This twin turbo monster will be the end of me! - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Intake/Fuel Tech
Intake/Fuel Tech CAI, TBI, Porting, Forced Induction, Nitrous Oxide...
Old 08-18-2012, 01:45 AM   #1
adamsar
adamsar's Avatar
Default This twin turbo monster will be the end of me!
So when I got my car I was in love hell I still am. I loved catching people of guard who slept on the hidden goodies, but last year my engine blew because of my boost controller dying and my motor not liking 20+lbs of boost. Over the last year I had been slowly and carefully rebuilding the car the way I wanted it. It started out with picking the engine the guys at CMS set me up with a forged stock displacement LS3 with a 9.5ish CR, little more power from the motor but could handle more boost. Then we made the turbo exhaust side a little bigger during the rebuilding, next changed the boost controller to the center cubby mounted Eboost2 setup, sent the 3200 stall to be dialed in again at Circle D, popped in some Gforce racing axles and BMR Bushings. Every time I looked up I was trying to make this thing even more insane. So as I come to the end of this build I have just a short list of things to do.
Mechanical
- Tune the car
Take it to the track and get into the 9s.
Cosmetics
- GXP front bumper
- Bathhurst stripe kit (Silver)
- ZL1 replica wheels
- HDPE radiator cover (making this also, borrowed idea from the other forum.)
Help me out guys is there any other weak points I didnt get to or any other suggestions that could help make this car a little better? Ask any questions.
2009 G8 GT Twin Turbo
Forged LS3, 6465 turbos, Tial 38mm waste gates, Tial 50mm blow off valve, full dual 3 stainless exhaust, Eboost2, FMIC, CircleD 6l80e, CircleD 3200 stall converter, Triple staged 392 Walbro pumps, Fuel lab regulator, Aeromotive rails, FIC 127lb injectors, 3.27 rear with Wavetrac diff, Gforce 750hp axles, BMR full bushings kit.
adamsar is offline   Reply With Quote
Old 08-18-2012, 02:09 AM   #2
adamsar
adamsar's Avatar
Here's a look at the FIC injectors, they look great out of the box, no tool marks or anything I could see that would worry me and I cant wait to put the dyno sheet up next.
Old 08-18-2012, 05:56 AM   #3
Crazy_8
Crazy_8's Avatar
Those are huge injectors! Have you already rebuilt the tranny?
Good luck. Can't wait to see your numbers.
2009.5 Liquid Red G8 GXP A6
For mods list, honk 3 times.
Crazy_8 is offline   Reply With Quote
Old 08-18-2012, 08:30 AM   #4
LBV
LBV's Avatar
That's way beyond where my know-how ends but where would you say the stock engine HP max is at from your experience? Also what went when you over-boosted (what cylinder(s) and what part?
Good luck with the build.
2009 GXP, Manual with Sunroof
Borla cat-back, H&R springs, & Sprintbooster & I love it! Summer rims = 19 x 9 CTS-V PVD Permachromed
LBV is offline   Reply With Quote
Old 08-18-2012, 10:15 AM   #5
adamsar
adamsar's Avatar
I have a Circle D trans in the car so thats good. The engine held 13psi pretty good, but normally I kept it at 7-9psi. When it went, piston number 3 detonated and the rest of the pistons tapped the valves.
Old 08-18-2012, 11:09 AM   #6
thebeast
Didn't see anything mentioned about oil or trans cooler?
2008 LR G8 GT
TSP Forged LS3-D1-221/232 RCR Cam-Ported L92's-Squash-Kooks-Solo 3in-BMR-SS wheels and brakes-Kicker-Demon 8 Designs Gauge Pod-BC Racing Coilovers- Custom Earls Tranny Cooler
613/543 old worn out numbers
11.6 at 123 1.92 60ft
New numbers coming soon..........
thebeast is offline   Reply With Quote
Old 08-18-2012, 11:38 AM   #7
adamsar
adamsar's Avatar
trans and oil coolers were already installed temps never even crept into bad areas.
Old 08-18-2012, 11:54 AM   #8
Black_Ice
Black_Ice's Avatar
Isn't a Camaro Rear Diff A little Stronger ?
