The Mysterious Rick Crawford... - Page 2 - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Intake/Fuel Tech
Intake/Fuel Tech CAI, TBI, Porting, Forced Induction, Nitrous Oxide...
Closed Thread
Old 01-23-2013, 03:06 PM   #21
GXPaycheck
GXPaycheck's Avatar
Originally Posted by gr8lover View Post
hmmm...... I think this answers how he gets cars to go so fast..... quite possibly swapping some parts for parts..... tricky!!!! psst.... we wont tell anyone else...
I can't wait for him to do the Hover Mod on mine
RIP Charlie, The GRRRR8 One
2009 G8 GXP, #715 0f 1829 (one of 38 as optioned), Magnetic Silver, 6M, Sunroof, Onyx/Red
VCM, Magnaflow axle-backs, WAMS IWM/VIM, Back-up camera with JHP autoswitch, Homelink by Snakey, Pedders bushings
2014 Chevy SS, Mystic Green, roof. One of 144
Forum junkie at the G8Board and "The G8 Forum That Shall Not Be Named"!
GXPaycheck is offline
Old 01-23-2013, 03:16 PM   #22
Pakitullanc
Pakitullanc's Avatar
Default Re: The Mysterious Rick Crawford...
Originally Posted by Zodiac View Post
Lmao
Sent from my Inspire using Autoguide.com
2013 Buick Regal GS stock with every option possible.
09 GT LR.....(SOLD)
Pakitullanc is offline
Old 01-23-2013, 03:19 PM   #23
Roadcone
HeapBlaster
Originally Posted by G8-4-Speed View Post
I am only mysterious because if I make it out of my shop its like a BigFoot sighting. Try a google search with my name and throw intake in with it....
i tried that and found a bunch of people who said they had one of your intakes... no one was specific about what that meant tho. i just assumed you were modifying parts from the space shuttle program to fit the LS3 based on how people were praising you. I'm not far from you in Greenville, SC
2009 G8 GXP M6 - Katech LS9R Clutch, SLP LTs w/ !cat, Magnaflow X-pipe added, OBX-R axleback, VCM OTR Intake, Powerbond 25% UDP, Taylors 10.4mm wires, SLP 160* TSTAT
Roadcone is offline
Old 01-23-2013, 03:42 PM   #24
Troy Trackbeast
Super Moderator
Troy Trackbeast's Avatar
Maybe this helps... Here is an exert from Rick from the following thread:
http://www.g8board.com/forums/showthread.php?t=66163
Its best to have all your mods ready and have it tuned once. Gears, stalls, TB, intakes, ect...
There was two episode of intakes for me. First was porting, tried everything and got nothing. It would flow the same as stock no matter what. 20+ hours in a intake and nothing other than hurting port velocity from making all the runners bigger. Gave up....
Time comes and I get another request for intake work and decide not to give another reponse of "nothing is there....". Over my earlier frustration, it is back to work....This time I got an idea. With flowing heads on a flow bench, you always use a radius plate on the port to make sure you get clean air running thru the head. Flow numbers are terrible without it. This gave me the idea of trying a radiused mold on the knife edge of the port entry in the plenum. POOF! like magic it started flowing better without touching the port. Next problem was coming up with something that's practical, cost effective, and could be installed in the plenum without worrying about it coming un-glued, loose, or have the chance of making its way into the motor. Molds and epoxy were out, couldn't be trusted long-term. Especially with all the oil that gets in to the intake. Looking around the shop I found some tubing and decided to try it, gave the same results. Tried several different sizes, even got a few special cnc's wood dowels from Jeremy, until settling on what I am using now. Finally got an intake that shows promise but will it deliver? Anyone who knows me can tell you it wasn't going to the dyno, it was going the track. If it doesn't go faster, then a better dyno number means nothing....With my car I only installed the bars. No cleanup, no pillars removed, nothing.....just the bars installed. Before the intake, it was running 11.80's-70's @116 with my 2800 stall and 285/40-18 drag radials. Now with a 2600 stall and 285/40-18 BFG KDW street tires. Made two separate trip to the track over two months and 11.70's-60's both time @118-119. On a side note, when just porting the intakes, I had the car as slow as 12.0's @114-115 when I tried to radius the knife edge in the plenum. It really hurt the flow numbers... Tested, worked, now to try and get good results beyond my car......
