transmission fluid change - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Drivetrain Tech
Drivetrain Tech 5L40 A5 / 6L80 A6 / TR6060 M6 / ZF Rear Diff
Old 11-02-2011, 12:20 AM   #1
JetSnake
JetSnake's Avatar
Default transmission fluid change
I plan on dropping the pan to change the oil and the filter, but without a dip stick, I was wondering how to fill the transmission. I never looked at it yet, but didn't know if I need a special tool for this.
My Audio System
http://www.g8board.com/forums/showthread.php?t=25630
JetSnake is offline   Reply With Quote
Old 11-02-2011, 02:35 AM   #2
Shift12
Shift12's Avatar
When I am ready to get this done I am having the dealer do this. The 6L80E is a sealed unit which means checking the fluid is not required. And even so I have not found the filler neck on mine if there is one...
-Rob
2008 White Hot GT w/ Premium Pkg.
Drag DR-37 Hyper Silver 18x8.5 +40 w/ 255/45 Motivo
35% Tint, Holden "V8" Emblems, Custom Painted MGM/MSM engine cover, FE3, Spectre CAI, SC Flashpaq, X-pipe
+reso delete+ GXP Mufflers, GXP Diffuser
Shift12 is offline   Reply With Quote
Old 11-02-2011, 07:09 AM   #3
wawazat
I believe it is set up like a manual transmission. There should be a fill hole on the side of the transmission body. You just fill it with fluid until it starts coming out the fill hole.
Im about to do my transmission and diff fluid change as well.
wawazat is offline   Reply With Quote
Old 11-02-2011, 08:49 AM   #4
SRG963
Its Good To Be Tha King
SRG963's Avatar
I've been told to flush the system, including filter. Filter is metal I believe.
Trigger - Fully Loaded 2008 Stealth Blue Pontiac G8 GT
Rotofab/Cortex/BMR/Pedders/VMR/
Adams/OBX/Nitto
PRAISE THE LOWERED
SRG963 is offline   Reply With Quote
Old 11-02-2011, 09:48 AM   #5
bostonf4$
I would DEF have the dealer do it, especially if you're in warranty range - they will flush the system and clean the filter and will use the correct GM fluid, its worth having them do it for peace of mind IMO
Old 11-02-2011, 10:13 AM   #6
btr1208
btr1208's Avatar
I went to the dealer yesterday to have this done, i was out of warranty and they still did it for free!
btr1208 is offline   Reply With Quote
Old 11-02-2011, 02:47 PM   #7
SRG963
SRG963's Avatar
^You got hooked up my friend! I had to pay at 45k, and I'm assuming I'll have to pay again next time at 90k
But hey, I get free cappuccino lol
Adams/OBX/Nitto
PRAISE THE LOWERED
Old 11-02-2011, 02:52 PM   #8
millatime84
How much did the deal charge for this?
G8 GXP WH A6 O/O with roof #230
Stock SBM GT w/ Prem/Sport - sold
millatime84 is offline   Reply With Quote
Old 11-02-2011, 03:10 PM   #9
SRG963
SRG963's Avatar
Most dealerships will have coupons on their website. Find the closest GM dealership with such coupon and save.
I had a 20% off voucher, can't remember how much I paid tho.
Adams/OBX/Nitto
PRAISE THE LOWERED
Old 11-02-2011, 05:48 PM   #10
thebeast
dealer wanted 250 for a tranny flush. my buddy has the auot tranny machine and.did it for 100
2008 LR G8 GT
TSP Forged LS3-D1-221/232 RCR Cam-Ported L92's-Squash-Kooks-Solo 3in-BMR-SS wheels and brakes-Kicker-Demon 8 Designs Gauge Pod-BC Racing Coilovers- Custom Earls Tranny Cooler
613/543 old worn out numbers
11.6 at 123 1.92 60ft
New numbers coming soon..........
thebeast is offline   Reply With Quote
Old 11-02-2011, 06:29 PM   #11
SMSO966
Supercharged Moderator
SMSO966's Avatar
Did mine today. The filter that O'Riley specified was wrong. It was for a 6L80E, but not for the g8's shallow pan. I used solvent to rinse out my old filter and re-used it. I called the GM dealer, but they were not showing the part # in the computer that was stamped on the AC Delco filter I was holding in my hand. (24235900)
To re-fill, I just put a tip off of a gear oil bottle onto what ever quart I was using at the time, attached a rubber hose, and stuck it in the filler / dipstick hole on the right side of the tranny and squeezed the bottle. There is a easily removable / replaceable rubber plug blocking the hole. You know it's full when fluid comes out of the hole in the middle of the pan after getting the tranny up to temp. There is a picture on the bottom of the tranny pan that depicts how to determine if it is full.
DD: 08 White Hot G8 GT Best E.T. 12.698 @ 109.1 MPH
VMR 20's 4 Wheel 04 CTS-V Brembo's
FE3 & Eibach,
Roto Fab,Doug Thorley LTs Magnaflow
1 of 1,086 2008 White Hot Pontiac G8 GT's
Garage Queen:
09 Stryker Blue G8 GT (No ET Under construction)
TVS1900, GXP 19's, 4 Wheel 09 CTS-V Brembo's
Rotofab, Solo, More to come soon!
