How far off is speedo with Camaro 20s? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Wheels / Tires
Wheels / Tires Sponsored by: Discount Tire
Old 07-22-2010, 09:36 AM   #1
cpd004
municipal zoo keeper
cpd004's Avatar
Default How far off is speedo with Camaro 20s?
A take it a tune is the only way to correct the speedo?
2009 Stryker GT
1971 Firebird
cpd004 is offline   Reply With Quote
Old 07-22-2010, 09:43 AM   #2
TLS
TLS's Avatar
Are they a taller/shorter diameter than stock?
2009.5 G8 GT SRM
Sport + Premium - No Sunroof
255/40-19 Conti DW Summers
18" Winter wheels with Conti DWS's
Full Size Spare and Jack kit
Sliding Armrest
Volant CAI w/Amsoil dry filter (HSRK)
Maximizer LTH's & Midpipes into Corsa Axlebacks
Mustang Dyno tune
FE3, Eibach, Whiteline mounts, New Control Arms, Moog Endlinks
TLS is offline   Reply With Quote
Old 07-22-2010, 10:34 AM   #3
zepcom
Type in your numbers, bud.
http://www.miata.net/garage/tirecalc.html
To make the camaro rims "fit" a g8 (without rubbing), the standard camaro tires are replaced by lower profile tires.
Thus, it's closer to a 19" stock g8 tire, generally speaking.
Plug in your stock numbers. For example, I have 245-45-18's which are still my stock RS-A's on stock rims. Now find what others are wrapping their camaro rims with, 275-30-20's ring a bell, not sure though.
Using that formula... compared to "stock", your aftermarket tire&rim is causing your speedo to be reading 0.7% too fast. thus, when you're going 60 mph according to your speedo, you're really going 59.4mph.
If you chose to run 275-35-20's on the camaro rims (slightly larger sidewall than the 30-series tire) then it goes the other way. Since the overall tire height is higher with that combination, your speedo is now reading 3.4% too slow. Thus, when you're going 60mph according to your speedo, you're really going 62.0mph. Be careful speeding with this size tire...
Hope this helps. You can use that miata.net calculator for any combination of tires to compare, it's really the best one out there!
--zep
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Last edited by zepcom; 07-22-2010 at 11:25 AM. Reason: color code to seperate two comparisons
Old 07-22-2010, 10:51 AM   #4
mongosG8
mongosG8's Avatar
Zep
Thanks man! I was just trying to figure this out yesterday!
Appreciate it!
2009 White Hot G8 GT Onyx/Red Interior Sport/Prem no roof
Intake: Volant CAI Exhaust: Borla Cat back Tune: SC Tint: 20% around
Other: Black Hood Scoops w/ Mod
/ GXP Fascia /GXP Diffuser 1 blk 1 white/ Roto Fab rad cover/ Stagrd 20" Polished Camaro SS wheels /Crystal Clear markers/ Shark fin/ Infinity 6032si/
"Never mind that S*** ...Here comes Mongo!"
"Blazing Saddles"
mongosG8 is offline   Reply With Quote
Old 07-22-2010, 10:44 PM   #5
Ridin ON Chrome
Rim and Tire GOD!!!
Ridin ON Chrome's Avatar
Yup, as long as you get the right tires. Any size rim will make the speedo stay correct.
Truthfully, its no big deal for it to be 1-2mph off. My GTP is and never had issues.
Ridin ON Chrome is offline   Reply With Quote
Old 07-22-2010, 10:51 PM   #6
cgbr4d
My 275-35-20's on my Camaro wheels make it about 2 mph slow at 65 by running side by side with my dad (I wanted to test this when I got them). Zep's info appears spot-on.
cgbr4d is offline   Reply With Quote
Old 07-22-2010, 10:57 PM   #7
Ridin ON Chrome
Rim and Tire GOD!!!
ofcourse man. Thats why its a wheel/tire calculator. It will never be wrong. It will tell you correct answer no matter what brand, size, width tire/wheel you have.
I like this one too.
http://www.rimsntires.com/rt_specs.jsp
Old 07-22-2010, 11:13 PM   #8
cgbr4d
I was not doubting it at all. I was just chiming in with my own personal experience.
The MPH difference is minor but something to keep in mind just in case.
