transmission fluid change - Page 2 - Pontiac G8 Forum: G8 Forums - G8Board.com
post #21 of 57 (permalink) Old 12-26-2012, 02:27 PM
Plastidip is awful
If you guys are doing this yourself, make sure the car is level when you fill it and check it. When doing this at home with a jack, that means 4 jack stands and using a level on the transmission to make sure you've got all 4 corners at about the same height.
Otherwise buy the aftermarket Lokar dipstick for around $100 and you can just use that to check and fill. You would simply drain the fluid, put the bolt back, put the car back on flat ground, and use the dipstick. The dipstick must also be used with the car flat, but the advantage is that you don't need the car to be jacked up flat. Much easier. I know you said you don't want one... that's up to you. You'd have to buy another set of jackstands otherwise if you don't already have 4, and again, can be a pain to get the car jacked up and leveled on all 4 corners.
On some cars I have disconnected one of the lines between the transmission and the radiator, and extended one end into an empty bucket and the other into a clean jug of ATF. Then I just turn the car on until either the fluid dumping into the bucket starts looking new, or if I am about to run out of the new stuff. I've always done this with a second person at the wheel ready to kill the engine if anything bad happens. Fortunately I haven't gotten the hoses backwards yet. But I've only done this a couple of times so far. Of course I'd still recommend dropping the transmission pan and changing the filter, though (and yes, upgrading to the Camaro pan and filter is also a possibility). There are multiple ways to do that. You could try a pan drop, not adding fluid, setting up for this method and then you'd have to check the level and top off if necessary afterwards. That would waste the least amount of new fluid. But it's a bit more risky than sacrificing some new fluid when you pan drop. But you'll have to check the level regardless. Make sure to buy some extra ATF and set at least a couple quarts aside for topping off if necessary. Don't use all your new ATF in this home "flush" only to find that you're several quarts low. When operating this way, the system is obviously not sealed so there is not a guarantee that the fluid level won't change. So be cautious. This method has been VERY easy for me, but I have not done it in a G8 or anything very similar to a G8.
It's also a good idea to check the ATF again 1-2 more times after you check it initially and do some driving. Especially if you unseal the lines. Dipstick would be extra useful. I really recommend it. It disgusts me that GM doesn't add one. It's not because the system is magically more reliable than older transmissions with dipsticks. It's solely a cost-saving measure (well, and possibly one of those moves they made to try and curb third-party/home repairs and get more people to pay for dealer service, but I can't prove that). There are no lifetime fluids in cars from the consumer's point of view. A "lifetime fluid" in OEM speak means 100k miles.
BTW, if it interests you at all, Amsoil makes compatible ATF for our cars.
dandragonrage is offline
post #22 of 57 (permalink) Old 12-26-2012, 02:32 PM
every village has one
tchr49's Avatar
Originally Posted by todds87ss View Post
you have not tried it, have you?
A flush does not change the filter. For the price of a dealer flush, you can get the camaro deep sump pan and filter (PACE), buy the 8 quarts of synthetic fluid, and still have enough for a six pack of beer.
"couple of quarts..." hmmm...
And good beer at that...
e85 Surprise Package
tchr49 is online now
post #23 of 57 (permalink) Old 01-20-2013, 02:29 PM
RJKmotion's Avatar
My mechanic is gonna flush my trans in the next couple of months. I see people mentioning the camaro trans Pan and filter. Does anyone happen to have part numbers for these and has anyone put it on a gxp??