Sold!
SMSO966 is offline   Reply With Quote
Old 11-02-2011, 07:54 PM   #12
romeyjdogg
How often do you really need to change trans/diff fluid?
2009 G8 GT
35W HID, LED fogs, custom front/rear Pontiac symbol badges, sharkfin, BlueStar Bluetooth, GXP front end, GXP diffuser, x-pipe, straight through mufflers with helmholtz chambers, RotoFab intake , Eibach springs, FE3 shocks/struts, BMR rear subframe inserts
romeyjdogg is offline   Reply With Quote
Old 11-02-2011, 10:17 PM   #13
HotRodG8
HotRodG8's Avatar
The tranny is a seal unit... The best way is a flush... the unit flushes All the fluid from the filter and converter, valve body, etc. not just the couple quarts you get by dropping the pan....
Owner @ MJD Performance "If you can dream it, we can build it"
2009 PBM G8 GT
Premium, Sport, Sunroof
LS3 Swapped
Lingenfelter Ported Heads
MJD Performance Custom Cam
RotoFab CAI
American Racing headers w/ GXP mufflers
PATC Custom 3400 Stall
Built 6L80e with 6L90e internals
FE3 Suspension
CTSV Coupe Wheels with Michelin PS2 rubber
473hp/459tq NA
--All New Setup in the work's for 2015 !!--
HotRodG8 is offline   Reply With Quote
Old 11-02-2011, 11:06 PM   #14
SMSO966
SMSO966's Avatar
I did mine with almost 60,000 miles. A complete flush is better, but the fluid didn't look that bad and there was hardly any sludge on my magnet. I completely cleaned the pan, flushed my filter with solvent, and put 5 quarts of synthetic fluid back in.
Better than nothing and only cost $40.00. I will try to do a full flush at 100,000.
FE3 & Eibach,
Garage Queen:
Sold!
Old 11-02-2011, 11:21 PM   #15
Titanws6
Titanws6's Avatar
My buddy works at a Chevy dealer, had him do the flush at 56k miles.
I stood and watched, and the fluid coming out was pretty dirty compared to the bright red fluid going in. I think I paid $140 for the flush, good peace of mind knowing it has been done now and good for another 50k miles.
'14 SS MYSTIC GREEN 1 OF 11 OPTIONED-STOCK FOR NOW
'09 GXP MSM M6 #1123 - #30 of 38 OPTIONED KOOKS, VCM, VMAX, PAT G TUNED.....SOLD
'08 G8 GT IOM S/P-VCM-OBX-UDP-TUNE...362/375....SOLD
'00 Formula WS6 Hardtop M6 1 0f 233...GONE
'12 FRONTIER KC PRO-4X, M6, LOCKING DIFF, BILSTEINS..SOLD
'06 SAAB 9-7x 5.3...SOLD
Titanws6 is offline   Reply With Quote
Old 11-03-2011, 06:59 PM   #16
GMCustomerService
GMCustomerService's Avatar
@btr1208, that is very cool. Seems as though you may have found a "keeper" for a dealership.
I hope that you are having a great evening.
Michelle, GM Customer Service
GMCustomerService is online now   Reply With Quote
Old 11-04-2011, 02:41 PM   #17
Gavine
Gavine's Avatar
I think this is the fill plug SMSO966 is talking about (circled it in red)....
Roof Spoiler, Catch Can, Rear Subframe Inserts, Poly Bushings (Strut Mounts, Steering Rack, Sway Bars)
Check-out our Disney Vacation Rental Home -->
http://www.emeraldislandgem.com
Gavine is offline   Reply With Quote
Old 12-22-2012, 08:23 PM   #18
Skittledg8
Skittledg8's Avatar
i want to do my trans flush and diff fluid chamged my car has 80k what are your thoughts on doing this
Skittledg8 is offline   Reply With Quote
Old 12-23-2012, 10:19 PM   #19
todds87ss
Car RamRod
todds87ss's Avatar
you have not tried it, have you?
A flush does not change the filter. For the price of a dealer flush, you can get the camaro deep sump pan and filter (PACE), buy the 8 quarts of synthetic fluid, and still have enough for a six pack of beer.
"couple of quarts..." hmmm...
You can choose to be anything you want on the internet...why choose to be so stupid!
todds87ss is offline   Reply With Quote
Old 12-26-2012, 03:21 PM   #20
M23G8GT
In other vehicles (non GM), I have always loosed the tranny pan bolts and then drain. Change out filter, clean off pan magnet, wipe out bottom of pan, measure what came out, and add that amount back in. I've done that every 30k on a few of my cars and trans are still running strong another 100k+ later.
I have yet to do the G8 and I'm sitting at 96k. I know I'm due so I probably use the same method. Never heard anything good about flushes- seems like it would just move all the contaminates around and filter out very little.
M23G8GT is offline   Reply With Quote
