Front Driver Door Handle Removal - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Appearance / Detailing
Old 01-31-2012, 05:37 AM   #1
SavageStag
SavageStag's Avatar
Default Front Driver Door Handle Removal
I am repairing my keyed doors and I need to removal the door handles. The other doors without the lock are easy but how do you remove the one with the lock? I will be doing a tutorial on DIY scratch repair if it turns out right.
Thanks a lot guys. BTW I have already read this...
http://www.g8board.com/forums/showthread.php?t=19041
2009 PBM GT de-badged except Arrows (tinted centers), 35% Headlight armor foglight tint, Black Euro corners, PD'd grille surrounds, Diamo 19's, Dry Roto-Fab, SLP LT's, Straight mid pipes with "H" connection, Kook's axle back, VMS Tuned, H&R springs.
SavageStag is offline   Reply With Quote
Old 01-31-2012, 01:22 PM   #2
SmokeyBear911
SmokeyBear911's Avatar
I been wanting to do the same...
If you figure it out please post or PM thanks...
Liquid Red GXP, Sun and stick !
#611 of 1829
SmokeyBear911 is offline   Reply With Quote
Old 01-31-2012, 03:55 PM   #3
SavageStag
SavageStag's Avatar
Will do Smokey. Someone has to know how.
Old 01-31-2012, 06:49 PM   #4
pic18
Enthusiast
pic18's Avatar
I changed out all of my door handles. The front driver door was similar to the others. I don't remember exactly what I had to do, but a semi handy person with good common sense can do it. I think I had to pop the lock out of the back of the handle. I was a little worried about it, but I got through it. If you're willing to go forward, I think you'll make it through.
2008 MGM G8GT no mods, I'm the first and third owner! Just glad to be driving a G8 again!
pic18 is offline   Reply With Quote
Old 01-31-2012, 07:08 PM   #5
mikemaj82
it's not difficult at all. I did it on mine when somebody broke the lock with a screwdriver. I got a paint-matched cap to put over the lock cylinder so it isn't visible anymore. there are a few threads about it as well as some videos. i did it a while ago so I don't remember the exact steps, but it isn't much different from the other handles.
mikemaj82 is offline   Reply With Quote
Old 01-31-2012, 08:27 PM   #6
GOPHERIT
I read that all door handle removal procedures are the same except for a couple of steps. That door would be the only one that has the added lock actuating rod. Disconnect that rod from the lock cylinder, then remove the blanking plug on the end of the door to allow removal the "lock cylinder retaining bolt, then remove the lock cylinder from the outside door handle. That same retaining bolt on the other doors does the same thing to secure the handle, but without the cylinder lock in there. At least that's the way I read it.
Old 01-31-2012, 08:53 PM   #7
SmokeyBear911
Well I guess I'll try it...
I need to plastidip it...
It's the only one not done... lol
I need to redo them...
I was a n00b with my Adams Portacable and didn't' mask them off...
#611 of 1829
Old 02-01-2012, 03:12 PM   #8
SavageStag
SavageStag's Avatar
Ok so that little plastic piece surrounding the lock pops right off, which is perfect if you're plasti-dipping it. But in order to re-clear the door I'm going to have to figure out how to get the lock mechanism itself off.
Old 02-01-2012, 05:23 PM   #9
TomPierce
Owner / Operator
TomPierce's Avatar
Front Side Door Outside Handle Replacement
Removal Procedure
Remove the door trim panel. Refer to Front Side Door Trim Panel Replacement (See: Front Door Panel\Service and Repair) .
Pull the rear half of the water deflector away from the door panel in order to access the outside door handle.
Important: Pry the outside door handle rod retaining clip (1) using a suitable tool.
Disconnect the outside door handle rod (2) from the door handle rod retaining clip (1).
Remove the lock actuating rod (1) from the lock cylinder (2) (if fitted).
Important: Remove the rubber blanking grommet to allow access to the retaining bolt (1).
Remove the outside door handle to door retaining bolt (1).
Important: Replace the gaskets (2, 3) when replacing the outside door handle (1, 4).
Remove the outside door handle (1, 4) from the door.
Important: The outside door handle retaining nut (1) must be loosened to remove the inner part of the outer door handle.
Loosen the outside door handle retaining nut (1).
Push on the outside door handle retaining nut and stud to relieve pressure between the inner part of the door handle and the door.
Important: Push the retaining tabs (2) inwards to release them then push the inner handle towards the front of the car to release the retaining pin (1).
Remove the inner part of the outer door handle (1, 2).
Remove the inner part (1) of the outer door handle from the door (2).
2008 MGM G8 GT - #615 of 888 - Premium/Sport - 12.6 @ 111 on stock tires
SHOW - Chromed Wheels - Color Matched Splash Guards - Debadged - G8 Tail Lights - GXP Diffuser - Painted Calipers - Under Hood Lights - too much Zaino
GO - ARH Long Tube Headers / Midpipes - BMR Front / Rear Swaybars - Camaro 3.45 diff - Custom non-DOD Cam and Valvetrain - Homegrown PCM / TCM Tuning - K&N Filter - Pedders 'Fruit' Suspension - Yella Terra Intake - Stealth Airbox
TomPierce is offline   Reply With Quote
Old 02-01-2012, 05:25 PM   #10
TomPierce
Owner / Operator
TomPierce's Avatar
Door Lock Cylinder Replacement
Removal Procedure
Important: Do not attempt repairs in order to correct lock cylinder discrepancies. Replace the lock cylinder.
Remove the door trim panel. Refer to Front Side Door Trim Panel Replacement (See: Doors, Hood and Trunk\Front Door Panel\Service and Repair) .
Pull the rear half of the water deflector away from the drivers door panel in order to access the door lock cylinder.
Remove the lock actuating rod (1) from the lock cylinder (2).
Important: Remove the rubber blanking grommet to expose lock cylinder retaining bolt (1).
Remove the lock cylinder to outside door handle retaining bolt (1).
Remove the lock cylinder (2) from the outside door handle (1).
Old 02-02-2012, 02:21 AM   #11
SmokeyBear911
wow Tom...
so crystal clear...
#611 of 1829
Old 02-02-2012, 02:23 AM   #12
SmokeyBear911
I figured out the 3...
Will video the drivers door when I do it...
[YOUTUBE]http://youtu.be/uB5XrZb-6Pk?hd=1[/YOUTUBE]
#611 of 1829
Old 02-02-2012, 04:06 AM   #13
SavageStag
SavageStag's Avatar
Thanks for the help guys. I really don't wan to remove the door panel so I will just clear it with it in place. It will be hidden by the handle so it doesn't really matter much.
Old 07-07-2013, 02:27 PM   #14
djerickd
G8/LSX n00b
any one have the rubber blanking grommet part number?
09.1 G8 GT, 20x9.5/10 RD Sport RS-5's, 255/30 & 275/30 sumitomos, magnaflow catback, Kooks mids w/cats, Crawford ported TB/manifold, Spectre 4"/LS7 MAF, Rotofab, HID's, Aussie SV6 tails, GXP front bumper, GXP rear diffuser, BMR strut bushings/cradle inserts/sway, Megan Coils, CTS-V 6/4pot Brembos, HSV steering wheel, Klearz corners, HSV map lights, CHenry splitters/tuned
djerickd is offline   Reply With Quote
