Originally Posted by mikemaj82
i want to do this but i know I'm gonna have trouble masking off the certain parts.
Though I won't be able to tell you how it turned out for a couple of days - but what I did was simple and seemed to be effective in covering what I wanted covered.
The straight lines are easy - just line up the tape, etc. On the curves or raised areas, take the 3" wide blue painters tape and lay it across the area loosely. Take your finger/finger nail and work the tape into the joint/crease. Rub it back and forth to create a seal and to force the tape into the seam. Be careful not to cut the tape with your nail. Make sure the tape is well secured on both sides (you don't want it moving while cutting).
Take a VERY sharp blade (exacto, straight edge, etc) and place into the seam against one edge (the engine covers have good seams to follow). Pull slowly through the seam and cut the tape. Stop if you notice the tape bunching up as the blade might not be cutting well.
Take your time and use plenty of tape.
