Widened GXP Wheels with 295/30/19 Tires - Page 5 - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Wheels / Tires
Wheels / Tires Sponsored by: Discount Tire
Old 06-12-2012, 03:48 PM   #81
ottw
ottw's Avatar
305's will fit lowered but you need inner well work.
2009 GXP White A6 Roof Onyx/Red, 619 , Magnacharger 2300, BAP Fuel Sys, CNC Heads, Stage 2 Cam, Kooks Hdrs & Cats, Corsa Exhaust, Livernois Dyno Tune, Roto-Fab CIA, Mini Tubed R Wheel-wells, Cut & Welded Wheels 9" Fr, 10.5" R, 265/35-19" & 305/30-19" Pilot Sport PS2's, Dark Window tint, BMR: Tnl Brace, S Frame Connectors, Trailing Rods, Bushings, Toe Rods, sway bars, DBA Slotted/Drilled 5000 rotors, Sphon LCA's, Pedders subframe bushings, Pedders fr control arm pkg, Supercar Coilovers.
ottw is offline   Reply With Quote
Old 06-12-2012, 06:25 PM   #82
TyG8GXP
TyG8GXP's Avatar
Originally Posted by Bill in pgh View Post
Sorry I missed this post and to clearify the tires rubbed on the outside. My mistake was the 2" widening and installing the 1 1/4 spacer. Should have widened 1 1/2" with a 3/4 spacer. I put stock wheels back on the car and sold it to buy a GXP. After reading this thread I think I will be safe to widen the stock GXP wheels 1" and run 275's or 285's with no spacers. 04GT does this sound correct. I would like to get as wide as possible with no spcaers or adapters.
1" and a 275, I THINK you should be ok.
Damn. Your GXP looks killer!
2009 M6 G8 GXP - Sold
710rwhp/742rwtq
TyG8GXP is offline   Reply With Quote
Old 07-02-2012, 06:12 PM   #83
soup070
soup070's Avatar
04GT what was the true width of the spacers you used? Somehow I couldn't find them, I need a set of spacers for my stock wheels during winter to use Brembos and wondered what thickness I could use. On ebay there's a set of 20mm or 15mm 5x120 14mm 66.9 hub spacers, just wondered which one.
Saw you still have the Corsa, have to meet upsome time and checkout my HSVs.
2009 Voodoo Metallic Blue G8 GT
1 of less than 1,111
Premium/non-Sport & no-roof, Vararam OTR, V6 Radiator Cover, Corsa CB, RoyalPurple,
LLumar Ceramic Tint 40/30/15, 3400k HIDs, Pontiac cargo tray, 18" Drag-37 wheels,
BMR Sways, HSV Engine Cover & Clubsport Wheels, Yellow +09 CTSv Brembos,
Kooks Mids w/Pat G Tune
5 Year Plan: 3.27 Dif, HSV Front Guards & Flutes, E3 front bumper
soup070 is offline   Reply With Quote
Old 07-02-2012, 09:39 PM   #84
BigZub
BigZub's Avatar
I widened my GXP wheels 1.5", and got some 285/35-19's for the rear.
When I went to install them, they cleared the inside and outside OK, but the wheel was contacting the Spohn LCA!! Glad we noticed it before we rolled it.
I ordered the MotorSports Tech adapters, 3/4", correct hub-centric, and spec'd the M14x1.5 studs. Went to put them on today, and found that the lugs they supplied are not cut at the same angle as the adapters, so they don't fit flush. I sent an e-mail to them to ask what the solution should be.
It kind of pisses me off that they would send them out like this. I don't mind having to cut the original studs to add clearance for the wheels, but to not have the lugs fit flush? C'mon, man!
I'm going to hit the Fastenal tomorrow to see if they have anything that can work. If not, to the machine shop the adapters go, to have them countersunk to the correct dimension and angle.
I also bought an Eastwood fender roller, and rolled the fenders tonight. Pretty easy!!
'09 Pontiac G8 GXP, A6, Sunroof, MGM, #1664 of 1829
GMM RAMJET OTR CAI, Livernois E/TCM Tune, Kooks 1-7/8" LTs, catted mid-pipe, Hooker Polished SS MaxFlow mufflers - 394RWHP/386RWT
BMR Rear LCA's, stabilizer bars, end links, front LCA bushings, rear toe links and trailing arms, Pedders Street II kit, including subframe and diff bushings.
Hawk Ceramic pads, Brake Performance slotted and dimpled rotors, Russell stainless lines, Super Blue fluid.
Best 1/4 time - 12.52 @ 114.47, 1.94 60ft.
BigZub is offline   Reply With Quote
Old 07-03-2012, 12:22 AM   #85
ottw
ottw's Avatar
Itís easiest if you just modify the LCA's
Old 07-03-2012, 09:14 AM   #86
BigZub
BigZub's Avatar
I had thought about doing that, but that means pulling the rear suspension apart again. I have the proper cutting tools for it, but not a welder, and would also have to find a place to re-powdercoat them.
Not sure how that is easier, but it is an elegant solution.
Old 07-03-2012, 09:20 AM   #87
dblaron
Super Moderator
dblaron's Avatar
I'm sad to hear about your experience with Motorsport tech. I have bought spacers/adapters from them in the past and had a good experience. Good quality and good service. I actually have recommended them to a few people. I am going to follow your progress closely, if their qualit has changed I'd like to know. Good luck, let us know what happens.
