255/40/18 - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Wheels / Tires
Wheels / Tires Sponsored by: Discount Tire
Old 07-08-2011, 11:10 AM   #1
shaker954
shaker954's Avatar
Talking 255/40/18
WILL A 255/40/18 FIT ALL THE WAY AROUND ON THE G8 WITH STOCK RIMS AND NO SPACER ,JUST WANT TO THROW SOME TIRES ON .THANKS GUYS
shaker954 is offline   Reply With Quote
Old 07-08-2011, 12:36 PM   #2
Turbo301
Turbo301's Avatar
Should be no problem. I'm thinking of getting 255/45R18 as my next tires (a bit taller to improve tire life and fuel economy ^_^).
2009 G8 GT in MSM: no sunroof, no sport package, no leather... just the standard-equipment "yee haw"!
Mods: K&N air filter, AEM Brute Force short-ram, Solo Mach Balanced + HFCs + resonators, Livernois ECM/TCM tune(s), gorgeous wife mod
Other cars:
1996 Caprice Classic: dark cherry, LT1, B4U
1977 Mercury Cougar XR7: light jade metallic, rare 302/low-option Ontario car
Turbo301 is offline   Reply With Quote
Old 07-08-2011, 01:37 PM   #3
juspimpin
juspimpin's Avatar
changing to 255/40/18 will fit, but the tires will be smaller in diameter making the speedo show faster than actually traveling. The difference will be about 2.5% meaning when your speedo shows 70, you will actually be going about 68. It is not a big change and the increased width is about 3/8 inch. Half of that will be inside the wheel well. I think 255s look better than 245s on stock rims, but I would go 255/45/18 if I were you. The difference there would be 1% the other way. 70 on the speedo would be almost 71 real speed.
09 GT, Stryker Blue, Sport/Prem
07 Solstice GXP, Mean Yellow, tuned
03 Excursion, 6" Fab lift, V10, 37s
94 Bronco, 5.8L, 35s and rust
03 RC51
juspimpin is offline   Reply With Quote
Old 07-08-2011, 02:38 PM   #4
Gordon0652
Do 255/45/18
2000 Maple Red Metallic Trans Am A4, Grandfather Left It To Me
LME 440 LS7|TSP LXR 285cc LS7x|278/286 .718 .702 112+4|Becks 115mm|Direct Port|D&D T56 Mag|McLeod RXT
2009.5 Pontiac G8 GT SMR||KOOKs 1-7/8"|Corsa|VaraRam|223/231 .610/.617 115+4
Gordon0652 is offline   Reply With Quote
Old 07-08-2011, 05:48 PM   #5
shaker954
shaker954's Avatar
U guys are great thanks alot . I thought I would have to do 40s because of rubbing . But if 255/45/18 don't rub , well that sounds better . I just didnt want to add any spacers
Old 01-09-2013, 04:45 PM   #6
GT_ONT
GT_ONT's Avatar
Shaker954: Did the 255/45/18 work out ? I'm considering a new BF Goodrich G-Force Sport Comp 2 summer in this exact size on an '09 G8 GT. Tire Rack rates this tire exceptionally well.
GT_Ont.
GT_ONT is offline   Reply With Quote
Old 01-09-2013, 10:58 PM   #7
shaker954
shaker954's Avatar
I will let u know , tires are at buddy's house , going tomorrow
Old 01-09-2013, 11:34 PM   #8
Knothead
Knothead's Avatar
265/40/18 doesn't rub with the stock wheels and stock ride height.
Knothead is offline   Reply With Quote
Old 01-10-2013, 12:18 AM   #9
shaker954
shaker954's Avatar
255/45/18 all the way around, works,
Old 01-10-2013, 01:23 AM   #10
RJKmotion
RJKmotion's Avatar
You need to consider how wide of wheel you are using and manufacture of tire max width range for rim width size. If u start going wider tire on a wheel that is too narrow you are going to destroy the edges of the tires.
