ideas?
New Cam specs 223/231 .625/.622 111+0
About .025-0.030 clipped off of the heads, stock LS3 valves.
after the tear down on the first time finding the bent valves ,was there a piston to valve clearance check? and I would have checked the piston to valve clearance on the new cam for sure ,,,, I wouldn't run it to long in its current condition , due to more damage
We should have done so, but did not, we figured it ran fine before tearing it apart, so we put it back together as is. What baffles me is the tuners comment of him seeing only 2 degrees of timing at 45 MPH, I cant put that together of how that could happen.
Was the cam that you swapped out also aftermarket? Or was this the first cam job you've done on the car?
If it was a previous swap, did you degree it in? Did you degree the new cam in?
Always need to be sure to replace known damage parts, and new valves generally require a valve job especially when the sucker was struck and bent.
Until you properly fix your valve problem and verify that your cam meets spec and is installed properly, you can't otherwise observe to detect additional potential problems. You may want to price a full valve job to see how much it would be per cylinder. I would rather not do a single cylinder anyways, but with a single damaged seat you can probably get away with it as long as the other valves are fine.
Fueling is fine, though fuel pressure hasn't been logged, i think my tuner would have pointed out anything else out of the ordinary. It is not necessarily an audible knock, but you can hear the car "breaking up" through the exhaust in the higher rpm's. What specifically would you like to see in the log? I can screen shot and post it up, I appreciate the help.
Okay, it sounds like an ignition problem, and an ignition problem WILL cause KR.
Scan for current misfires on each cylinder using the Hp Tuners scan tool. Make sure the misfire tables in the tune are set to stock before doing this or the misfires will not be detected in the log!!
So, I finally had a chance to pull the heads, prior to doing so, I found plenty of oil around the intake ports and a decent bit inside of the parts and on top of the intake valves. This car has a catch can, that was not full, not even a little, so I'm not understanding why so much oil build up, catch can is routed like any other basic on (valley cover and driver side valve cover). I'm thinking the unburned oil getting into the combustion chambers is what could have been causing detonation and in turn knock? Any thoughts?
Injectors are good, and installed new plug wires prior to posting this thread. The catch can is hooked up via the driver side valve cover and the valley cover.
Let me ask you guys....lets say we mucked up cam timing some how and cam and crank dots were off by just one tooth....would a correlation code necessarily be thrown or would the vehicle still operate as normal?
yes ,the engine would idle but once you accelerate you will notice power and torque is way off ,also with the cam you have shown in your first post, I would figure you would have some piston to valve contact happening ,, there would be a code associated as long as the dtc wasn't turned off by the tuner, I don't know the code number(s) off hand but ,it will be a cam/crank sensor correlation description ,,in other words the ecm is picking up from the top gear that it is not in sink with the crankshaft
with that note to that: if the oil pump wasn't removed while doing the cam swap that might be the possible issue ,, it can be hard to see the marks on the lower gear
The cam that is in now, should not have PTV clearance issues....shouldn't...but there could always be that other percentage...i have something else for anyone who wants to look at it...this is a clip of the histograms from a recent log, I am wondering why the timing is negative (-) in some spots...surely this isn't knock? But why negative?
from what I can see from the graph is , your o2 millivolts drops to 0 and your timing goes to 40 degress to -2.5 (3:44:35 into the log file ) while your tps was a constant 19.2 ,,, a wide band o2 would be helpful to see how bad the lean spot is ,, its both banks that are doing it ,,, I would compare your tune to a stock tune just to see what the tuner changed in the fuel table ,,,
gmonde
