Installing a WB sensor in the stock O2 bung - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > PCM Tuning / Dyno Results
Old 09-11-2009, 09:46 AM   #1
RWD-V8
Default Installing a WB sensor in the stock O2 bung
I would like to install a WB in one of my pre-CAT stock O2 bungs. Does anyone know of any WB that outputs both 0-1V and 0-5V to work with HP Tuners and feed my ECM a like stock signal. I believe the factory O2 sensor outputs 0-1V. I'm fine with cutting a stock O2 sensor so I can use the connector to connect into the harnes. The car is a GXP
Would I need to put a resistor across the heating circuit on the stock O2 sensor side. If so, any idea what value? Any help or links would be appreciated.
RWD-V8 is offline   Reply With Quote
Old 09-11-2009, 09:59 AM   #2
Rich-n-Texas
Pooper Scooper!!!
Does this help?
http://www.g8board.com/forums/showthread.php?t=20537
Rich-n-Texas is offline   Reply With Quote
Old 09-11-2009, 10:21 AM   #3
RWD-V8
Thanks. I've seen that.
I'm trying to do it without the addtional bung. I found some WBs that output both voltage ranges. I think I can just splice into the stock O2 sensor harness signal wires and feed in the 0-1V from the WB and leave the heating circuit wires connected so it will heat as if it were in the exhaust stream. Then just tie it back to keep out of the way.
My only concerns with this is could it overload the sensor heating circuit because the O2 sensor would be heating continually heating w/o being in the O2 stream?
Old 09-11-2009, 03:50 PM   #4
Tweaky
Juice Addict
Innovate LC-1 can do it.
Tweaky is offline   Reply With Quote
Old 09-11-2009, 04:35 PM   #5
roswald0511
Be EzE HEMI
roswald0511's Avatar
Just weld in a bung, it will cost like $20 and you wont have this headache.
Did you call them and ask them if it could?
IMO, I dont think it can, cause I have one.
2005 Fiat Magnum RT
Modded
roswald0511 is offline   Reply With Quote
Old 09-12-2009, 07:54 AM   #6
RWD-V8
Yeah, I don't want to grind the coating of carbon steel headers to TIG in the bung. I found out I can just tie the NB output into the harness input for that O2 sensor. Now I just need to fine a wiring diagram for the harness connected to the ECM. Does anyone have this or a link to it.
Also, does anyone know the P/N of the GXP ECM and where to get one at a good price. I've searched around and found conflictign P/Ns. I guess I could dig down an pull mine out. Thanks.
Old 01-15-2013, 11:39 AM   #7
brentsten
Bump. I'm installing headers on my car tonight/this week and would rather use a wide band in place of the stock o2 so I don't have to add another bung. Ill be feeding it into hptuners eventually, just waiting for a good price on a used one to pop up. But like the OP asked, will it feed the ecm as well?
Edit: Nevermind, looks like the outputs are different. I'd need a controller to feed it back into the ecm.
2009.1 SBM G8 GT
LSA SC 2.85, ZL1 lid, LS9 cam, OBX, Aeromotive Eliminator, FIC1000s, Flex fuel, HPT
10.8 @ 130
1/4 mile: https://youtu.be/uVBMAh_ULTc
1/2 mile: http://youtu.be/EudOyV9dSnU
brentsten is offline   Reply With Quote
Old 01-15-2013, 03:55 PM   #8
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Juts add a bung in the right location, while the headers are out of the car. cheap and easy, and you won't have to mess with it except when replacing the WB sensor if needed later on. We have pics showing the bung if you didn't order the headers with the bung in place. you can order Kooks with an extra bung for a WB for example.
Old 01-15-2013, 09:48 PM   #9
Dousail2
Dousail2's Avatar
I looked into this some time ago because I didn't want to weld on my beautifully coated Kooks LT's. The PLX WB controller does this. I bought it with the DM-6 Gauge. The problem with doing this is if there is any difference with the calibration/readings between the WB controller signal and the stock NB signal the Left bank NB readings will be different from the Right bank NB readings and these get used to control fueling for the engine. So I finally decided to leave the the stock NB's and weld a bung into the front of my High Flow CAT. It was tight and closer to the CAT than I wanted to be for the WB but it wouldn't corrupt the stock NB signal in any way. So follow the advise that many others have already provided and weld in a new bung.
Ken's 2009.1 Pontiac G8 GT Pacific Slate Metallic -Premium
Rotofab CAI, Kook's 1 3/4 LTs, HF Cats, 3" X-pipe, Stock Mufflers, PLX WB O2 & Aeroforce gauges
Rick C Manifold/TB/LS3 valves/Little Lunati/Tune, BTR Spring kit, many appearance mods
VMR Solar Rain V701 Staggered 19x9.5+50 & 19x8.5+35, Hankook V12 285/35 & 255/40
Stoptech, HPS, 12.27 sec 114.6 mph 1/4, 1.96 60ft
Put Jesus Christ in the drivers seat
Dousail2 is offline   Reply With Quote
Old 01-15-2013, 10:40 PM   #10
08G8V8
08G8V8's Avatar
Get the bung welded in before the cats and do it right the first time......
