H-Pipe Setup May Trump X-Pipe on the V6 - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Community > G8 Talk (V6)
Old 09-20-2012, 01:19 PM   #1
lg68jcu
lg68jcu's Avatar
Default H-Pipe Setup May Trump X-Pipe on the V6
Hey Guys and Gals,
Not sure if you guys saw this over in the Exhaust forum so I wanted to post it here as well. I know unless I need something specifically exhaust related I dont usually read over there.
Anyways I had an opportunity to ask Summit Racing what their opinion was on the X-Pipe vs. H-Pipe debate for the G8 V6 and below is what they said. This solidifies my decision to go with an H-Pipe. I have always leaned that way. Planning on doing it around Christmas time. I would love to hear some feedback on this.
Do any V6ers have an H-Pipe?
""Due to the small CID of your engine, an H-pipe setup likely will perform better than an X-pipe setup. It's hard to say for sure though how the vehicle will react to either due to it's small size engine and in a lot of cases conventional V8 ideas on making power do not equate to more power in V6 applications."
"Installing the H-pipe setup in place of the mid mufflers will increase the flow capabilities of the system greatly but also will likely greatly increase exhaust drone quite a bit at lower cruise rpm's. Making this change will likely also make the exhaust tone deeper. "
2008 Panther Black V6
Homemade Intake Tube with K&N drop in
Dynomax Super Turbo Mufflers
LPM with air scoop into the lower panel of the snorkel
Quarter Mile 15.38 @ 92.49 MPH - 2.29 60' (5-12-2012)
Click Here For Video
Quarter Mile 15.43 @ 91.01 MPH - 2.24 60' (6-14-2011)
SOLD 11/30/2012
lg68jcu is offline   Reply With Quote
Old 09-24-2012, 06:32 PM   #2
Enginerd
Enginerd's Avatar
That's pretty good info/feedback...they're generalizing but accurate at the same time (hmm that's contradictory? lol)
It's a speculation game...X-pipes are proven to produce better exhaust gas scavenging effects than H-pipes BUT then the exhaust system must be tuned and flow in such a way for a scavenging effect to take place under high RPM.
For most street cars in the 350-400ci range, running modest cams, catalysts, mufflers, you don't see X-pipes yielding HUGE gains over H-pipes...from all my research/experience on the subject the difference in say, for example the LS3, between an H-pipe and a (properly tuned) X-pipe system might be up to ~7-10whp (prob closer to 5 IMO)...I'm painting some broad strokes here but really in most ppl's applications the difference is fairly small.
Start adding boost, cams, entering the world of big-block displacement then, yeah, an X-pipe is the way to go all day long...
That being said, in a V8 application, to me there is NO comparison in sound - a properly located H-pipe sounds WAAAAYYYYY better than an X-pipe, and to me/some I'd rather leave (an arguable) 3-5whp on the table and not sound like a ricey/raspy foreign V8...
Now, as for V6s - I do agree an equalizing H-pipe would give a V6 a noticeably deeper tone but could contribute to increased 'drone' depending on a number of other factors (muffler type, pipe size, crossover location, etc...). But if you're looking for that, and understand it's not going to sound like a V8 no matter what, an H-pipe would likely yield the most tone change (deeper)...depending on muffler selection of course.
My $0.02.
---------------GXP M6 #595/1829---------------
Enginerd is offline   Reply With Quote
Old 09-24-2012, 06:39 PM   #3
Jeff92se
They are probably recommending the H for the low end torque benefits.
For the record, I put a resonated X pipe on my 3.5 liter G35 sedan. It went in on a Borla catback that didn't have a H or a X. The X cut out alot of the drone and picked up some torque down low. How a H would have done in that situation? I dont' know. My main objective is to rid myself of the drone and gain some torque/hp/sound. Which it did
Jeff92se is offline   Reply With Quote
Old 09-24-2012, 08:40 PM   #4
lg68jcu
lg68jcu's Avatar
I am in the market for low torque gains. I am happy enough with my peak hp. I just want to improve my 60' mainly. I gained 2 mph with my mufflers and intake but lost a tad off the line .05 ave. If I could gain low end torque and not lose any peak hp I would be thrilled. That's exactly what I want.
SOLD 11/30/2012
Old 09-24-2012, 10:00 PM   #5
cpbeaulieu
cpbeaulieu's Avatar
I have a h-pipe installed on my car. The low end is a little better but i feel like i lost alot of my high end
cpbeaulieu is offline   Reply With Quote
Old 09-25-2012, 01:20 PM   #6
lg68jcu
lg68jcu's Avatar
Thanks for the feed back. I am assuming you have the V6? Do you have any other mods?
