Power Steering Fluid - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Drivetrain Tech
Drivetrain Tech 5L40 A5 / 6L80 A6 / TR6060 M6 / ZF Rear Diff
Old 03-26-2008, 01:53 PM   #1
TomPierce
Owner / Operator
TomPierce's Avatar
Default Power Steering Fluid
According to the Owners Manual the recommended Power Steering Fluid is DEXRON-VI Automatic Transmission Fluid.
Can someone verify that this is not a typo?
(According to the stupid owners manual I should also have reading lamps in my new G8 GT. I've looked all over for them - I even looked under the seats in case they fell off.... )
Tom
TomPierce is offline   Reply With Quote
Old 03-26-2008, 02:34 PM   #2
GigaHz
GigaHz's Avatar
Do you have a sunroof?
2008 Corvette
2008 Yaris (wife)
2006 GT Grand Prix (To be traded on G8)
2004 GTO 392 rwhp (sold)
GigaHz is offline   Reply With Quote
Old 03-26-2008, 04:48 PM   #3
need4spd
Flying at low altitude
need4spd's Avatar
Tom
Some cars use tranny fluid instead of power steering fluid...I just can't remember which.
Check the cap of the power steering, usually it is marked as to the correct fluid.
2008 GT
need4spd is offline   Reply With Quote
Old 03-26-2008, 05:08 PM   #4
Rue_G8GT
Rue_G8GT's Avatar
My Mustang's power steering uses automatic transmission fluid so I'm sure it's correct if it says so in the book.
Fully loaded 2009 Hot White G8 GT coming soon.....
Rue_G8GT is offline   Reply With Quote
Old 08-24-2009, 09:49 AM   #5
eggydoo
I had low power steering fluid this morning (may have a leak) car only has 8000 miles on it.
Called the service dept at the dealer and asked them the same question on why it says dexron. The tech said I should use regular power steering fluid.
eggydoo is offline   Reply With Quote
Old 08-24-2009, 10:27 AM   #6
TJay74
Sounds like the dealership tech is not up to par on gm fluid requirements.
Most all gm vehicles and even other brands are now using transmission fluid for the power steering. Even my 2001 formula used it when new from the factory.
Transmission fluid is about the same viscosity as power steering fluid and the added detergents help keep the powersteering system runing smoothly.
2008 Corvette 3LT with Z-51 package
TJay74 is offline   Reply With Quote
Old 08-25-2009, 10:16 AM   #7
wreckwriter
9 Second G8
wreckwriter's Avatar
The manual says Dexron VI, that's what you use.
2011-13 G8 King
wreckwriter is offline   Reply With Quote
