How do I get into the diagnostics mode again? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Community > Lounge
Old 08-10-2009, 03:59 AM   #1
Eric_GT
Eric_GT's Avatar
Default How do I get into the diagnostics mode again?
My check engine light is coming on again and before I take the car to the dealership I would like to go into the diagnostics mode to see what code I get. I am assuming it is the evap leak code- gas cap.
How do I get into the mode again for the codes? And also, is there a link in here that explains the code numbers?
Thanks.
Eric_GT is offline   Reply With Quote
Old 08-10-2009, 07:21 PM   #2
OLD_GOAT
2009 G8 GXP
OLD_GOAT's Avatar
Press down on the metal wheel on the left side of the steering wheel. While holding it down, turn the car on, then you should be in diagnostic mode.
2013 Deep Impact Blue Mustang GT, automatic. Steeda lower control arms, GT 500 axle backs, BAMA tune, Nitto 275/40/17 NT05R drag radials, Airaid CAI.............12.13 @ 115.33......1.891...... 4/19/13 Royal Purple
OLD_GOAT is offline   Reply With Quote
Old 08-10-2009, 10:42 PM   #3
Eric_GT
Eric_GT's Avatar
There you go..that's right.
Once I turn the car off will it reset?
Old 08-10-2009, 10:47 PM   #4
Oreo
Oreo's Avatar
how does this exactly work..? I'm confused
I've been to this mode when having engine light on, and it says there is no codes to show...
No wonder it's the most powerful car starting under 30k...
2008 Liquid Red G8 GT - Red/Onyx interior
Appearance Mods: Partially de-badged, Front license plate delete, 19" inch Breyton GTS wheels and Kuhmo Ecsta SPT summer tires, JHP two tone sport steering wheel, GXP rear diffuser
Performance Mods: Roto-Fab CAI, Magnaflow cat-back exhaust, hood-vent mod, VMS Tune (ECM + TCM)
Future mods: GLong tube headers, LED interior lightning
Oreo is offline   Reply With Quote
Old 08-11-2009, 01:23 AM   #5
mikemaj82
The metal wheel puts you into engineering mode. If you wanna check the engine light codes, you have to hold down the button on the steering wheel that looks like a road, you know the button that cycles the driver information control screen in front of you (odometer, mpg, average speed, etc). Hold that button down while you start the car.
mikemaj82 is offline   Reply With Quote
Old 08-11-2009, 02:35 PM   #6
Eric_GT
Eric_GT's Avatar
I tried this and received a message- No service messages to reset (or something similar to it).
Old 08-12-2009, 12:59 AM   #7
markw78
You held down the DUI changing screen button, and you have no codes (no service engine light etc). You want the other one, press and hold Enter when you turn the car on (silver dial/button on the left)
markw78 is offline   Reply With Quote
Old 08-12-2009, 11:15 AM   #8
Eric_GT
Eric_GT's Avatar
This is getting more and more confusing.
I have a checK engine light with the lightning bolt. I wanted to on my own figure out what the service code is. I guess I'll just press the Onstar button, but I hate to have this go on my record...if that makes any sense.
I don't know if with my ods and having several check engine lights pop up is a good thing or not.
I am 99% sure it is still the gas cap, but wanted to find out for myself.
I think they ought to make the procedure and check engine codes a stickey...IMO.
Old 08-13-2009, 10:49 AM   #9
Perhaps
http://www.obd-codes.com/trouble_codes/
P0442
*edit*
Don't hesitate to ask what some of the other codes mean. OBDII really isn't as complicated as it may seem.
It really does help to narrow things down when troubleshooting.
Some codes need to be reset while while other codes will delete themselves after passing a set number of self-diagnostics with no fault.
*end edit*
Perhaps is offline   Reply With Quote