2008 PBM G8GT, TVS1900, Patrick G cam, Lonnies Double Pumper, Kooks 1 7/8 Mids, Corsa Cat-back, Patrick G Tuned, RotoFab, BP Catch Can, Pedders Lowered Street II, VMR V713 wheels, in-dash GPS/Bluetooth, de-chromed.......
08G8V8 is offline   Reply With Quote
Old 01-16-2013, 09:43 AM   #11
brentsten
I deleted the cats, so I'm just going to install it in the rear bung since they'll be turned off anyway. I don't know why I didn't think of doing it that way in the first place. Is there any opinion on left bank vs right?
Sent from my Galaxy Nexus using AutoGuide.Com Free App
2009.1 SBM G8 GT
10.8 @ 130
Old 01-16-2013, 09:57 AM   #12
08G8V8
08G8V8's Avatar
That makes sense. I just assumed you had cats.
Sent from my SCH-I535 using AutoGuide App
Old 01-16-2013, 04:21 PM   #13
mtocrs1
I have thought about doing this as well.
2009 White Hot G8 GT
HPT Tuned-Bluegoat has been telling me what buttons to push
Vararam with Vector HSRK
Pacesetter Long Tubes
Partial Debadge
Window tint 20% back 35% on the sides
Camaro 20's.
Next mod-1.85 Rockers and LSA Blower
87 Buick T-Type-My fast car Gone
87 Buick Grand National
2005 Avalanche
2003 Impala- Winter Warrior
mtocrs1 is offline   Reply With Quote
Old 01-16-2013, 06:09 PM   #14
brentsten
Just an extra note for anyone considering using the rear bung for a wide band, you cannot do this if you still have cats. The wide band needs to be placed before the cat.
2009.1 SBM G8 GT
10.8 @ 130
Old 01-16-2013, 09:04 PM   #15
08G8V8
08G8V8's Avatar
I put mine in the drivers side. I read that cylinder 7 is usually the cylinder that goes lean. No idea why that would be, or if it's true, but I went with it.
Old 01-17-2013, 06:58 AM   #16
Back in a Pontiac
Back in a Pontiac's Avatar
What sensor are you installing?
Back in a Pontiac is offline   Reply With Quote
Old 01-20-2013, 02:36 PM   #17
pkstang
why is that?
'09 G8 GT
(daily driver: VCM OTR, Kooks LT Headers & Cats)
'90 Turbo Mustang
(712rwhp 715rwtq)
pkstang is offline   Reply With Quote
Old 01-20-2013, 02:40 PM   #18
pkstang
i ran the LC-1 on my mustang few years back and it was a royal pita and their reset/reteach procedure got old and am now having lot better luck with the aem setup although don't belive they would give you the 0-1v output you're looking for but obviously come with the 0-5v
also, lot of the aftermarket WB02s are not made for turbo setups and won't last as long with the added heat. i found a slick litle heat sink setup from dynotunenitrous that's increased the life of the sensors. lot of them are out of oem vw made by bosch.
pk's $0.02
'09 G8 GT
'90 Turbo Mustang
(712rwhp 715rwtq)
Old 01-21-2013, 08:12 AM   #19
brentsten
Originally Posted by pkstang View Post
why is that?
It's what I've heard for as long as I can remember. It has to do with the post-cat emissions being leaner than pre-cat, which is where your narrowband o2s are taking readings. I found this on another website that explains it a little better.
From the wideband sensor's point of view, post CAT gas is leaner, and the exact amount is hard to quantify in a rule of thumb. The cat is not venting fuel, but it is changing the composition of the gas - so from the sensor's point of view, which runs a pump cell to try to achieve equalibrium, the gas appears leaner.
2009.1 SBM G8 GT
10.8 @ 130
Old 01-21-2013, 10:01 AM   #20
jgeorger
The cats use oxygen, which is what the O2 sensor measures. Therefore a post-cat O2 sensor can read leaner than the pre-cat. The exact amount is hard to determine, especially for WOT operation, which is richer than stoich - so you would think there would be NO oxygen in the exhaust stream. This of course is not true, but there is less. The cats do have some residual O2 storage, but I believe that a full WOT blast would exhaust this. Then one might think the post-cat O2 might read about the same as the pre-cat.
I have had my local dyno operator tell me that his tailpipe WB O2 reads about .1 leaner than a pre-cat. Take it with a grain of salt. I imagine he is referring only to the full WOT run and not steady-state cruising, but who knows? I hope to get a WB O2 kit installed this year and I will go to the dyno and compare my numbers with his and report back to this forum.
2009 SRM G8 GT, CC 215/232 .603/.574 118+4, BTR .660 Platinum springs w/Ti retainers, BTR 7.425 pushrods, Rotofab, HP Tuners, NGK AFX WB, Kooks 1-3/4" LT's, Kooks catted X
Mustang dyno results:
stock: 299 hp/304 ft-lbs
mods: 388 hp/343 ft-lbs
12.9@110 DA=198 ft
jgeorger is offline   Reply With Quote