Virus would be the first, his went 11.90 @116+ at @+1200DA with tires I call "hockey pucks"....also his heads and intake is the first data put on the board to show the flow difference but collectively not separately. He was very helpful with all is support since my data and feedback looks bias....
Jeremy, Brent, Dave, and few other shortly followed and it has been gaining momentum ever since. Jeremy did a back to back dyno pull with good results as was the rest of his combination. Brent finally made it to the track as well as Dave. Brent put the stall stall N/A bar pretty high for such a mild cam running 12.0's at 117 during GONE. Dave had nice gains over his previous 1/4 runs and put tail lights on a G8 sporting the new 250cc PRC heads. John set a PB with 11.67 @119+ just bolting on the intake and running at the track, then went to NewEra for a tune update and settled at 18hp gain. Now with a good Possy on my side it is just a matter of staying on top of everything that comes along with it. Emails, tunes, and the work. All keeps me very busy since this is just a side venture to my other two jobs....
End result: Simple, effective, practical, cost effective, and similar price to other "ported" intakes. Next .....getting separation from the "typical" ported intake circle. Again, not ported, MODIFIED... But people generally look for a "ported" intake just like they do with heads which means want something that flows better for more power. Problem is nothing "ported" with this manifold really generates much of anything. I have seen some cut out the pillars but you can't measure any gains on a flow bench. It doesn't show anything. The math shows more volume but there is already enough so it is speculation to what it is worth. Plus port flow is still the same so it would be combination sensitive and gains would be minimum to none. Who wants to buy a "maybe"? I have put a ton of work in follow-up, tuning, and advice with all my initial intake buyers and with their help the intake speaks for itself. It isn't just a "ported intake", it is a AirRam with the potential to be faster........
Not here to sell you a ported intake, I don't have any.......
Troy Trackbeast is offline
Old 01-23-2013, 05:27 PM   #25
BigV8
BigV8's Avatar
Originally Posted by Roadcone View Post
basically all i can find about whoever this is, is that a bunch of people swear by him but no one ever says what he does and i've even seen where someone had an intake ported and THEN Sent it to him too... so, who is this guy and what is he doing?
If you can make the IRS Eastcoast Shootout V in Darlington SC in Febuary he'll be there.
Sold and wish I hadn't.09 GXP SRM A6 w/sunroof. Mods:Livernois Maggie 2.3, 3.0" pulley, 160 stat, KB Bap. Rotofab,Corsa, Kooks 1 7/8 mids, BMR,Pedders supercar coilovers, all Brembos, CTS-V rims, Hids, halos, leather console lid. HSV gauges. 502rwhp,479tq#873 of 1829 and 1 of 169 in SRM.
BigV8 is offline
Old 01-23-2013, 05:30 PM   #26
Bo White
Bo White's Avatar
I will be having V8Muscle.net tune my car when i do either an LS9 or LS7 cam swap.
With you being so close to him I cant think of another reason why you would take it else were for tuning. It would be like you living in Texas and not have Pat G tune your car.
Bo White is offline
Old 01-23-2013, 05:37 PM   #27
Roadcone
HeapBlaster
no offense to him at all since i don't know him or his reputation outside of the intake manifold but these guys a proven, seen too many cars leave reputable shops with horrible tunes get fixed by them. also seen them set records with bolton cars...
Roadcone is offline
Old 01-23-2013, 06:07 PM   #28
Zodiac
Sarcasm Personified
Kinda like Troys car with Rick's tune and work? He's setting records. There are quite a few members on here with tunes from Rick. I have never heard of the company you are using for your tune, doesn't mean they aren't good, just means I've never heard of them. I'm not kissing Rick's ass or any of that nonsense as I don't have any work done from him... being as he only works on LS engines, but I was going to have a bunch of work done from him for my G8 before I sold it.
Only you can decide what's right for you, but it's kinda odd you were asking about it but don't consider him for any tuning work or things like that. I have personally been in several cars he's tuned and they are far better than any other that I've been in , including my VMS tuned car.
Best of luck with your mods and car, let us know either way what you do and how fast you go!
