Oil your using? Duration you use? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 07-26-2012, 02:11 PM   #1
EMS Guy
Default Oil your using? Duration you use?
Reading GM's manual for the car, it appears 5W30 API approved oil is recommended. What brands are you using? Motul? Mobil 1? etc....What duration are you changing it?
PLEASE DON'T tell me you follow the dummy oil change light.
EMS Guy is offline   Reply With Quote
Old 07-26-2012, 02:22 PM   #2
PSMG8GT
PSMG8GT's Avatar
The search function has more than enough oil thread results for you to research off of.
MODS:
CORSA CATBACK EXHAUST
DBA 4000 SLOTTED ROTORS W/ HAWK CERAMIC PADS
GXP DIFFUSER
FULLY DEBADGED
TSW NURBURGRING 20X8.5/9.5 WITH NITTO INVO 255/35 285/30
PSMG8GT is offline   Reply With Quote
Old 07-26-2012, 02:25 PM   #3
Silver Bullet
Super Moderator
Silver Bullet's Avatar
I use the supertech 20w 50 and I just change it when my light tells me to.
lol...ok not really
I have only changed my oil once since I got the car and I used penzoil ultra 5W20 and have gone about 4k miles on it so far. Ill probly change it at around 8k or so. Not to say you should base your decisions off of anything I do though. I dont claim to be an oil god by any means.
-2009.5 MSM Premium GT-
Mods: Brembos, OBX Headers to Maxflows, VCM, RCR Intake, HSRK, LS7 Maf and tuned by Pat G.
In The Garage: Yank 2800 stall, SLP UDP, Pedders Coilovers
10.59 at 100.31 in the 1000.....8.33 at 88.13 in the 1/8....1.99 60 ft
Silver Bullet is offline   Reply With Quote
Old 07-26-2012, 02:47 PM   #4
EMS Guy
lol...ok not really
Why did you adjust your duration? Curious.....
I adjusted my specs on the previous car to 5w30 from 0w20 and duration to 5K miles +
Old 07-26-2012, 03:04 PM   #5
Silver Bullet
Super Moderator
I have been seeing where good synthetic oils are lasting 7-10k between changes. Plus our engines hold right at 9 quarts and I would assume the more oil the longer it takes for it to be broken down. 8 just seems like a safe place to change it out.
Old 07-26-2012, 03:40 PM   #6
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Pennzoil 5w30 conventional, i change the oil whenever the OLM says "service oil", which can be anywhere from 7k-10k miles in my case, once i get the cam i'm thinking to get, i'll switch to GC 0w30(syn oil), much better oil pressure from 6000rpm and up, which the bearings always love.
There, change the oil whenever the dummy oil light says so , really, or whenever you like to change it., either way.
Old 07-26-2012, 04:32 PM   #7
PSM09
Tail o'the Dragon Action!
PSM09's Avatar
Have used Mobil1 5w30 Dexos-approved, changed when the dash tells me. But I will be changing to Quaker State Ultimate Durability 5w30 next time. Why? There is a site you can find by searching "Bobistheoilguy" that has a ton of information that leads me to believe that the QS is at least equal to the Mobil1 and it is also Dexos approved. Oh, and it is $6 cheaper than Mobil1 per 5 quart container at Wal-Mart.
Tail of the Dragon-car's not lowered, just leanin'
Pat
ASE Certified Master Tech, over 30 years
2009 G8 GT
Pacific Slate Metallic ( who came up with that name?)
1 of 1063 GTs this color
Premium Package, Sunroof and All-Seasons, no Sport
ClearMask, BMR rear subrame mounts and Advanced 2-way Remote, self installed
BrakePerformance.com slotted and dimpled rotors plus Carbotech 1521 pads all around
Dead stock otherwise
PSM09 is offline   Reply With Quote
Old 07-26-2012, 04:39 PM   #8
Camss57
Camss57's Avatar
5W-30 Castrol Edge every 5K.
Camss57 is offline   Reply With Quote
Old 07-26-2012, 04:41 PM   #9
dandragonrage
Plastidip is awful
Major waste with such a good oil, especially with double the oil capacity that most cars have.
I change my oil twice a year, which comes out to around 7-10k.
Going to be trading in my G8 in January or February, 2013. It's been a good run. Thanks all. See you in the for-sale section soon as I pawn off some parts...
Car audio sale - now | Wheels & parts sale - soon
dandragonrage is offline   Reply With Quote
Old 07-26-2012, 07:18 PM   #10
sport red GT
penzoil platinum 5w30. I usually change it when the OLM is around 50% which is usually around 5K miles.
sport red GT is offline   Reply With Quote
Old 07-26-2012, 07:41 PM   #11
BenG8
2008 G8 GT
BenG8's Avatar
Mobil 1 0W-30
I wait until the Oil Life Meter gets to under 10-2% remaining.
Once I use up the Mobil1 I have left, I'll use either the Castrol Edge or the Fram Full Synthetic I got. I'm not too picky/choosy about oil.
BenG8 is offline   Reply With Quote
Old 07-27-2012, 02:12 AM   #12
blkscooby
blkscooby's Avatar
Amsoil 5W-30. Change around 12k with their filter. Soon will be the trans and diff to since I just hit 50k miles.
NEW- 2009 PSM GT- Vararam/ RCR 219/227 cam/ Kooks 1 7/8" LT/ 3" exhaust/ 3200 Yank/ 3.45 gears/ HSW Nitrous/ HPT self-tune
SOLD- 2008 LR G8 GT /
Intake / HPT self-tune / E85 / 160* stat / Kooks mids / Dynomax ST axlebacks / Xpipe / 219/233 Comp Cam
blkscooby is offline   Reply With Quote
Old 07-27-2012, 11:07 AM   #13
EMS Guy
Mobil1 is Dexos approved.
http://www.gmdexos.com/licensedbrand...sedbrands.html
Where can I view my OLM? Just got the car on Monday.......
Originally Posted by BenG8 View Post
Mobil 1 0W-30
Huh.....
Yeah.....I will be there next year. 35K now.
Old 07-27-2012, 11:14 AM   #14
zepcom
Hold down the left steering wheel scroll bar (enter key function) when cranking. Instead of the usual DIC LCD screen that you're used to, you will find "Engineering mode".
Use the same scroll wheel up and down to cycle through the extended information that it supplies. Throttle Position Percentage is a fun one! But Engine Oil Life in % is there in one of those options. Don't trust the battery percentage one, people have found it to vary widely.
If you press the road button on the steering wheel, you exit out of engineering mode, and can't get back in until another ignition-start cycle with the enter key pressed.
Hope this helps.
--zepcom
2009.1 ZEPCOM MGM G8 GT
www.youtube.com/zepcom
Old 07-27-2012, 11:21 AM   #15
EMS Guy
Hope this helps.
--zepcom
Just tried. It didn't work for me. I am gonna try again.
Old 07-27-2012, 11:23 AM   #16
EMS Guy
No dice again! I have an 09 if that matters.
Old 07-27-2012, 11:25 AM   #17
zepcom
Hold down the scroll wheel with thumb while using other hand to crank with key.
Old 07-27-2012, 11:30 AM   #18
EMS Guy
That's what I did. I will try again./
Old 07-27-2012, 11:33 AM   #19
jackalope
jackalope's Avatar
Another oil thread?
Old 07-27-2012, 11:35 AM   #20
EMS Guy
Got it after about 4 tries just now! NICE. Thanks.
