How to Replace Lower Control Arms - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 01-06-2011, 04:49 PM   #1
2SLO4ME
Car Crazy
2SLO4ME's Avatar
Default How to Replace Lower Control Arms
So I've done some searching and can't seem to find a DIY for changing out the front lower control arms. Mine have never been changed and they just started doing it at 58K. So I unfortunately I won't be having the dealer cover it under warranty.
I ordered the New Kit that comes with all four arms and will be installing them tomorrow. Has anyone changed them themselves or know a place that gives instructions... I'm assuming it can't be that hard since it is only four nuts and two bolts. Through some digging I found this picture with some specs on it, but I'm not quite sure which specs are for the arm the has the bend in it.
2009 Liquid Red G8 GT - SOLD
2SLO4ME is offline   Reply With Quote
Old 01-06-2011, 06:45 PM   #2
2StepsAhead
I dont have a how to but theres a post around here where someone said they took only an hour or two to replace them, Ill see if I can find it. Ive been under the car, its only a few bolts...gotta knock the ball joints from the knuckle.
Rick Crawford Built/Tuned..bolt ons and stuff...
2StepsAhead is offline   Reply With Quote
Old 01-06-2011, 07:11 PM   #3
Virus
Capital City G8
Virus's Avatar
It's not too terribly difficult. You need to get an alignment afterwards.
Virus is offline   Reply With Quote
Old 01-06-2011, 07:33 PM   #4
JCMG8
can download manual sections here
9.5 RPM (Red Passion Metallic) Sport /Premium
ICOM 208H
"Experience is what you get when you didn't get what you wanted."- unknown
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. -red green
<img src=http://www.g8board.com/forums/signaturepics/sigpic9701_2.gif border=0 alt= />
JCMG8 is offline   Reply With Quote
Old 01-06-2011, 07:55 PM   #5
2SLO4ME
Car Crazy
2SLO4ME's Avatar
Yeah I figured it couldn't be too hard, just wanted to make sure there wasn't something different with this car.
Good to know and yeah an alignment will be done. I have SLP springs, Whiteline Strut Mounts and Bearings, LCA's and new Clevis Bolts all sitting in a pile waiting to be done. So needless say I will definitely need an alignment after all that, lol
Thank you much!!!
Old 01-06-2011, 08:21 PM   #6
Voice of Reason
Protagonist Extremist
Subscribed so I can find this later.
2014 SRT Viper TA
Drivetrain: 25% UDP, Solo axle back
Suspension / Brakes: BMR f/r swaybars, radius rod bushings, diff bushings, trailing arms,
toe rods, crossmember bushings, subframe connectors, tunnel brace, DBA slotted rotors
Show: VE SS Black/Red Steering Wheel, VE Black/Red Shifter, Leather Console Lid
Voice of Reason is offline   Reply With Quote
Old 01-06-2011, 08:24 PM   #7
DilligafDave
DilligafDave's Avatar
Im doing the same thing. just got all 4 control arms today, i also got bmr bushings for the control arms while i have them out. I also have new strut top mounts/bearings to install at the same time. it helps to know a mechanic with a lift in his garage too, he will be helping me.
JCMG8: thanks for that link it will help with more than just this task.
To those that have done this, is it safe to reuse the nuts/bolts for the control arms? I know the strut to steering knuckle bolts are single use so at minimum ill will be getting those.
2011 Subaru Impreza WRX Limited 4DR - Dark Grey Metallic
2009.1 G8 GT - Panther Black Metallic, Sport and Premium Packages - TRADED IN 9-9-11
DilligafDave is offline   Reply With Quote
Old 01-07-2011, 01:08 AM   #8
JCMG8
actually, the best deal is at drcustomparts dot com. He sells a set of DVD's that are the GM service software used in dealerships. They contain all GM vehicles from 90 something thru 2009 or 2010. It's the real deal, TSBs and search based on part name, flow charts etc. at the bottom of the prices section.
