PCV System Questions - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Community > Lounge
Old 01-07-2012, 10:45 AM   #1
oddstuff63
oddstuff63's Avatar
Default PCV System Questions
I just picked up a really well maintained Lexus RX300 with the standard issue 3.0L Toyota engine. I've been reading a lot and see that these engines have been prone to sludging issues (or gelling as some call it). Apparently it has to do with an inadequate PCV system design: http://www.toyoland.com/sludge.html
While mine hasn't exhibited any of the symptoms (yet) I was wondering if there's any proactive measures one could take to minimize the risk. I understand running full synthetic virtually eliminates the risk but my concern is if the engine has some sludge in it won't going to full synthetic with its high detergent properties possibly loosen the sludge and block oil passages, oil pickup tube, etc? On my older, normally aspirated engines I used to run a qurt of kerosene thru it for a 15 minute parked idle prior to changing oil and filter to "clean" the inside of the engine. I hesitate to do that with newer engines though.
Do you think one solution would be to run a valve cover breather filter in lieu of the oil fill cap? What effect (good or bad) could that have? Would it screw up any electronically monitored signals (MAP, etc)?
Thanks for any thoughts.
oddstuff63 is offline   Reply With Quote
Old 01-07-2012, 10:51 AM   #2
Silvereagle
Drives with wolves
Silvereagle's Avatar
Read up on using "Auto Rx" long time engine cleaning system.
2009 G8GT - premium and sport package - PSM 1 - of 1063. Magnaflow catback 16887, Rotofab, VVME HID 6k, Cortex Rotofab 91 tuned
Silvereagle is offline   Reply With Quote
Old 01-07-2012, 11:40 AM   #3
Screw991le
Red Sox Nation !!!
Screw991le's Avatar
Their are so many additives out there, it is hard to believe which works.
Any experience with this product, first hand?
2010 Steel Gray MB E63 AMG
Screw991le is offline   Reply With Quote