2009 GT Prem. Sport. Sun Roof.
Paddle Shifters, BMR Sways, Eibachs, Koni's, Brembos, 3.45s, LS2 cam, 918 springs, 1.85 rockers, Spectre CAI, Rick C Intake/TB/heads , LS7 MAF, Custom Axle Backs, JBA LT's,
Currently Installing RCR 215/223 .609. 615 114+1
Pat G Tuned.
12.23 @ 113.7 mph 1.98 60' 1,000' DA
20X9-35 TSW Nurburings 255/35 Cooper RS3-S
dblaron is offline   Reply With Quote
Old 07-03-2012, 09:35 AM   #88
TyG8GXP
TyG8GXP's Avatar
I bought the Motorsports tech 3/4" adapters.
Yup, still have and love the Corsa. Hopefully us STL guys can get a meet together soon.
They sent me wrong sized nuts. They didn't fit over both the stock studs, or the adapter studs (same size anyway). Ended up having to buy new ones from a local ace hardware.
710rwhp/742rwtq
Old 10-11-2012, 07:51 PM   #89
Fast GTO
Would widening 1" allow you to run 285 without adapters and stock suspension?
Fast GTO is offline   Reply With Quote
Old 10-11-2012, 08:29 PM   #90
TyG8GXP
TyG8GXP's Avatar
Couldn't tell ya for sure. It all has to do with backspacing. I think even if I did a 1", I think just for aesthetics, I would have run an adapter so the wheels sit flush with the fenders.
710rwhp/742rwtq
Old 10-11-2012, 08:55 PM   #91
Fast GTO
Well looks like you had some clearance with 1.5" and 295's so I'd think 1" wider and 285/75 should work.
Old 10-12-2012, 12:22 PM   #92
BigZub
BigZub's Avatar
I finally had the time to get the wheels on about a month ago. I ended up buying new lug nuts for the adapter that had the correct seat angle, then ground them down with my belt sander so they would fit flush. Everything fits good, and it looks nice! I'll try to get some pics soon.
I have a little rubbing when hitting large dips, with something in the trunk, but not bad.
Old 10-13-2012, 06:51 PM   #93
blzngto
in the market...
blzngto's Avatar
That has got to be the best looking gxp on the forum imo. The stance, the offset just do it for me I'm all about less is more.
blzngto is offline   Reply With Quote
Old 01-06-2013, 02:23 AM   #94
MIEngineer
Ottw - anymore pics? Interested in what you did for the mini tubs!
2014 Chevy Cruze
2013 Chevy Avalanche
2009 Pontiac G8
2009 Saab 9-3 Combi
1988 Volvo 740
MIEngineer is offline   Reply With Quote
Old 01-06-2013, 11:54 AM   #95
ottw
ottw's Avatar
The last two show the stock wheel well and one with the inner liner trimmed so you can see how much room was made. Note things like the gas line is moved and the spring tower is trimmed and the seam has been removed and welded.
Old 01-06-2013, 05:56 PM   #96
mlittleton
Mack
Sick! Needs a drop though
2008 Pontiac G8 GT: 10.928 @ 125.840 MPH 1.52 60' - Fayetteville Motorsports Park, NC
2008 MGM G8 GT | 20" Forgestar CF5's | 20x9 et.38F/20x10 et.45R | NT555 265/35/20F | NT05 305/30/20R | SOLO Mach Balanced | Kooks LT/SOLO HFC Connections
Rick Crawford Racing 6.6L stroker build | RCR Spec'd Lunati Cam @223/232 .615/.598 | RCR Heads TB/Intake/Tune | VCM Intake | Camaro 3.45's | LS7 MAF | Coan 3200
mlittleton is offline   Reply With Quote
Old 01-07-2013, 07:11 AM   #97
TyG8GXP
TyG8GXP's Avatar
I would love to, but my piping for the turbos is way too low already at stock ride height. If I ever get them re-routed, I'd be able to, but no way can I lower it the way it sits now.
710rwhp/742rwtq
Old 01-08-2013, 01:10 AM   #98
BlackBeast
Looks great!
So the rims are now 9.5" wide with 295 tires?
I have 9.5" rims with 285's and up for tires... Wondering how much lip 295's would have.
Black 09 G8 GT, Premium and Sport Packages
Mods: VMS Tune, Kooks 1 7/8" Mids, Solo Mach Balanced w/3.5" tips, Vibrant 12" Resonators, Roto-Fab CAI w/HSRK, BP Catch Can, Lowered on Eibach's, Radiator Cover, GXP Diffuser, CTS-V front & rear brakes, Matte Gunmetal 20" Nurburgring, Michelin Pilot Super Sport 255/35 - 295/30, MaverickMan Carbon Spoiler and Grille Surrounds.
Dyno: 337HP 349TQ
BlackBeast is offline   Reply With Quote
Old 01-09-2013, 08:43 AM   #99
TyG8GXP
TyG8GXP's Avatar
Originally Posted by BlackBeast View Post
Looks great!
Yup.
9.5" wheels with 295 tires.
710rwhp/742rwtq
Old 01-09-2013, 07:45 PM   #100
kirkby
1stOrangeinTexas
BTW, what offset do you think they measured at after the widening? Thanks..-Ken
kirkby is offline   Reply With Quote
Copyright ©2007-2008, G8Board.com
