12 volt power outlet ground? - Pontiac G8 Forum: G8 Forums - G8Board.com
post #1 of 3 (permalink) Old 12-07-2012, 09:03 AM Thread Starter
cstmg8's Avatar
I have already securely grounded the cigarette lighter outlet, but I am still getting some feedback when I watch video on my head unit. I think I have possibly traced it down to a bad ground connection on my adapter, which is the ground, the end of the adapter or the springs on the sides?
Sent from my DROID RAZR using AutoGuide App
09 panther black G8 GT
Show:19x9.5's rear w/rolled fenders, 18x9.5's front, 20% tint, trim/lense tint in progress, sub rewire, amp adj, VIM w/ dvd in gb, interior blackout in progress.
Go: spectre, hsrk, lpm, pacesetter LTs, full 2.5" cat/mid/res delete, flowmaster ABs, INTENSE tune.
97 Red GP GTP- ECM, headers, custom exhaust, ported blower, heads, TB, CAI, etc....... sold
91 GP GTP- L67 swap, tranny, headers, exhaust, ECM, and a few more.... ;-) sold
cstmg8 is offline
post #2 of 3 (permalink) Old 12-07-2012, 09:51 AM
The sides. Or you can use nearly any exposed (non-painted) metal surface as the ground.
'09 G8 GT, Liquid Red, Premium, Sport
amfarthing is offline
post #3 of 3 (permalink) Old 12-07-2012, 11:34 AM
There's a bolt that's already being used as a ground on the right hand side of the center stack behind the passenger side triangle trim piece. You can loosen that up, slip your ground wire in, and tighten back down for a solid ground. Or put a grommit on your wire and loop it around the bolt.
Ground Loop Isolator circuits on the RCA side sometimes fix the alternator whine also.
good luck!
Livernois tune, VCM, FE3's, Blue gauges, iphone on display. Daily Driver FTW
