N/A time slips in here. - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > Racing > Drag Racing
Old 11-14-2012, 02:32 PM   #1
blubyya
blubyya's Avatar
Default N/A time slips in here.
I'm wanting to know whose got the quickest N/A stock cubic inch car? Anyone under the 12s please chime in.
Dctg8
60ft. 1.62
330. *. **
1/8. *. **
1/4. *. **
Mph. 120
Time. 11.45
E/t. *. **
2008 gt, lsa 9psi, meth, rcr blower cam, Lingenfelter ls3 heads, ls7 maf, crawford tb, kooks headers &mid pipe magnaflow mufflers, spohn toe & lowers
10.38 130mph 1.56 60ft PB
11.29 122pmh 1.67 60ft (old n/a setup)
blubyya is offline   Reply With Quote
Old 11-14-2012, 02:45 PM   #2
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
I have been 11.65 @118.55 and 11.69 @119.2 two seperate weekends, DA +500/+600
2600 stall, DoD cam, 1.85 rockers, H/C/I, 3.45 gears, Headers&exhaust, full street trim and street tires. With drag radials I am sure it would go 11.50's if I could get the 60 ft in the 1.60's. Went 1.7X's with street tires prepped.
2009 G8 GT- Rick Crawford
1.50 60ft, 10.41 @ 131.4 Comp 234/243 111+0 6.4 N/A
1.53 60ft, 10.59@ 129.7 ALL MOTOR!!! N/A G8 Record Holder
G8-4-Speed is offline   Reply With Quote
Old 11-16-2012, 03:00 PM   #3
blubyya
blubyya's Avatar
What would you say your HP Is at?
Old 11-16-2012, 03:21 PM   #4
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
That would depend on the dyno. 420-460.
Old 11-16-2012, 03:35 PM   #5
orangeg8
Offshore Prositute
orangeg8's Avatar
I ran 11.8@120mph with a modded LS3 (my L76 got destroyed) I put down 435rwhp. This was with 3.27 gears also. So basically a gxp powertrain without the suspension setup. Looking to go 11.6 or 11.7 now with coilovers and anew cam (broken lifter took out cam).
Don't complain about life, if you do, try death, nobody has complained yet.
I am no Challenger to this game, I don't go Chargering away, and it is more than just ponies in this beast.
orangeg8 is offline   Reply With Quote
Old 11-16-2012, 07:47 PM   #6
gtp6515
gtp6515's Avatar
Dumb question potentially, but does suspension affect 1/4 mile time? I am all stock except trailing arms.
219/223 .625 .625 112 "Little Lunati", 11.78 @ 119, 440/421 dynojet, Crawford heads, tb, intake. Kooks 1 3/4 lts and solo Mach balance catted with added Solo resonators, VCM, 3.45's, stock stall.
gtp6515 is offline   Reply With Quote
Old 11-21-2012, 08:12 AM   #7
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
Nothing until the 60ft starts getting fast..... My G8 suspension is all stock....
Old 11-21-2012, 08:22 AM   #8
blubyya
blubyya's Avatar
I got to get me some radials. I've yet to get my 60 below a 1.9 spins like crazy. I'm positive I have a 11.5 pass in the car. It made to much not to And a lot of torque
Old 11-21-2012, 04:12 PM   #9
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
Spinning or not, that mph needs to be 116 for what you have. Even if you spin out of the hole and the shifts your mph should be better.
Old 11-21-2012, 04:33 PM   #10
blubyya
blubyya's Avatar
If you are referring to the time in my sig, then that is my old motor. I make 60-70 more hp and a crap load of torque. So that's why I think I should be able to pull a 11.50
Old 11-21-2012, 04:53 PM   #11
fixem2
Rick,
What tires are you running on your street tire runs? Need to start researching new rear tires!!