Sent from my iPhone using AutoGuide.com App
RJKmotion is offline
post #24 of 57 (permalink) Old 01-20-2013, 02:32 PM
RJKmotion's Avatar
How would this work on our trans if they are self sealed? What line would u disconnect so it could suck in the new fluid and push the old stuff out?
post #25 of 57 (permalink) Old 01-20-2013, 02:33 PM
Super Moderator
Troy Trackbeast's Avatar
Troy Trackbeast is offline
post #26 of 57 (permalink) Old 01-20-2013, 04:26 PM
RJKmotion's Avatar
Originally Posted by Troy Trackbeast View Post
Gmp-24250062 - $65.95
Is this for the camaro pan? Any number for filter? Does it fit on a gxp?
post #27 of 57 (permalink) Old 01-20-2013, 04:54 PM
Everything you need to know right here about 24250062
ICOM 208H
<img src=http://www.g8board.com/forums/signaturepics/sigpic9701_2.gif border=0 alt= />
JCMG8 is offline
post #28 of 57 (permalink) Old 01-20-2013, 07:10 PM
Camshaft Master
Its a dealer "have" to type of thing. There's a specific way to flush this unit, at least according to GM. I'm alittle over 60k, and its a 60k maintance item... I'm too still looking to get more information, as my buddy is a GM Tech. I'm waiting to get a stack of information about routine maintance things to do.
DDTECH -Custom Cams/Tuning/Engine building
DDTECHCAMS.com
Custom Camshafts, VTEC Killers, and Rollers for your Honda
08 G8 GT - Daily 13.5@107mph 2.0 60'(STOCK)Its got some mods now.... And tuning.
92 EG Civic - Racecar - Trapping 115mph+(NA)
DDTECH is offline
post #29 of 57 (permalink) Old 01-21-2013, 12:00 PM
HPT Pro Tuner
bluegoat06's Avatar
I had my fluid replaced at 74k miles when i did my converter, find a reputable trans shop (assuming you can't do this yourself), that know about the 6l80e trans, and ask them to check/change the fluid for you. It would be cheaper than what the stealer will charge you, unless the dealer has a coupon that would make the price attractive.
There are also more transmissions out there that would requiere the same filling/check procedure, so trans shops should know what do, i gave my trans shop the details about the temp just in case, but they knew the trans either way, so it was more for my own piece of mind to know they had the correct procedure at hand. Again, make sure they know the trans, you'll be surprise how many shops have no idea about the trans when you ask them specifically about it. Dealers would also have this info at hand straight from GM.
Some people reuse the filter, but you can get the filter, and the gasket for cheap online.
I just bought the Camaro pan, filter, gasket from Pace, since i was doing the verter, and the parts were very cheap (about $80 shipped to my door), , so i figure the stock trans gasket and filter should be cheaper than the Camaro pan with all the parts, although not sure about that.
My trans fluid was still decent looking at 74k miles, the guys at the shop saved the old fluid to show me, and they said it was in fairly good shape compared to other fluids from other car brands with about the same mileage. I wouldn't have had any issues letting my trans go all the way to the 100k miles mark from GM, so that was a good thing.
I'll use the same shop again the next time i need to replace my trans fluid, and i'll probably get at least a new gasket, assuming the filter can be reused at least once.
2012 Mustang GT, M6, 3.73's, Base/Brembo Package
3" H Pipe/Stock cats, Res!/3" pipes, Magnaflow 14419's AB, UPR Catch Can
HPTuners Pro v2.25 | Street Tuned
2010 Silverado 1500 LT Crew 5.3L
Magnaflow 14619, K&N Drop Filter, Airraid MIT, UPR Catch Can, American Outlaw Deputy 17x9, BFG 285/70/17 TKO, Bilstein 5100's
Hptuners 2.24 Pro / Street Tuned
bluegoat06 is offline
post #30 of 57 (permalink) Old 01-23-2013, 12:26 AM
RJKmotion's Avatar
Do you have a link to the procedure and temp??
post #31 of 57 (permalink) Old 01-23-2013, 05:12 PM
HPT Pro Tuner
bluegoat06's Avatar
See post#5 here for example
Is It a Transmission Drain Plug or Level Check Plug
post #32 of 57 (permalink) Old 07-25-2013, 08:37 AM
Dictatorsaurus's Avatar
The cheapest quote I've gotten to flush the fluid and replace filter in NJ is $250 which is pretty high.