2015 Mustang GT Auto, 3.55, recaro seats, spoiler delete, Solo catback, SVE Drift 19x9.5 w/ 275/40/19's.
2015 Jeep Cherokee Latitude V6
Zodiac is offline
Old 01-23-2013, 06:08 PM   #29
dblaron
Super Moderator
dblaron's Avatar
Roadcone, can you clarify your statement? I can't seem to make sense of it. Maybe I'm too tired....
2009 GT Prem. Sport. Sun Roof.
Paddle Shifters, BMR Sways, Eibachs, Koni's, Brembos, 3.45s, LS2 cam, 918 springs, 1.85 rockers, Spectre CAI, Rick C Intake/TB/heads , LS7 MAF, Custom Axle Backs, JBA LT's,
Currently Installing RCR 215/223 .609. 615 114+1
Pat G Tuned.
12.23 @ 113.7 mph 1.98 60' 1,000' DA
20X9-35 TSW Nurburings 255/35 Cooper RS3-S
dblaron is offline
Old 01-23-2013, 06:08 PM   #30
djerickd
G8/LSX n00b
I'm driving up there one day to get him to work on mine!
09.1 G8 GT, 20x9.5/10 RD Sport RS-5's, 255/30 & 275/30 sumitomos, magnaflow catback, Kooks mids w/cats, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP front bumper, GXP rear diffuser, BMR strut bushings/cradle inserts/sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel, Klearz corners, HSV map lights, CHenry splitters/tuned
djerickd is offline
Old 01-23-2013, 06:20 PM   #31
Roadcone
HeapBlaster
I've know who rick is for a few hours now. I've know my local guys for years. Whil e I'm guessing rick does excellent work I refuse to just believe a bunch of user names when I have seen dozens of cars from my local guys. I'm actually waiting on rick to send me a quote for his intake mod because I see people having real gains with it while all other ported intakes are hit or miss at best. It also helps that I shoot their cars for them and it onlytakes me 20 minutestoget to them from where I live. Again, I mean no disrespect to rick. Just prefer to use my local guys
Roadcone is offline
Old 01-23-2013, 06:50 PM   #32
Troy Trackbeast
Super Moderator
Default The Mysterious Rick Crawford...
There is definitely comfort in going with someone local so I see you point. What other work are you thinking about having done on your G8?
Since your in SC you should come to the East coast shoot out in darlington on feb 23. It's going to be a blast and you can get some good runs in. Plus you can meet some of the the guys behind the "usernames"...
Rick and at least 3 cars built by him will be there. Plus the big dogs that run 9s in the G8s...
Old 01-23-2013, 06:53 PM   #33
Troy Trackbeast
Super Moderator
Damn app screwin my post up...Disregard
Old 01-23-2013, 06:58 PM   #34
Pakitullanc
Darlington sounds good but I am not running my car....too chicken to break something....we will let you represent NC Troy......plus you owe me a coke and a smile for the lug nut cap.......lol
09 GT LR.....(SOLD)
Old 01-23-2013, 07:03 PM   #35
Troy Trackbeast
Super Moderator
Yes Sir I sure do.
You should make some passes for sure. These big girls are tough as hell. You could break something tomorrow pulling on the highway or off from a stop light too...
Old 01-23-2013, 07:05 PM   #36
Troy Trackbeast
Super Moderator
I will be repping NC but not the fastest. DougHG8 and blue mayhem will be quick with Dctg8 not far behind. I'll be bringing up the rear lol.
Old 01-23-2013, 07:10 PM   #37
HerronPerformance
There are other people that can do what others do.
He doesnt know this guy yet you dont know V8m either but insist that he should go elsewhere from where he feels comfortable.
HerronPerformance is offline
Old 01-23-2013, 07:17 PM   #38
Bo White
Bo White's Avatar
HerronPerformance, Rick is a G8 owner and is a very active supporter of the G8 sites. those things along with him doing great work speaks volumes to me.
I do porting, I do what others do but dont get offended when others are recommended for porting.
Bo White is offline
Old 01-23-2013, 07:20 PM   #39
HerronPerformance
The others should respect others when they use people they know/like/trust.
I been around for a long time...its all the same...
Old 01-23-2013, 07:24 PM   #40
Bo White
Bo White's Avatar
Sure. Understood. Rick was the one the OP was seeking out. Rick also has 400+ posts, most of those are valuable information for members here.
Bo White is offline
Closed Thread
