Bulb List for LED Swaps - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Stereo / Electronics
Old 06-10-2010, 01:54 PM   #1
rez0nance
Post Bulb List for LED Swaps
Given that bulb numbers are requested constantly, and the Sylvania list is (or was) unreliable for our cars as they listed some incorrect or proprietary numbers, finding out what bulb numbers you need is a bit painful and currently requires a lot of searching around (I know from experience). Therefore, I figured I'd make a central list with all the numbers I have tracked down, as well as whether or not they are confirmed to work. I included a zipped Excel spreadsheet that I made for this which might be easier to read.
Mods, if you could sticky this, I'd appreciate it.
If anyone has numbers for any other bulbs I missed, or sees any mistakes in the list, let me know and I'll update the post.
Format:
[Bulb name]: [bulb number], [quantity needed (individual bulbs)], [Color (stock)], [Confirmed to work?]
Starred (*) bulbs require a resistor (6 ohms on each bulb) to be installed in order to avoid hyperflash, brake release blinking, output degradation, and other unsavory side-effects.
Exterior Bulbs:
  • Backup/Reverse: 1156, 2, White, Confirmed
  • Brake: 7443/7440, 2, Red, Confirmed
  • License plate/Tag: 194, 2, White, Confirmed
  • Sidemarkers (under headlight on front bumper cover): 194, 2, Amber, Confirmed
  • Side repeaters/fender turn signals (behind front wheels): 194, 2, Amber, Confirmed
  • Front turn signal: 1157, 2, Amber, Confirmed , *
  • Rear turn signal: 1156, 2, Amber, Confirmed , *
Interior Bulbs:
  • Dome lights: 194, 4(sunroof)/2?(no sunroof), White, Confirmed
  • Trunk (also Glovebox, Center console): 211, 1, White, Confirmed
PLEASE BE AWARE THAT MANY SITES (SUCH AS V-LEDS) SELL MANY BULBS IN PAIRS! DOUBLE CHECK HOW MANY BULBS YOU ARE BUYING SO YOU DON'T ORDER MORE THAN YOU NEED!
If you are going to add a glovebox light (or if your '08 G8 has it and you're going to swap it to LED), or a center console light, the same bulb type as the trunk light will work.
I've confirmed all bulbs except for the brake (which are on the way to me) and license plate lights, but these have been installed by others on the forum before and I got the bulb numbers from them. Edit: Confirmed by other members. Edit 7/29: Brakes confirmed by me as well.
I believe non-sunroof cars have 2 interior bulbs as they lack the map lights... If anyone that owns a car sans sunroof can confirm I'll update things.
I will update this OP as needed.
'09 MSM G8 GT - Premium, Sport, Sunroof - since 9/18/08
Performance: Roto-Fab CAI; Corsa catback; VMS Tune; DBA 4000 slotted discs; Hawks Performance Ceramic pads
Interior: SAS/GTPprix Digital Gauges; Interior trim by CAA; Homelink-visor; Blendmount/Invisicord mounted V1/Dashhawk
Exterior: 3M 20% CS Tint; TSS custom darts; splash guards; Roto-Fab engine bay; Klearz sidemarkers; Spencers 5000k lows/3000k fogs
Misc.: Billet Prototypes catch can; full V-LEDs LED swap
rez0nance is offline   Reply With Quote
Old 06-10-2010, 03:23 PM   #2
Scorpious
G8 fiend
Scorpious's Avatar
i have the 7443 bulbs installed for my break lights.
only bulbs u sihould be gettin from v-leds are the dual white/amber ones. they are way over priced and u can find most other bulb types on ebay for 1/10 of the cost
<a href=http://s98.photobucket.com/user/repozone/media/DSCN0298.jpg.html target=_blank><img src=http://i98.photobucket.com/albums/l259/repozone/DSCN0298.jpg border=0 alt= /></a>
Scorpious is offline   Reply With Quote
Old 06-10-2010, 03:44 PM   #3
5litrarag
The Mustang dude
5litrarag's Avatar
Lic. Plate bulb is indeed a 194 bulb.
Anybody looking for a set let me know.
95 Mustang GT convertible 347 stroker
95 Cobra coupe Rotrex supercharged
The new baby - 09 White Hot G8 GT
Tinted, badges deleted
5litrarag is offline   Reply With Quote
Old 06-10-2010, 04:16 PM   #4
rez0nance
Thanks guys, I'll update both the OP and XLS to show those as confirmed.
Old 06-10-2010, 10:31 PM   #5
EllTee
EllTee's Avatar
Tanks all for the info. Stangster in N. Pomona...hmmm...I'm not to far from you.-LT
EllTee is offline   Reply With Quote
Old 06-11-2010, 12:58 PM   #6
GoneUpInFlames
Black & Silver
GoneUpInFlames's Avatar
Just a thought, but wouldn't the side repeaters need a resistor as well?
2009 MSM G8 GT - SOLD!
2013 Subaru BRZ - SOLD!
2011 F-150 FX4 Ecoboost - 2.5" Leveling kit, Turboback full exhaust from Stainless Works, Airraid intake, Livernois tune.
GoneUpInFlames is offline   Reply With Quote
Old 06-14-2010, 11:22 AM   #7
rez0nance
Sorry for the delay, been a hell of a busy weekend...
No, the side repeaters do not require resistors. They will not hyperflash when swapped for LED bulbs.