09 PBM M6 G8 GXP
08 Solstice M5 GXP
05 GTP CompG
88 Fiero Formula
81 Turbo Trans Am
76 Trans Am 455
Black_Ice is offline   Reply With Quote
Old 08-18-2012, 01:37 PM   #9
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
I'm interested about the Wavetrac also. I like and hate our limited slip.
Old: 353.8
New: 632/530 Mustang Dyno
Old 08-18-2012, 01:51 PM   #10
adamsar
adamsar's Avatar
Its a GXP 3.27 rear but the camaro ones are stronger as well. The gear ratio is what I want and to pick up a little more time in the 1/4 mile. The wavetrac is a beast, cant wait to put it in.
Old 08-18-2012, 03:23 PM   #11
ExpLiciTSainT
So you think with all those horses, you're still going to want smaller gears?
Old: 353.8
Old 08-18-2012, 03:28 PM   #12
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
She'll be a beast on E85 dude, have fun with it, you have some local gas stations in SD that sell it, Pearson Fuels. Ask your tuner to use 10.65 as the start stoich point in your tune if you pump E85 from them, all Pearson Fuel gas stations that sell E85 have more or less the same amount of ethanol in it (i've pumped from the SD gas stations, and one close to Santa Monica where i work). starting at 10.65 stoich in the calibration, should put her right on, or super close from where she needs to be running this E85 brand.
Have fun.
Old 08-18-2012, 05:33 PM   #13
adamsar
adamsar's Avatar
Yeah I was running E85 in 2010 when I was in Virginia, at least in San Diego the military bases have E85 and Pearson is less than 5 minutes away from me. The 3.27 is where I want to go since the wavetrac can only fit the g8 rears that 2.92 is just too short on 1st and 5th isn't getting all it could.
Old 08-18-2012, 07:39 PM   #14
deezomaxima
MUSCLE Biotch!
deezomaxima's Avatar
I thought I was going to read some terrible news about a build. Good to see this is not the case.
97 Nissan Maxima - Engine croaked at 396K - Replacement 13,000 mile engine install and clean as hell inside
2008 White Hot G8 GT - SC 91 and Roto Tune
Morimoto - Pennzoil Pure Plus NG Syn - Mobile 1 Filters - Harbor Freight - 3M - Spectre - Superchips Flashpaq - SuperBrightLED - Cooper Tires - Camaro SS Pan
deezomaxima is offline   Reply With Quote
Old 08-18-2012, 11:19 PM   #15
20lbbooster
What is the rest of your fuel setup?
20lbbooster is offline   Reply With Quote
Old 08-19-2012, 01:33 AM   #16
MGM GT
MGM GT's Avatar
Sounds like a cool build!!! Hope it runs a number!
But 720/680 and only a 10.8? Whats wrong with it? Kinda sounds like an unoptimized setup or lack of traction.
Just another 9 second family car...
Capital City G8 Club /// DriveShaftShop /// Powerhaus Performance
MGM GT is offline   Reply With Quote
Old 08-19-2012, 01:49 AM   #17
Blanky
Blanky's Avatar
Stall?
Blanky is offline   Reply With Quote
Old 08-19-2012, 11:42 AM   #18
adamsar
adamsar's Avatar
Stock intank pump feeding 2 gallon surge tank with three staged Walbro 392 pumps. -10an feed line / -6an return line. Fuel lab regulator and new 127lb injectors on Areomotive rails.
Yeah this was originally Parish's build, but I had to upgrade it the tune got tweeked and all the areas I wanted to clean up as far as traction and running are now different. Hopefully the new set up drops the time by at least .5 to .7.
Originally Posted by Blanky View Post
Stall?
CircleD 3200 stall Pro III 245mm triple disk converter.
Old 08-19-2012, 11:53 AM   #19
MGM GT
MGM GT's Avatar
Ahh ok gotcha.. sweet! Yeah thats good power, should easily run low 10's.
Old 08-20-2012, 09:29 AM   #20
adamsar
adamsar's Avatar
3.27 rear on its way, injectors at the shop, wavetrac in the dining room. This week should be interesting....
Tags
build , project , turbo , twin turbo
