HSV logoed camaro brembos - Pontiac G8 Forum: G8 Forums - G8Board.com
 16Likes
post #1 of 50 (permalink) Old 03-13-2017, 09:49 PM Thread Starter
mustangmoser's Avatar
Talking HSV logoed camaro brembos
Just showing off...please don't drool on the paint fellas
cheerguyhpu likes this.
Holden SSV SE conversion
Pacesetter long tubes
Vararam OTR intake
Cortex 93 tune
Brembo 4 pot front and rear
Factory Bluetooth retrofit
mustangmoser is online now
post #2 of 50 (permalink) Old 03-13-2017, 10:54 PM
L_Alvis's Avatar
Nice! Did you use anything to protect the decals? Here's mine and so far the sprayed clear enamel has kept mine from getting damaged.
BTR Stage 2 Kooks LTs SLP Powerflo 3.27 Rear
6/4-pot Brembos TSW Nurburgrings
L_Alvis is online now
post #3 of 50 (permalink) Old 03-14-2017, 04:59 AM Thread Starter
Painted, applied decals, clear coat on top
Vararam OTR intake
Cortex 93 tune
post #4 of 50 (permalink) Old 03-14-2017, 05:27 AM
G8GTLVR's Avatar
Nice. Question; are those the 4 piston Brembros? Looks like they just barely clear the main spokes of the front wheels; did you need to use a spacer to get them to clear? I am thinking of upgrading my fronts to Brembros.
2006 GTO
G8GTLVR is offline
post #5 of 50 (permalink) Old 03-14-2017, 07:29 AM
You can see the spacer in the first photo.
post #6 of 50 (permalink) Old 03-14-2017, 07:34 AM Thread Starter
It's a 1/4 spacer, the rears did not need a spacer using the ss sedan rotor
Vararam OTR intake
Cortex 93 tune
post #7 of 50 (permalink) Old 03-14-2017, 09:14 AM
I would use a hub-centric spacer...
post #8 of 50 (permalink) Old 03-14-2017, 09:52 AM Thread Starter
Thanks for the advice, but when I can make something that's a fraction of the cost work perfectly then I'm going to. And no I don't have a wheel balance issue with my spacers, all u have to do is center it.
Vararam OTR intake
Cortex 93 tune
post #9 of 50 (permalink) Old 03-14-2017, 11:03 AM
And that's the problem. Each time, you have to center it. Also, the stress is also being moved from being on the hub (where it's supposed to be) to being on the wheel studs.
A hub-centric spacer will sit on the hub, perfectly, and will also have its hub extended a bit since your wheels mount onto the hub.
Good:
Bad:
Hubcentric Explained | Superforma Ltd
Just something to think about...
MGMGXP likes this.
post #10 of 50 (permalink) Old 03-14-2017, 11:43 AM Thread Starter
I'm fully aware of how a hub centric spacer works and the merits of such a piece, and if i could have bought one for a reasonable price i would have. However I'm also fully aware that you cannot point to a single time where a stud broke due to a wheel not riding on the hub.
Now please quit with the thread hi jack, there are plenty of other threads that speak to the hub centric vs standard spacer debate.
Vararam OTR intake
Cortex 93 tune
post #11 of 50 (permalink) Old 03-14-2017, 12:15 PM
Can you tell a big difference in stopping power, braking distance?
blackg8smatter is offline
post #12 of 50 (permalink) Old 03-14-2017, 12:17 PM
You're the only person here that brought up a broken stud as a potential failure.
But whatever works for you price-wise. Which I find rather ironic since you spent good money on those rotors, calipers, paint, and install when all of those were adequate prior (OEM brakes). But then decided to forgo on getting the correct spacers. But hey, it's your 4,000lbs car, not mine. If it works for you, I'm happy. Nice HSV decals as well.
@G8GTLVR , do yourself a favor and for peace of mind, avoid the Mickey Mouse universal spacers and get some hub-centric spacers. The peace of mind alone is worth it. Not to mention the reinstall every time you have to dismount and mount the wheel to the car and having to worry about aligning the spacer.
MGMGXP likes this.
post #13 of 50 (permalink) Old 03-14-2017, 12:20 PM Thread Starter
Lol gxp guys = cobra guys in the Mustang world
Vararam OTR intake
Cortex 93 tune
post #14 of 50 (permalink) Old 03-14-2017, 12:31 PM
How many turns of the lug nut do you have with the 1/4" spacers? That's getting a little thick without the use of longer studs IMHO.
https://www.tirerack.com/wheels/tech...jsp?techid=99&
Jeff92se is offline
post #15 of 50 (permalink) Old 03-14-2017, 12:36 PM Thread Starter
Factory stud it was only a couple of turns, lug stud 610-490.1 is what I used, had to cut off the ends a bit to allow the lug nut covers to fit
Vararam OTR intake
Cortex 93 tune
post #16 of 50 (permalink) Old 03-14-2017, 01:08 PM
Great info! That's as informational as the following link I posted above on what not to do and what to look out for. Though I'd be concerned about a "couple of turns" (2 turns) since your link clearly mentions a minimum of 6.5 turns depending on the "Size of Bolt or Stud."
Hopefully changing out studs can be done at a reasonable price...
post #17 of 50 (permalink) Old 03-14-2017, 01:16 PM Thread Starter
Ok, everyone knows that hub centric is better, I'm not arguing the merits of that, but for those of us who for whatever reason choose to run a standard old school wheel spacer, they work, and they work well, as I've proven on my own vehicle. There is a difference between better and required, are hub centric better? Sure. Is my wheel going to vibrate out of my hand if I use standard? No. Again, my car, my decision, and no one is in danger due to my old school wheel spacers
This was simply a thread to show something that I've not seen in the countless brake swap threads I've read through, hsv logos.
BlueG8GT likes this.
Vararam OTR intake
Cortex 93 tune
post #18 of 50 (permalink) Old 03-14-2017, 01:17 PM
Lolgxp guys = cobra guys in the Mustang world
So you're saying Cobra owners like to modify their cars the safe and correct way? Are the GT drivers the ones who keep crashing and running over people then?
GXP25 and MGMGXP like this.
MGM GXP - M6, Sunroof, and a whole lot of fun
Omega is offline
post #19 of 50 (permalink) Old 03-14-2017, 01:20 PM Thread Starter
Lmao yes sure that's exactly what I'm saying
Vararam OTR intake
Cortex 93 tune
post #20 of 50 (permalink) Old 03-14-2017, 01:42 PM
They look great and the fact that you clear coated over them means they should last plenty long. What type of clear coat did you use?