How is the drone and sound?
Could your estimation of high end power loss just be that extra low end torque isnt carried through the whole power band and just isnt more than it was before?
Do you have and performance apps on your phone etc? Wondering if you have a performance compare. Just makes me wonder more with the limitted information out there on H pipes and exhaust mods on our cars in general.
I know I gained HP with my super turbos (quarter mile runs dont lie). Seems like a complete crap shoot on whether there are any gains to be made by modifying the stock exhaust any further on the V6 (X-Pipe or H-Pipe)....
SOLD 11/30/2012
Old 09-25-2012, 08:01 PM   #7
cpbeaulieu
cpbeaulieu's Avatar
Yes i have a 6 and i've had a bunch of exhaust setups on this car. I was trying to find the right sound and i never found it lol. The setup i have now( h-pipe, no resis, no mid muff and solo axle backs) is the worst I feel performance wise but sounds the best. Now that i can not find the right sound im goin for performance which i felt was x-pipe, no resis, no mid muff and stock axle backs(to cut down the drone). This time tho i got a resonated x-pipe waiting to be install because i want to keep my solos on but if the drone is too bad ill put my stock ones back on. Even my wife noticed the car lost some power at the higher end and she never notices stuff like that
Old 09-25-2012, 09:40 PM   #8
lg68jcu
lg68jcu's Avatar
Yes i have a 6 and i've had a bunch of exhaust setups on this car. I was trying to find the right sound and i never found it lol. The setup i have now( h-pipe, no resis, no mid muff and solo axle backs) is the worst I feel performance wise but sounds the best. Now that i can not find the right sound im goin for performance which i felt was x-pipe, no resis, no mid muff and stock axle backs(to cut down the drone). This time tho i got a resonated x-pipe waiting to be install because i want to keep my solos on but if the drone . too bad ill put my stock ones back on. Even my wife noticed the car lost some power at the higher end and she never notices stuff like that
Performance wise I wonder if all you need is a tune? Your current setup is basically wide open with no back pressure. I am not sure the stock computer / tune can adjust to that much flow. Maybe its just running lean or something. Maybe a tune can increase your fuel delivery and increase performance. I dont know a whole lot about tuning but just taking a stab at it.
If I go with an H Pipe I plan on removing the mid muffler, Keeping the resonators and running my Super Turbos. I have a feeling it may drone like a B!0tch. my super turbos can drone from time to time but its mostly under control. what was your experience with drone and your setups?
SOLD 11/30/2012
Old 09-26-2012, 09:15 AM   #9
cpbeaulieu
cpbeaulieu's Avatar
First setup was no resi, no mid muff,stait pipes and stock axle backs(very little drone)second was no resi,x-pipe and stock axle backs(little to no drone). Third was no resi, x-pipe and custom solo axle backs(worst drone i ever had). Fourth was no resi, flowmaster mid muff and custom solo axle backs(drone still pretty bad but a littler better). Fifth was no resi, flowmaster mid muff and regular solo axle backs(drone is still there but alot better). Sixth was no resi, h-pipe and reg solo axle backs(drone got a little worse). Oh and forgot to tell you that i have solo QR resi on there now to help with the drone and they do.
Old 09-29-2012, 11:16 PM   #10
lg68jcu
lg68jcu's Avatar
Thanks for your input. I do have a question about your first setup (no resi, no mid muff,stait pipes and stock axle backs).... How did it perform compared to the stock setup? How much louder was the exhaust and what kind of tone change did you notice. Did you like the sound at all? If I went this route I would keep the resonators. I just dont want to add an H pipe and have a drone like a B@#$%. My setup now is noticable but tame with little to no drone.
I always have given this setup some consideration as well because it would be dirt cheap and since its a V6 you may be able to get by without a cross over.
Thanks!!
SOLD 11/30/2012
Old 09-30-2012, 11:30 AM   #11
jackalope
jackalope's Avatar
IDK guys Hot Rod magazine did back to back dyno tests years ago when "X" pipes started coming out. They tested straight duel exhaust, "H" pipe's, and "X" pipe's and they found that the "H" pipe added around 5 to 7 hp and 7 to 10 lbft of tq and an "X" pipe added 8 to 10hp and 12 to 15 lbft of tq.
They used an other wise bone stock 5.0 Mustang as the test mule, now I know you V6 guys don't have as much displacement but the results should be the same regardless of engine size.