Old 08-24-2010, 05:18 PM   #9
likwidred
hasa Member
likwidred's Avatar
Due to our sue-happy culture, most factory speedos read a little fast anyway (if you found you were going 1mph faster than the speedo said it would be "unsafe", and you could sue the car maker, but the other way around is "safe"), so going to a rear tire 2% larger may actually CORRECT your speedo. That is exactly what I found when I changed the tires/wheels on my S2000. The slightly larger rear tires just about exactly corrected the speedo. I tested it using GPS before and after.
09 G8 GT, Liquid Red, Premium, Sport, Sunroof, Two tone
likwidred is offline   Reply With Quote
Old 08-24-2010, 06:17 PM   #10
Mike M.
Mike M.'s Avatar
Wouldn't replacing the tire pressure sensor when getting the 20" Camaro rims correct the problem?
MSM GT with Premium & Sport packages, sun roof, clear bra-full hood and fenders, front license bracket removed, partial debadging of Pontiac name, and front fender chickletts removed, GM Accessory trunk mat.
My all original 1990 Trans Am with my Silver G8 GT in the backround
Mike M. is offline   Reply With Quote
Old 08-25-2010, 12:36 AM   #11
likwidred
hasa Member
likwidred's Avatar
Completely unrelated.
Old 12-15-2010, 10:41 PM   #12
JensKP
Awesome link man!
JensKP is offline   Reply With Quote
Old 12-15-2010, 11:25 PM   #13
2dbatcv
2dbatcv's Avatar
I'll bite...why? I'm guessing because the TPMS system maybe measures the RPM of the sensor and gets MPH from that??? That's the only thing I can think of....really not being a jerk, just interested in the thought process
2008 White Hot G8 GT - V6 tails, Cortex tuner, Dynomax Turbo mufflers, Giovana Doulble G 20X8.5, Falken FK452 245/35R-20XL ....hopefully more to come. I love my car!!!
2dbatcv is offline   Reply With Quote
Old 12-16-2010, 08:50 AM   #14
TLS
TLS's Avatar
No, the sensors just "sense" pressure, and relay that info to your car. You could build a pressure chamber out of 6" PVC pipe, put all 4 sensors inside, seal it up, and pressurize it to 35psi, put it in your trunk, and everything would be good.
Just bothers me when the OP never returns back to a thread and answers questions or thanks others for helping them.
2009.5 G8 GT SRM
Sliding Armrest
Mustang Dyno tune
Old 12-30-2010, 05:40 AM   #15
bennems
bennems's Avatar
With 245/35's up front and 275/35's on the rear, and according to my iphone speedometer, I have found it to be only about 2 mph faster @ 75 mph!
"Stay Sweetly Numb"
09 - MGM G8 GT, tint, k&n filter, 2010 Camaro 20's, Magnaflow axlebacks.
02 - Bagged Silverado, flat blue, fully shaved, 99 deville tails, 22" Centerline Archers, Longtubes, Dual 3" flowmaster 40's, Volant CAI, Elec. fans, laptop tune, Kenwood double din, polk sound.
98 - Jeep Wrangler, Hot red, Borla full exhaust, JET chip, k&n intake, pioneer sound.
bennems is offline   Reply With Quote
Old 12-30-2010, 03:18 PM   #16
Slizzo
Slizzo's Avatar
Overall diameter changes from 26.7" to 27.6" on that size rear tire. Speed difference SHOULD calculate out to 3.3%, or 62MPH at 60MPH actual.
2011 Radiant Silver Metallic CTS-V Wagon - Corsa Axleback, AirAid Intake
2008 Panther Black Metallic G8 GT *Sold 6/11/14*
Slizzo is offline   Reply With Quote
Old 12-31-2010, 09:44 AM   #17
granatelli
He's a zookeeper and the animals are escaping! (They're running for office).
granatelli is offline   Reply With Quote
Old 02-26-2011, 03:31 PM   #18
Supercharged
Supercharged's Avatar
Nice calclulators! So I could actually run a 225.60.16 tire for winter tires. This would be a little cheaper than buying 18's and maybe open the door to using steel wheels. The only question that just came to mind is will 16" wheels clear the brakes?
Supercharged is online now   Reply With Quote
Old 02-26-2011, 08:04 PM   #19
Slizzo
Slizzo's Avatar
No, they won't. Smallest you can go is a 17" wheel.
I run a 225/55/17 during winter on 17x8" wheels
Old 03-03-2011, 08:19 AM   #20
XT1NCT
TeRm1n8D
XT1NCT's Avatar
THANK YOU! So one thing ruled out on why my car got slower once the wheels and exhaust.
XT1NCT is offline   Reply With Quote
