Key Programming - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 02-25-2010, 09:45 PM   #1
STL G8 GT
Default Key Programming
Getting a spare key and don't yet have a service manual. Does anyone know the programming sequence (or must you have a dealer tool)? Thanks...Matt
'09 G8 GT
'08 G5
'02 Viper RT/10
'00 Grand Prix GTP
'99 Grand Am SE
'89 6000LE
'09 H-D XL1200C
STL G8 GT is offline   Reply With Quote
Old 02-25-2010, 10:00 PM   #2
DRCUSTOMPARTS
Banned
Programming the key:
To program a new section (A):
1. Insert the original, already
programmed key into the ignition
and start the engine.
If the engine does not start, see
your dealer/retailer.
2. Remove the key from the
ignition.
3. Insert and turn the new
section (A) to ON/RUN within
five seconds of removing
the original key.
4. Turn the new section (A) to
LOCK/OFF. Section (A) is
now programmed.
Programming the fob:
To program a new section (B): Remote
1. Turn the ignition to ON/RUN with
the new section (A).
The vehicle must be in
PARK (P).
2. Select Remote Key from the
personalization menu.
3. Select Program.
4. Press Unlock and Lock on the new
section (B), at the same time,
until you hear two beeps.
5. Repeat Step 4 for all other keys,
including keys that require
programming or ones previously
programmed to the vehicle.
Any key not reprogrammed will
be erased.
6. Turn the ignition to LOCK/OFF.
DRCUSTOMPARTS is offline   Reply With Quote
Old 02-25-2010, 10:43 PM   #3
mi04se1
mi04se1's Avatar
You are correct sir, but I wish I new about the fob programming today. My trim guy spent over an hour trying to download from tis2web to program my fobs. Hes gonna laugh when I tell him this tomarrow.
8000K hid lows, GM 2-way remote, BT from 09.5, VIM, Rotofab rad cover, GXP fascia & diffuser, Inalfa sunroof
Rotofab CAI, VMS ecm/tcm 93 octane dyno tune, Mobil1, Solo Mach Shorty, Solo hfc's, Kooks 1 7/8 LT's
BMR subframe connectors, trans brace, diff bushings, subframe bushings, trailering arms
Summer rims/tires- 19X8.5 FR (245/40 Hankook), 19X9.5 rr (275/35 Hankook)
Winter tires/rims- 18X8.5 all the way around (245/40 Michelin)
339 WHP
mi04se1 is offline   Reply With Quote
Old 02-26-2010, 09:27 PM   #4
STL G8 GT
Thanks drcustomparts!
'09 G8 GT
'08 G5
'02 Viper RT/10
'00 Grand Prix GTP
'99 Grand Am SE
'89 6000LE
'09 H-D XL1200C
Old 06-27-2012, 10:41 AM   #5
Dictatorsaurus
Dictatorsaurus's Avatar
I bought a new transmitter and got a new blade cut by GM and programmed the key myself. The transmitter and blade work fine.
One problem is that the key will turn in the ignition in only one position and not the other even though it's a double sided key. My other two keys work in both positions.
I called the dealership and they said they will have to take a look at it and try it. I programmed the key myself so I don't want to get charged service for a defective key I got.
Suggestions?
Dictatorsaurus is offline   Reply With Quote
Old 06-27-2012, 04:08 PM   #6
PBMG8
The one and only
PBMG8's Avatar
It sounds like a defective key to me. I had my replacement key cut by the dealer, but I also programmed it myself and it works both ways in the ignition. If it is defective then shouldn't charge you for that I wouldn't think but you never know with a dealership.
2008 PBM GT - Gone
2014 Jeep Grand Cherokee SRT!
PBMG8 is offline   Reply With Quote
