valves ? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-20-2010, 03:42 PM   #1
LuminaSS
LuminaSS's Avatar
Default valves ?
Hi
If I want to rev over 6000rpm I only need to change valve springs what about the intake valves ?
thanks
LuminaSS is offline   Reply With Quote
Old 11-20-2010, 06:43 PM   #2
mr_didgers
Cam might need to be changed too.
Just remember there are trade offs whenever you make big changes like this.
mr_didgers is offline   Reply With Quote
Old 11-21-2010, 10:30 AM   #3
zepcom
Originally Posted by LuminaSS View Post
Hi
thanks
Do you have the L76 engine with AFM/DOD, or the non-DOD variant?
I would think that would make a big difference in our responses. Non-DOD engines are much happier revving higher safely than DOD equipped engines.
At the very least, if you have a DOD engine like the L76 in your Lumina, you'd want to replace the camshaft with a non-dod higher lift cam, replace the special DOD lifters with their LS2 variants, and plug up the extra oil valleys in the tray. You'd be basically changing your L76 into an LS2, more or less.
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Old 11-21-2010, 02:15 PM   #4
LuminaSS
LuminaSS's Avatar
I have a g8 gt 2009
well I am asking if I can revs over 6000rpm with stock valve springs and stock intake valve ?
my main question is do I need the intake valves does it need to be changed
Old 11-21-2010, 04:27 PM   #5
hayabusa160
valve sping is more important in valve control during high rpm...valve float is no joke.
hayabusa160 is offline   Reply With Quote
Old 11-21-2010, 05:15 PM   #6
2quik4u
2quik4u's Avatar
You dont need to run over 6000 rpm on the stock cam it doent make any power up that high. If you are going to install an aftermarket cam then you will have to replace the valvesprings along with several other parts anyway. The L76 does use really heavy valves so having a strong spring to control the valvetrain is essential.
09 Stryker Blue G8 GT 435/405 Cam, Full Bolt-ons, 3200 stall, Camaro diff, Pedders Suspension, Tuned by Frost
02 SS #510 M6 440/400, 585/592 100 shot Sold
98 Z28 M6 cam/boltons 395/377 Sold
73 Z28 Neverending project
2quik4u is offline   Reply With Quote
Old 11-21-2010, 10:49 PM   #7
Damian
LSX Mechanic
You can successfully run the stock valvetrain to 6200 and still make power before it starts floating. Not to mention it's not necessary since the stock engine doesn't make any power past that.
On the A6 cars I tune, I set the shift points in the 61-6200 range. This makes a big difference in getting the car down the track/road faster because it doesn't fall as far back in the rpm range after each shift.
6200 is fine. Anything north of that is pointless AND risky.
As for upgrading valves, that is not necessary.
Spartan LSX Performance
Damian is offline   Reply With Quote
Old 11-22-2010, 02:42 AM   #8
danswrld
Tin Indian
danswrld's Avatar
The roller lifters in the AFM motors are very heavy in order to accommodate the DOD oiling in order to collapse the lifter in four cylinder mode. The cam is also small compared to other LS engines partly because the lifter can not take an aggressive ramp profile due to it's weight. Changing springs alone most likely will not get the desired result to rev the motor safely, and as previous post stated, the motor falls off in the power band mush past 6,200 range due to the conservative cam profile. A more aggressive cam, AFM delete lifters and matching springs (such as a stock LS3 cam and lifter set even) will get the motor to 6,500 no problem.
1967 Firebird 400/4spd all numbers matching
1965 Pontiac GTO 389 4bbl 4sp.
1971 Camaro Pro ET Drag Car
1970 Camaro real Z-28
1963 Impala Super Sport 409 dual quad 4 spd
1967 Chevelle SS396 4sp clone
2009 White Pontiac G8 GT.........shockingly stock.
(My wife says I have a problem)
danswrld is offline   Reply With Quote
Old 11-22-2010, 06:16 AM   #9
Comp G
Grand Prix Guy
Comp G's Avatar
Would there be any benefit to changing valves to the lighter weight LS3 valves?
Tate
08 G8 GT: RCR Heads, Intake manifold, throttle body, 219/232 .625/.599 109LSA, LS7 MAF, Rotofab, Kooks LTs and catted X-pipe, Solo axle backs, RCR ECM/TCM 93 tune, Free Mods
P.B. et- 11.84, mph- 120.5 w/ 1.93 60'
04 Comp G: Sold
Comp G is offline   Reply With Quote
Old 11-22-2010, 07:23 AM   #10
LuminaSS
LuminaSS's Avatar
thanks
what about the valves do I need to go for ls3 hollow stem valves
Old 11-22-2010, 07:52 AM   #11
Richard Craneum
Richard Craneum's Avatar
Hi
thanks
Consider changing the pistons too. That is one of the biggest chunk of reciprocating mass and I do not think the Stock pistons are designed to handle stress at that amount of RPMs. By my experience, most cars with V8 over the 5.0 L mark are not high revving, they have bottomless torque at lower RPMs. In another hand, the ones that climb way high RPMs has puny size pistons.
This might give you an idea on what to look for.
US Army Retired 1986~2008
Fortune Favors The Bold
Richard Craneum is offline   Reply With Quote
Old 11-22-2010, 09:27 AM   #12
mr_didgers
I'll second that motion, especially if you have the L76. It was initially a truck motor, and still has its truck pistons. Some pistons designed for higher RPM's and loads would be a nice change if you can do it.
Old 11-23-2010, 03:07 AM   #13
LuminaSS
LuminaSS's Avatar
so it is not necessary to replace the valves but when do I need to replace them and maybe go with ls3 valves (lighter)
Old 11-23-2010, 08:22 AM   #14
SS_Nasser
G8 GT it means same as our Lumina Ss in UAE, so I will not recommend more than 6200 rmp because you have the L98 valve springs, you can go for 6600 if you put the LS2 valve springs. google the part number and get them from any dealer.
this is the best for you and based on my experience.
regards
Nasser Almuraqab
President of Ss Freaks Motorsport Club
www.SsFreaks.com
UAE
SS_Nasser is offline   Reply With Quote
Old 11-24-2010, 09:36 PM   #15
Damian
LSX Mechanic
With all due respect sir, that is horrible advice to give about an LS engine. Especially on the internet where 350 people who don't know any better are going to believe it and read it.
You do NOT "need" to change the pistons in any LS motor unless it's getting a lot of boost or a lot of nitrous. I've spun stock LS bottom ends to 7200rpm's and pushed 200 shots of nitrous through them. The stock pistons are fine.
Yes, lighter pistons are a benefit. But necessary? Absolutely not.
Old 11-24-2010, 09:43 PM   #16
Richard Craneum
With all due respect, the word Consider does not meant that you have to.
Hey, if you have experience in the matter do not hesitate to share
Old 11-25-2010, 12:28 AM   #17
danswrld
Tin Indian
danswrld's Avatar
If the sole goal is to rev the motor past 6,000 rpm, it is all in the cam, lifter, and valvesprings.....not the valves themselves. A more aggressive cam is going to move the powerband into the upper rpm ranges. Not sure if you are mistaking the term "valves" for "Lifters".
