Differential Fluid Change - Pontiac G8 Forum: G8 Forums - G8Board.com
  • 1 Post By Jova007200
post #1 of 19 (permalink) Old 04-19-2017, 12:11 PM Thread Starter
Aim High - Squeeze Twice
I'm changing the differential oil in the coming weeks. I'm not taking the cover off, but I'd like to make sure the innards are good and clean. (At least reasonably clean).
Was thinking I'd drain and fill with new fluid. Then after a few months or so drain and fill again.
Thoughts on that?
'09 PSM G8 GT - Current Mods: Solo Axle-Back w/ X-Pipe OPG CAI. SuperPro Bushings (Front and Rear). BMR Sway Bars (Red)
Mods Planned: DOD-Delete, Stage 1C Livernois, Kooks Mids, GXP Trans Cooler, 2800 Circle-D Stall Converter, Differential (Max 3.45)
post #2 of 19 (permalink) Old 04-19-2017, 09:12 PM
Probably overkill.
I did mine at 140KM will do again at 200KM.
There was a thread on here months ago on the same subject, general feeling was no benefit to quick change but if you want piece of mind, hey its only time, money and gear lube.
post #3 of 19 (permalink) Old 04-20-2017, 07:58 AM Thread Starter
Mostly I was curious about getting it cleaned up in there. A part of me wants to... the other part says its not necessary.
I read several places with people putting things like diesel fuel and driving for a few miles to stir it up.... and I'm most definitely not doing that. LOL...
I think you've confirmed my gut instinct to not waste my time and an extra bit of money.
post #4 of 19 (permalink) Old 04-20-2017, 09:04 AM
Yeah, the lube costs enough to feel justified in doing it just once. That's what I did.
2009 SRM GT - Premium, Sport, Sunroof - HSV triple gauges and trim, HSV Supersport Red/Black Steering Wheel, GXP rear sway bar, GXP Diffuser, Rotofab, SOLO Axlebacks, Magnaflow Cats, Red Hot shift knob, Autodim mirror, Removed intake cover, Chrome lug nut covers, Infinity door speakers, 10" DVC RF Sub, Switchbacks, Slotted rotors & Braided stainless brake hoses, Cortex tuner
Admin: www.pontiacbonnevilleclub.com
J Wikoff is offline
post #5 of 19 (permalink) Old 04-20-2017, 10:27 AM
RANDOM VICTIM S.O.B.
ergeoverkill's Avatar
speaking of diff fluid, what are some preferred brands and weights used? i have searched a bit but not found any threads with personal preferences.
ergeoverkill is offline
post #6 of 19 (permalink) Old 04-20-2017, 10:47 AM Thread Starter
Lubricant | Genuine GM | 92184900 : GM Parts Direct: Your direct source for Genuine GM Parts
That's the GM Fluid, which is made by Castrol. It's got the friction modifier needed and everything. No reason to use anything else.
post #7 of 19 (permalink) Old 04-20-2017, 10:49 AM
Depends whether you have a Base or a GT.
Mines a Base so I went with the GM OEM gear lube.
GT diffs require a gear lube with a modifier in it, again available at GM in an OEM.
After market gear lubes may not have this modifier in there formula.
I don't remember if the modifier is available on its own.
Can' remember weight either....yeesh....
post #8 of 19 (permalink) Old 04-20-2017, 11:38 AM
It is a GT, so ya modifier. Thanks for the quick response guys!
post #9 of 19 (permalink) Old 04-20-2017, 08:17 PM
Markmsf3's Avatar
Yes, use the AC Delco fluid. The plugs take a 8mm hex. Break loose the top fill plug first. They will be tight and it would suck to drain it and then not be able to get the fill plug loose. Did I mention they will be tight?
09 WH GT
Sport/Premium
Onyx/Red
Rotofab CAI
Cortex 93 tune
20% tint
I just wanted one.
Markmsf3 is offline
post #10 of 19 (permalink) Old 04-20-2017, 08:43 PM
While I followed this procedure when I changed my fluid a month or so ago (exhaust was dropped along with drive shaft since I was changing out the carrier bearing), I am curious to find out why. A vacuum?
post #11 of 19 (permalink) Old 04-20-2017, 10:34 PM Thread Starter
I'm just guessing, but I figure generally speaking you want to be sure you're going to be able to fill it before draining.
post #12 of 19 (permalink) Old 04-21-2017, 11:23 AM
Markmsf3's Avatar
I thought i was going to have to put the torch to mine, but was able to get a cheater pipe on the wrench and finally broke them loose along with some busted knuckles.
09 WH GT
Sport/Premium
Onyx/Red
Rotofab CAI
Cortex 93 tune
20% tint
I just wanted one.
Markmsf3 is offline
post #13 of 19 (permalink) Old 04-21-2017, 07:11 PM
GM fluid part number referenced, is that for a quart?
2009 MGM GT: VCM CAI, ARH LT headers (no cats), Vector Tune, MT drag radials
Procharger D1SC still powering the box it came in January 2010, hiding somewhere in the back of my man cave.
PB: 12.533 @ 111.45 w/ 1.951 60' CLAIMING THE INTAKE/LT/TUNE/DR RECORD
"There are but three true sports...mountain climbing, bull fighting, and motor racing. The rest are merely games." Ernest Hemmingway
TonyKarter is offline
post #14 of 19 (permalink) Old 04-21-2017, 08:22 PM Thread Starter
That is indeed for a quart. (A fraction more, actually)
post #15 of 19 (permalink) Old 04-24-2017, 11:09 PM
Anything else that we should generally take note of when we are changing out the fluid actually? Like should I be running the car off for a bit before attempting to put in the new stuff, or what's the best way to acclimatise the car once the fluid is it? Sorry for the Noob questions but just hoping to ensure I do the best I can do by my car when I attempt this.
webbrowan is offline
post #16 of 19 (permalink) Old 04-25-2017, 09:32 AM
I had my driveshaft (prop. shaft) and exhaust off when I did mine since I was working on some other stuff at the time. It's not necessary to remove them from what I've read.
I simply loosened the top bolt, then loosened and removed the bottom bolt and drained the fluid. I then put the bottom bolt back in, torqued it to spec., and then put in new GM fluid in the top bolt hole using a pump until it slowly leaked out. Then I torqued the top bolt to spec. and cleaned up.
http://www.harborfreight.com/multi-u...ump-66418.html
post #17 of 19 (permalink) Old 04-25-2017, 10:17 AM Thread Starter
They sell hand pumps that screw right onto the bottles, too. Kinda like a soap bottle pump.
post #18 of 19 (permalink) Old 04-25-2017, 12:46 PM
Belo's Avatar
what this guy said. pretty common pm in trucks and way too many guys find out the hard way especially on northern trucks that you better make sure you can fill it back up first before you drain it. Nothing to do with vac.
Belo is offline
post #19 of 19 (permalink) Old 04-25-2017, 04:17 PM
This is what I also used for topping up my Transmission. Worth while getting
GT Drew is online now