Any recommendations for a decent shop in the Central NJ area?
Dictatorsaurus is offline
post #33 of 57 (permalink) Old 07-25-2013, 07:10 PM
aussiek2000's Avatar
I talked to a tech from another forum. He suggested this dealer.
Perrine Buick GMC
2730 U.S. 130
Cranbury Township
(609) 395-5599
2009 PSM GT Sport/Premium
aussiek2000 is offline
post #34 of 57 (permalink) Old 07-25-2013, 09:12 PM
markco33's Avatar
I had my trans service done at 60,000 miles and my diff fluid at 50,000 miles
Pedders street II kit daily driving, BMR tunnel brace, AEM air intake tube, AFE air filter, Custom airbrush hood liner, Axle back GXP mufflers and flaspaq 93 tune
markco33 is offline
post #35 of 57 (permalink) Old 07-26-2013, 06:12 AM
Perrine Buick GMC
2730 U.S. 130
Cranbury Township
(609) 395-5599
Great dealer I got my car there and I been there a few times for warranty work. service was good and the people were very nice they love my car lol
http://www.g8board.com/forums/signaturepics/sigpic4288_1.gif
Kooks long tubes, Kooks axle backs, rotofab cai, ported tb, koni yellow shocks, h&r springs, bmr bushings kit, rear toe and traction arms. Bmr sway bars. forgestar f10 20x9.5 35 offset 275/30/20, 20x10.5 42 offset 285/30/20
hayabusa160 is offline
post #36 of 57 (permalink) Old 07-27-2013, 07:28 PM
GMCustomerService's Avatar
Great to hear, hayabusa! If you want for us to pass along your compliments, please contact us via private message with your VIN and contact information.
Sarah (Assisting William)
GM Customer Care
GMCustomerService is offline
post #37 of 57 (permalink) Old 07-30-2013, 03:02 PM
Drives with wolves
Silvereagle's Avatar
I had my tranny fluid exchange exactly @ 50k miles (not flushed) 2 weeks ago, and the tranny seems absolutely "refreshed" from it. AND it it was done at my local GM dealer for $65.00
2009 G8GT - premium and sport package - PSM 1 - of 1063. Magnaflow catback 16887, Rotofab, VVME HID 6k, Cortex Rotofab 87 tuned, PPV-struts, Monroe front bearings, Folcik A-C controller + Pioneer ACH4000NEX Carplay
Silvereagle is offline
post #38 of 57 (permalink) Old 07-30-2013, 03:23 PM
dogcat's Avatar
That's amazing. My filter was $15 and the 12 quarts of synthetic fluid was almost $100. I did mine at 25k, along with the addition of the Camaro pan. It made a noticeable difference.
GXP, 223/230 .634/.609 114+3, BTR .660 springs, BTR 7.425 rods, IWIS Pro Chain, Comp Rocker Trunions, VCM OTR CAI, Kooks 1 7/8 LTs, HF Cats, X pipe, Solo Axelbacks or Hooker Maxflows, Billet PCV catch can, CTS-V rear calipers. Updated GM trans mount, Camaro trans pan, HSRK w/ Omega 44005 Thermistor, BMR Rear Cradle bushings, BRM Trailing Arms, Pat G tune.
20% 3M CS tint, Kicker 8's, Rockford Fosgage T1D210 in sealed box, 1,000,000 uF Cap, Kicker 1000W amp, tons of Dynamat
dogcat is offline
post #39 of 57 (permalink) Old 07-30-2013, 06:35 PM
Some sort of special? I pay 10% over cost, and think I paid more than that for parts. $48 for fluid ($4x12) and ~$20 for the filter.
post #40 of 57 (permalink) Old 08-01-2013, 02:29 PM
Perrine Buick GMC
2730 U.S. 130
Cranbury Township
(609) 395-5599
Perrine quoted me $425 for fluid flush and filter change. What a rip off!
