06-20-2008, 03:50 PM
#1
Banned
12.70 @ 108
It took some time to get all the parts, but it performed as expected. Stock 19in tires with 33-35psi, launch 1200-1400rpms = best 60ft was 1.91 with 12.70 @ 108. Worst time = 12.94 @ 107 2.06 60ft. Only made 2 passes due to air temp and track closing. I feel with headers and converter and Kirk "the magician" @ VMS this car on drag radials will run low12s or high 11s in cooler weather. Once I change the cam it will be a solid 11sec car. Charlie
06-20-2008, 04:01 PM
#2
PHAN BOIIIIIIIIIIIIIIIIII
dayum, good show...
06-20-2008, 04:06 PM
#3
Guest
Congrats! Way to stick that G8!
06-20-2008, 04:45 PM
#4
Holy snap! 12's are very nice!
222/230 .597/.600 114+4 EPS Cam, Vector Motorsports ECM/TCM Tune, Roto-Fab CAI, HSRK,
Yank 3200 Torque Converter, Transmission Cooler, Kooks 1 3/4" LT Headers, high flow cats, stock mufflers,
Billet Prototypes Catch Can, UD Pulley, Ported Intake Manifold, Spohn Trailing Arms
407 RWHP & 365 RWTQ
Best Time: 12.517 @ 115.02mph w/ 1.97 60' time - (on stock 18" AS Tires)
06-20-2008, 04:50 PM
#5
Hmmmmm
Most of a full second under what others with the same mods are running. Pretty impressive.
2008 Pontiac G8 GT, Magnetic Gray Metallic, Premium and Sport packages
ATI ProCharger D-1SC, 3.70 TrueTrac Diff, Bluecat tune, Ported Intake and TB, Aeromotive Fuel Rails, FAST 65 lb injectors, Full Kooks 1 7/8 system, Yank 2800 Converter, Pedders X-Member, Diff & steering bushings, BMR chassis parts, Slicks and skinnies, MSD 8.5 mm wires, GRRRR8 Mods.
06-20-2008, 05:09 PM
#6
Very nice run!
blown, cammed, and much more, and still slow.
06-20-2008, 06:16 PM
#7
Guest
This is the second car with nearly the same mods with the same ET and almost the same trap that has been reported to us so far. I think this will be more the norm when people really figure out how to get these cars out of the hole.
06-20-2008, 06:18 PM
#8
Hmmmmm
That would be great, hope you're right. The only thing unusual I see on this car is the underdrive pulley. I've been trying to find out more about these.
06-20-2008, 06:42 PM
#9
i Actually own one...
Who had the other car....any time slips /video jus curious...not saying any one is eggaerating..but this is a very very quick time for the mods listed IMHO.
I have intake..exhaust..and practice lauching the car ..but I lauched the car just like above and cut a good RT and 60ft .I dont know if 20 to 30 more hp is going to slice off more than a tenth or two from my 13.8...Unless your TCM control is really waking up the tranny ..and shifting....I am being optomistic and hope this is the general case. Awesome run..I hope I can see many other repeat this!
2008 G8 - flowmasters /roto fab intake / speed racer stickers
2006 Jeep Hemi stock
2005 razor scooter
1998 LIncolon Conti - Cobra motor/ 3 inch layer of dirt/ blowN out cats-NEEDs rotors and brakes.(Any 916 shade tree mechanics out there?)
G8 JOE
Best Run so far 13.8 @101 mph
60 ft 2.1
New Best RT .114
06-20-2008, 07:02 PM
#10
Hey GRRRR8: Did you use sport shift? If you did, did you keep it in 3rd gear to finish?
I noticed now with the Roto CAI & VMS tune, if you leave it in sport shift the 3 to 4 shift happens at 104mph. If you manually keep it in 3rd gear, it can stay in 3rd until 107mph.