Now those numbers are from memory so I may be off a hp here of a lbft there but that was those were the general findings that Hot Rod had come up with that an "X" pipe is the best. Summit is a great place to buy parts from but I'd like to know where they're gathering their test data.
Old 10-05-2012, 09:55 PM   #12
lg68jcu
lg68jcu's Avatar
I often wonder if just keeping the mid muffler is the best setup without a tune. Right now I have superturbos and an intake tube. My cars performance has increased .2 seconds + in the quarter with those two mods. I am afraid doing an x pipe or h pipe will kill my performance without a tune.
The mid muffler is just an open chamber right? If that is true that it is acting as a cross over and I can't imagine it's overly restrictive but could be wrong Can anyone confirm this. If this is the case I am not sure how much more benefit an h or x would be other than the weight reduction (especially with the stock tune)
SOLD 11/30/2012
Old 10-05-2012, 10:49 PM   #13
jackalope
jackalope's Avatar
Yes it is an open chamber in the middle.
Old 10-06-2012, 12:38 PM   #14
cpbeaulieu
cpbeaulieu's Avatar
Thanks!!
performance wise never really noticed a difference. Sounded a little louder at WOT. But when i put the x on thats when i noticed a performance gain for sure.
Old 10-06-2012, 03:28 PM   #15
lg68jcu
lg68jcu's Avatar
How was the low end torque/ off the line performance with the X pipe? How much weight redux do you think cutting out the mid muffler I am guessing it weighs at least 15-20 lbs and an x pipe is prob 4-5 lbs.
Was the exhaust louder with the x over stock ?
SOLD 11/30/2012
Old 10-06-2012, 03:39 PM   #16
knglibrty
knglibrty's Avatar
Got mine on the dyno today at Backstreet preformance in Medina, and got really good numbers. 223.13 H.P. 224.85 MAX tourq . Met some other G8 owners to, posted some pics on board on notrh east ohio g8s thread. planning to meet there in spring when they have a GTO meet. Hope you can attend .
2009 GT White Hot, AKA CASPER, Superchips 93 octane tune, Volant C.A.I with HSRK,Slotted and cross drilled rotors with ceramic pads,GXP Diffuser,Debadged.Solo axle backs, Coronet 440 style tips
Dyno 4/26/15,343 MAX H.P.,338.6 MAX TORQ
5/13/15 13.42@103.66, 2.03- 60'."WE ARE THE LAST OF OUR KIND"
2009.1 V6 STRYKER BLUE, TRADED IN 1/10/13
knglibrty is online now   Reply With Quote
Old 10-07-2012, 08:42 PM   #17
cpbeaulieu
cpbeaulieu's Avatar
I felt like it got better all around. The x weighs next to nothing so there's definitely a weight reduction. It does get a little bit louder
Old 10-08-2012, 10:55 PM   #18
lg68jcu
lg68jcu's Avatar
thats pretty awesome. Its funny. I read thread the day you guys met and got the dyno. I wouldnt have been able to go but I am 15 minutes away. Oh well maybe next time. I would have loved to see what mine would dyno. Has anyone ever done a pure stock dyno on the V6. Just curious what a stock V6 would do. Keep me posted if you hear anything about the spring meet. Maybe I can make it.
SOLD 11/30/2012
Old 10-08-2012, 11:04 PM   #19
lg68jcu
lg68jcu's Avatar
thanks. I am now looking to be louder now. my current set up is too tame for me now. Definitly now stock sounding but stock enough for my wife to drive without complaint. I would imagine the increase in volume would not be accompanied by drone with the X pipe unlike if I got an H pipe.
Does anyone (GT or V6) run the long / narrow style X pipe.
I keep gravitate to this one over the standard X pipe that is more square in overall shape. This is 20 inches long. Most other X pipes are only 12. It seems like it would make a more fluid exhaust. Would love other peoples opinions in this style of X pipe.
http://www.summitracing.com/parts/SUM-643125/
SOLD 11/30/2012
Old 10-10-2012, 11:31 PM   #20
lg68jcu
lg68jcu's Avatar
Just for the sake of argument I replied back with with following and got the response that follows:
"Thanks. What do you think would happen for both performance and sound if I remove my mid muffler(which does act as a cross over) and just run strait pipes in its place (Running my system without a cross over)? Could there be any benefits in doing this or would I be better off sticking with my current setup?"
"It's hard to say for sure how the engine will react to this change. I personally believe the engine will perform best sticking with the current setup. Reason I say this is that making this change will likely result in more HP but it may also hurt low end torque production. So, doing this may improve the top speed but hurt off the line acceleration. "
SOLD 11/30/2012