Old 06-14-2010, 11:31 AM   #8
CntryClub007
CntryClub007's Avatar
Anyone know how many resistors per side and ohm's we need? 2 per side?
I'm looking to change the rear turn signals to LED red, and don't know if a 3ohm or 6ohm load resistor is required...
2009.5 Liquid Red G8 GTSport/Premium/Bluetooth/Onyx-Red Interior
Performance: Roto-Fab,VMS,Kooks,Solo Performance,Livernois Stage 1 Cam
Appearance: 4300K HID,Roto-Fab Radiator/Fuse Covers,Autodim,Sharkfin,GXP Diffuser,Brembo Brakes
Wheels/Brakes/Suspension:
VMR 701 19x9.5, Yokohama Advan AD08 275/35/19,Russel Lines,Hawk,Pedders xA,BMR
http://www.g8board.com/forums/showpo...91&postcount=2
CntryClub007 is offline   Reply With Quote
Old 06-14-2010, 12:33 PM   #9
rez0nance
You'll need four resistors total, all of them 6 ohm.
Yes, the website says you can use 3 ohm if you're doing both front and back... except that assumes the car has electronic flashers. Our cars do not have flashers, the BCM controls the flash rate, and the circuits seem to be independent. You'll need 6 ohm resistors on each turn bulb to keep the BCM from thinking it's a dead bulb.
Old 06-14-2010, 12:34 PM   #10
Donology13
I have those same bulds for my tail lights but they are very dim when turned on. What do I do to fix this?
Donology13 is offline   Reply With Quote
Old 06-14-2010, 01:25 PM   #11
rez0nance
There are 3 different lights in each tail light. Which are you referring to?
Old 06-14-2010, 02:06 PM   #12
Donology13
Oh, my bad. The 7443 led tail light buld.
Old 06-14-2010, 02:09 PM   #13
Scorpious
G8 fiend
Scorpious's Avatar
i plan to either hack the puter so the flashers are always slow or jus swapit with the hazards since they dont hyperflash
Old 06-14-2010, 03:22 PM   #14
rez0nance
I haven't installed mine yet, but others have. If they're dim though, might be a bad bulb, or one that doesn't fit the application correctly.
Installing the resistors is a piece of cake... Especially compared to any of those options.
Old 06-14-2010, 07:08 PM   #15
Donology13
They are the right bulb, and they work fine. I think I need some capacitors installed but I do not know what size I need to give them that extra push. I have the 50w capacitors from Super Bright LED's that I ordered a couple of years back and I would use them only as a last resort. The reason being is that they get real hot when in use. I'm not too comfortable with that.
Old 06-14-2010, 07:18 PM   #16
Scorpious
G8 fiend
Scorpious's Avatar
i know there ez to install but for a more clean look and not have to worry bout hte heat issue of the resistor the hazards options would be the best and almost undectable if ur car goes in the shop they can void ur electrical system warranty
Old 06-14-2010, 07:44 PM   #17
PSB G8
PSB G8's Avatar
So is there an advantage to going to LED's? All you are really doing is reducing the watt load and have the approximately the same amount of lumens or is it for styling?
PSB G8 is offline   Reply With Quote
Old 06-15-2010, 08:34 AM   #18
GoneUpInFlames
Black & Silver
Mainly for cosmetic purposes. They also have a longer lifespan than filament bulbs and are brighter. The fact that they use less power is just an added bonus.
Old 06-15-2010, 10:40 AM   #19
rez0nance
Man, I'd just find myself a better/brighter set of LEDs before I resorted to going to capacitors... But that's just IMO.
Clean look? The places you'd install the resistor (on a frame rail in the engine bay, behind the carpet trim in the trunk) are invisible. There is no heat issue if you install it to a piece of metal, and even less if you use the brackets like the ones V-LEDs sells. For the engine bay ones, I stuck metallic duct tape on the frame rail, then used double-sided tape to stick the resistor on top of that. On the rear, since they go behind the trunk carpeting (even though the carpeting should never touch them), I'm using the brackets that completely encase the resistor to protect other components, and act as a heatsink as well. That will be stuck on with double sided tape to the sheet metal next to the tail lights.
If you do it right, there are absolutely no negatives to installing the resistor. Additionally, with the splices they come with, it would be impossible to void your electrical warranty, unless you completely bypassed the resistor with a straight piece of wire and shorted 2 wires, but then you'd really have to be trying to be a moron.
What would you be doing with the hazards? Rewiring the lights themselves? Besides being more complicated, it might not even be an option because the hazards might be entirely controlled in the BCM.
Exactly. They have an extremely long life compared to filament bulbs, better color temperature (cosmetic), brighter in some applications, give you much more options to customize your lighting to your liking (such as the switchbacks on the front turns that switch between white for parking light mode and amber for turning signal - there's no way to do that without going to those LEDs), and lower the power draw.
Old 07-28-2010, 10:23 PM   #20
WhiteHotWhyNot
Which bulb or company are you getting the 7443 bulbs from. How many leds should there be?
2009 MGM Pontiac G8 GT
K&N intake and Magnaflow Exhaust
1997 Pontiac Formula M6 *SOLD*
Stroked Sprayed 6 Speed
2006 Yamaha R1 Raven*SOLD*
520 Chain +2 in the Rear.
WhiteHotWhyNot is offline   Reply With Quote
Tags
bulb , led , numbers , part