ICOM 208H
Old 01-07-2011, 10:16 AM   #9
J2_GXP8
I have done many, and it is safe to re-use the hardware..
J2_GXP8 is offline   Reply With Quote
Old 01-08-2011, 01:37 PM   #10
DilligafDave
Would you re-use the single use bolts too?
Old 01-08-2011, 02:42 PM   #11
J2_GXP8
Yep... I have I just make sure I torque them to spec, just don't over torque them
Old 05-24-2012, 10:15 AM   #12
Dictatorsaurus
Dictatorsaurus's Avatar
Anyone has a DIY write to replace the lower control arms?
Dictatorsaurus is offline   Reply With Quote
Old 05-24-2012, 01:34 PM   #13
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
According to GM you don't need an alignment.... lol… I agree with you though.
Old: 353.8
New: 632/530 Mustang Dyno
Old 11-17-2012, 08:03 AM   #14
Dictatorsaurus
I'm looking to replace the front control arm. What ball joint tool is needed? is it something advance auto or harbors freight would carry?
Old 11-17-2012, 12:35 PM   #15
dandragonrage
Plastidip is awful
I have 5 different ball joint tools myself but the one I used for this car is the one from Harbor Freight. Thing is, I had to modify it a bit with my Dremel to open it up. It won't fit stock, and I'm not really sure what would :/ Advance and Autozone carry a few
BTW, get a ratcheting "Cross Force" 18mm wrench. The ones that have a twist in them. I had a set of those but it, like many wrench sets, it skipped the 18mm...
Going to be trading in my G8 in January or February, 2013. It's been a good run. Thanks all. See you in the for-sale section soon as I pawn off some parts...
Car audio sale - now | Wheels & parts sale - soon
dandragonrage is offline   Reply With Quote
Old 11-17-2012, 07:48 PM   #16
hayabusa160
No tool is needed for ball joints smack the pad with a hammer
http://www.g8board.com/forums/signaturepics/sigpic4288_1.gif
Kooks long tubes, Kooks axle backs, rotofab cai, ported tb, koni yellow shocks, h&r springs, bmr bushings kit, rear toe and traction arms. Bmr sway bars. forgestar f10 20x9.5 35 offset 275/30/20, 20x10.5 42 offset 285/30/20
hayabusa160 is offline   Reply With Quote
Old 11-17-2012, 07:59 PM   #17
Virus
Capital City G8
Virus's Avatar
For the most part that's true, however there isn't a lot of room to get the leverage/impact you need should it be stubborn. My passenger side was stubborn and it was not coming out with a hammer of any type. I had to get some type of ball joint pry bar to get it out. My club has had to use a pry bar on a few of our cars, but normally just a hammer will work fine.
Performance mods: Roto-Fab CAI, Rick Crawford head work, Rick Crawford Ported Intake Manifold, Kooks 1 7/8 LT's, Solo catted Mach Balance exhaust, 226/230 .598/.608 113+1 Cam, BMR complete bushing kit, BMR Toe Rods, BMR Trailing Arms, Pedders caster, camber & toe adjustment kits, BMR Sway Bars, BMR Sway Bar End Links, Camaro Brembo's w/custom powder coating. 11.90@116.58 1.78 60'
Old 11-19-2012, 04:54 PM   #18
dandragonrage
Plastidip is awful
Works sometimes, and a lot of the time you just need to figure out the right angle/place to strike, but this does NOT always work. Do NOT attempt this job without a ball joint separator available, because when you get to the fourth ball joint and realize that even though the other 3 came out with little issue, this one won't, you'll be screwed.
Old 11-20-2012, 08:56 AM   #19
Dictatorsaurus
Does a pickle fork work to separate the control arm?
Old 11-20-2012, 09:25 AM   #20
dandragonrage
Plastidip is awful
I'd expect that would work if you have the right size one (not sure which that would be). Not as big a fan of those myself though. I have one but I don't think I tried it on my car.