2008 White G8 GT
Kooks 1 7/8 Long Tube Headers, Kooks Catted X-Pipe, Kooks Catback Exhaust with single 3" tips, SLP UDP, Volant CAI & AMSOIL filter, BMR stuff
351hp / 370tq via Dynojet (Before 2012 changes)
2012 changes - Yank Converter, DSS 1 piece Driveshaft, Forgestar F14 Staggered
AMSOIL
fixem2 is offline   Reply With Quote
Old 11-21-2012, 04:58 PM   #12
1gr8ate
1gr8ate's Avatar
Went 12.3 stock stall stock cam stock gear with 285/30/20 on camaro wheels 1.9 60'
1gr8ate is offline   Reply With Quote
Old 11-21-2012, 07:19 PM   #13
dctg8
dctg8's Avatar
I ran the PB in my sig on a warm day. Cooler day I hope to hit 11.5 - 11.6.
D1sc, Meth, Cts-v fuel pump, 223/235 cam, RCR Heads & intake, obx 1 7/8 headers, custom Corsa axle backs, Circle D 2800, 305/35/19 DRs, and more mods that I can't remember.
Dyno #s TBD
D1sc Best 6/6/14 *hot & muggy*
10.63 @ 132 w 1.69 60ft
P1sc Best 11/24/13
10.36 @ 133 w/ 1.51 60ft.
N/A PB 1/05/13
11.45 @ 120 w/ 1.62 60ft.
dctg8 is offline   Reply With Quote
Old 11-21-2012, 09:39 PM   #14
MGM GT
MGM GT's Avatar
Stock G8 GT cubic inches NA I went 11.31
Bone stock G8 GT block with only boltons landsarmstrong went 11.95
Those are the two fastest times I know of for cam/heads and boltons for the 6.0L.
Just another 9 second family car...
Capital City G8 Club /// DriveShaftShop /// Powerhaus Performance
MGM GT is offline   Reply With Quote
Old 01-03-2013, 04:38 PM   #15
48sucks
I can tell you right now that 11.31 time N/A stock cubes is going to be hard to beat! Best I have been able to do is 11.8 with a 1.6 60'. Since then discovered the top end was trashed (bought the car already built). Had the whole top end rebuilt plus had the heads done and installed one piece driveshaft and 3600 circle D triple disk stall. Was still stock bottom end. Went to Commerce Dragway to see what she would do and cylinder 7 broke due to rod bolt stretching at 1/8 mile. How do I know that is when it happened, because that is when it started backfiring bad. Rebuilding bottom end now, all forged to hold a lot of horsepower.
Bottom line, I believe 11.31 N/A stock cubes is going to stand for awhile. To get this car to hook on even drag radials is tough on these bad prepped tracks!
Just living the dream! Building a G8 GXP with a big naturally aspirated full weight loud pedal my uncle in heaven would have been proud to be a passenger in. Spartan Performance Built!
48sucks is offline   Reply With Quote
Old 01-03-2013, 04:47 PM   #16
Troy Trackbeast
Super Moderator
Troy Trackbeast's Avatar
might go down this weekend. Me and dctG8 (dustin) are going to to the track on Saturday. He will be kicking it in the ass that's for sure. We are looking at mineshaft air Saturday, so a great DA is on tap. He will also be testing out his drag pack for the first time. Last time he went 11.5 so it should be interesting...
Troy Trackbeast is offline   Reply With Quote
Old 01-03-2013, 04:57 PM   #17
48sucks
Good luck. Hope you have good air and good track prep.
Old 01-03-2013, 09:04 PM   #18
dctg8
dctg8's Avatar
Cleaning the car out tomorrow and putting it on a diet. we shall see what this great air does. Troy no less than an 11 sec for your pb!
Dyno #s TBD
P1sc Best 11/24/13
N/A PB 1/05/13
Old 01-05-2013, 10:42 AM   #19
blubyya
blubyya's Avatar
Post up yalls, results that way we can get something started far as far as official times and mph.
Old 01-05-2013, 10:46 AM   #20
gardnertroy
gardnertroy's Avatar
I'm in there.
RCR 223/231 111+0
RCR heads
RCR ported intake/TB
Kooks 1 7/8 LT's.
Kooks x pipe
Magnaflow axle back
Vararam / RCR Ram Plate
Airaid 4" housing/ ls7 Maf
Slp pulley
Fe3/BMR
Yank SS4000
3.45 gear
Drag pack
Crawford tuned
N/A pb
11.15@120 1.48 60ft
gardnertroy is offline   Reply With Quote