407 RWHP & 365 RWTQ
06-20-2008, 08:05 PM
#11
Banned
Ok I can see the doubters have come out to play and I understand. For the benefit of the people that actually build fast cars and have fast cars, here is how I did it. 51psi frt tire pressure = less rolling resistance. 4 gallons 93 octane= saves approx 100lbs=1/10. Let car cool with fans and generator to 130 degress. Less heat=more power. No burn out, 140 treadwear tires are only going to get greasier when hot. Drive around the water box and drop hopped it to clean tires off. At the launch the engine temp was 161 degrees.Sport mode hold 3rd in M3. Every .10 in the 1st 60ft is .15 on the big end. So any REAL racer can see that just this would make me about .4-.6 faster then the same car that wasnt equally prepared. Not to mention that I made a panel to stop engine air from entering Roto-fab, or the half dollar sizes hole in the lower plastic panel that is now opened to optimize volume. I hope this helps, but there will be a video and feature article soon. Charlie
06-20-2008, 08:14 PM
#12
Thanks for the recipe for success! I need headers, the HSRK, under drive pulley and most importantly, a great 60' time!
Also, thanks for the heads up on the front tire pressure (less rolling resistance). Were your rear tire pressures set at about 20-25?
Thanks again! And congrats!
407 RWHP & 365 RWTQ
06-20-2008, 08:33 PM
#13
Nice times!! What were the track conditions (prep, temp or DA)? I know the tracks here in so cal are crappy due to the high DA and temps.
I know that track conditions also plays a role in your times.
If you guys want to find Density Altitude go to this site. http://www.modulardepot.com/density2.php
Here is site to find out the temp and humidity on the day you raced.
http://www.wunderground.com/
If you want to know how to get your corrected times go here.
http://www.smokemup.com/auto_math/nh...on_factors.php
I'm happy to know that this is 13-12 sec car with the right mods. I put the same mods on my G35 and I barely broke into the 13's in Cali.
Do you have any pics of this panel that you made for the intake?
06-20-2008, 08:50 PM
#14
Someone just ran 13.4@104 with a completely bone stock G8. I don't think his times are that far off to be honest. Look at his mod list. Plus, an underdrive pulley is worth WAY more then you guys think. It ain't about what the dyno shows. Dynos are for tuning, 1/4 mile tracks are to show how fast the car is.
06-20-2008, 08:54 PM
#15
Banned
THANK YOU!!! I thought I was the only 1 that saw bone stock 13.40/.50 cars. I guess alot of time and $$$ cant possibly pick-up a mere 8 tenths.
06-20-2008, 09:10 PM
#16
Hmmmmm
sure wish someone would give more info on installing the pulley....
06-20-2008, 11:03 PM
#17
I can haz Horsepower?
'08 Black on Black G8GT
12.166 @ 113.13, 1.72 - 60'<before the gear swap
FasterProms Tune, Ported TB/Intake - HSRK - Vararam - UD Pulley - GRRRR8 Heater Hose Relocation Kit - ARH 1 3/4" Longtubes - Pypes Violators - Yank 3200 Converter - PCM4Less Trans Cooler - SJM LineLoc - All Pedders Bushings, Xa Coil-Overs - Spohn Trailing Arms - Billet Prototypes Catch Can - GXP Diffuser - Skinnies on GTO rims - ET Streets on F Body Rims - 3.70gears/Harrop TrueTrac
06-20-2008, 11:58 PM
#18
Site Sponsor
Nice times man , congrats !
06-21-2008, 11:01 AM
#19
Time slips ? Pics? video ?
06-21-2008, 11:47 AM
#20
Queen of the Quarter Mile
No, I'm here and I really exsist.
Ranay - I'm Pregnant. Don't MESS With Me!
2008 Pontiac G8 GT - Magnetic Gray Metallic/Onyx Leather #2953
2008: 13.507 @ 104.17 - Stock - 6/15 [Best R/T: 0.78]
2009: 12.923 @ 109.67 - 1.920 60' - 5/9 [Best R/T: 0.15]
OPG CAI, StolenFox H-Pipe and Custom Loudmouth Exhaust, MT StreetET Drag Radials, HPTuners by MoMorg, Ported TB by VetteWorks, Intake Manifold Cover Removal by BobTheMonkee, Pedders LS 6/09