RJKmotion is offline   Reply With Quote
Old 01-10-2013, 08:23 AM   #11
shaker954
shaker954's Avatar
I never had a problem , ran them for a year untill I got my camaro rims , car looks good with 255 all the way around
Old 01-10-2013, 08:28 AM   #12
Monty
Monty's Avatar
Shame I missed this thread. I've been running 255/45/18's General UHP tires on chromed 6 Cyl rims for 2 years now without any problems.
09 G8GT SwitchBlade Silver/Sunroof:
SSV Z-Series ll rims (Chevy SS rims), GXP rear diffuser, Chrome G8 gas cap cover, Console sliding leather lid, Holden Engine Covers, Intake cover delete, Automatic dimming mirror, Holden VE Onyx Leather Sports Steering Wheel, SLP spoiler
RotoFab CAI, HSRK, MagnaFlow cat back, Kooks 1 7/8 mids w/HFC, GXP Brembos with drilled rotors, VMS Stage 2 tuned, Mobil 1
60'-1.954 1/4-12.753 @ 109.42mph
Monty is offline   Reply With Quote
Old 01-10-2013, 08:36 AM   #13
sweetair
How much wider than a 255 would you go on a 8" wide rim?
sweetair is offline   Reply With Quote
Old 01-10-2013, 09:29 AM   #14
Monty
Monty's Avatar
On our stock rim you could probably get away with 265/40. I would say a 265/45 would be too tall.
Old 01-10-2013, 09:39 AM   #15
Monte8009G8GT
Monte8009G8GT's Avatar
Yes 265 is probably the max on stock rim, I run NT05s 265/35 all around. No rubbing and im lowered on H&R springs. Though im pretty sure I heard/read of someone getting a 275 on it, But thats pushing it.
2009 G8GT:
364--forged rods/pistons stock crank.(Rick Crawford) Ported Heads,(Modified) Intake, TB. Vararam, Custom Cam, Kooks 1 3/4 LT, 2.5in custom exhaust, Yank 3000 TC, BMR SFC, H&R Springs. DDM HID's 8k-LB 3k-Fogs.
Dynoed 435whp 386wtrq with above setup 12.8@116 2.2 60ft BTTD.
Cam,Stall,LTH,CAI,Tune. Best time 12.7@110 1.9 60ft. Old Setup.
Dynoed 370whp 380wtrq
(w/LTH,CAI,Tune)Best time 13.1@105 Old Setup.
Monte8009G8GT is offline   Reply With Quote
Old 01-10-2013, 10:08 AM   #16
Monty
Monty's Avatar
As an example on the front I can just about get a finger between the top of the tire and the spring plate. On the inside I'm about a 1/4 in away from the strut. Plenty of room in the back so as Monte said you can go with a 275 on a stock rim.
Old 01-10-2013, 03:31 PM   #17
shaker954
shaker954's Avatar
I had at one point 275s on rear , buddy of mine gave them to me . They were low pro... I don't remember side wall size ...... Car looked mean from back , wide stance
Old 01-10-2013, 07:39 PM   #18
jpG8GT
jpG8GT's Avatar
Here is how my 275-35-18 fits on a stock 18. These are my Pilot PS2 track tires and wheels. They fit with very little sidewall hanging out. Almost a perfect fit. I have a set of 285-35-18s that I'm gonna mount on back.
Sent from my fresh lubed iPhone
File Type: jpg ImageUploadedByAutoguide1357864722.503465.jpg (6.7 KB, 57 views)
2009.1 Evoke Gray GT prem. sport no roof. CTS-V Brembos front and rear with CTS-V wheels, FE3 and Eibachs, Grill mod with custom brake coolers. Tranny cooler, Power steering cooler, RotoFab Intake. Pacesetter LTs, Custom Hooker MaxFlow Axlebacks, SS clone tips. HP Tuners and Rick Crawford tuned with Little Lunati Cam.
jpG8GT is offline   Reply With Quote
Old 01-10-2013, 08:02 PM   #19
shaker954
shaker954's Avatar
Sick ...... I have 285/30/20 Invos on my camaro 20s
Old 01-10-2013, 08:18 PM   #20
shaker954
shaker954's Avatar
The pilots are good tires
