Why DOD delete? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 10-07-2012, 12:46 AM   #1
I ARMY RECON I
I ARMY RECON I's Avatar
Default Why DOD delete?
So I'm a new g8 owner and I have a question... Why should I/someone do a DOD delete? Isn't the DOD there for better gas mileage? I am new to all this computer stuff my new ride has. Lol
I ARMY RECON I is offline   Reply With Quote
Old 10-07-2012, 02:28 AM   #2
Bo White
Bo White's Avatar
Yes, it is. Gas mileage is what some want and max power is what others want.
Old 10-07-2012, 04:05 AM   #3
Neverending
Neverending's Avatar
I plan on deleting DoD just because I don't trust it for reliability. Some people have done cams and kept DoD though. Most people don't care about the 2mpg difference especially when a good tune can gain that back and increase power.
Jeff
09 GT Premium + Sport + Webasto Sunroof
20/20/5 tint + GXP Diffuser + VVME 6000K HIDs + Camaro SS 20" 245/35 & 275/30
Borla Cat-back + Roto-Fab CAI + tune(Kooks LT 1-3/4 OTW)
310rwhp 314rwtq on Mustang dyno(stock tune)
Neverending is offline   Reply With Quote
Old 10-07-2012, 10:51 AM   #4
I ARMY RECON I
@neverending so if/ when I change my cam I should get the dod delete and get a good tune?
Old 10-07-2012, 11:40 AM   #5
MasterPat
MasterPat's Avatar
@Army,
The reason why people go with a DoD delete is that the reliability of the components is always questionable. I had my lifters fail on me causing the Lifters, Camshaft, and a few other components need to be replaced at GM's expense (Covered under warranty). If you are thinking about changing your cam you are left with 2 options.
1) Custom grind DOD spec cam. You would want to reach out to the few other members that have went this route
2) DOD delete package with camshaft. A few vendors sell them as kits and have a good reputation with their packages. Livernois for instance has their package for ~$1600 with all the DOD delete stuff with a camshaft.
White Hot 2009 Pontiac G8 GT | Roto-Fab Cold Air Intake | Kooks 1 7/8" Mids with HFC | Solo Mach Unbalanced Catback Exhaust | FE3 Struts| Livernois Motorsports Tune |DDM Tuning 35W 6000k HIDs | 15% Side and Rear Tint | Staggered Camaro SS Wheels with Hankook Ventus V12 Evo2 Tires
MasterPat is offline   Reply With Quote
Old 10-07-2012, 11:49 AM   #6
Dictatorsaurus
Dictatorsaurus's Avatar
The questionable components are the original Eaton lifters. most class the replacement Delphi lifters are reliable.
Dictatorsaurus is offline   Reply With Quote
Old 10-07-2012, 12:00 PM   #7
Troy Trackbeast
Super Moderator
Troy Trackbeast's Avatar
The real question should be why NOT do a DOD delete....
Sent from my iPhone using Autoguide
Troy Trackbeast is offline   Reply With Quote
Old 10-07-2012, 12:01 PM   #8
I ARMY RECON I
@masterpat Thank you for some real input I don't understand the DOD fully. I used to be a front end mechanic but I dont have a full concept on how the DOD works... But what I am understanding is that it is similair to hondas vtech in a sense but opposite of more horse. Does that seem correct?
Old 10-07-2012, 01:54 PM   #9
MasterPat
MasterPat's Avatar
DOD is built into our engines. The camshaft and lifters as well as some other components all work together to shut down 4 cylinders when cruising in order to bump up fuel economy. You can 'tune it out' if you have a custom tune on your car (Superchips Cortex 2950 works fine for small mods, until you start playing with headers and other components) and can Turn DOD/AFM off. There are actual hard components though that people remove -- Lifters, Camshaft, Valley Cover, Cam Sprocket, etc... -- that are the actual parts that help DOD/AFM function
Old 10-07-2012, 02:23 PM   #10
'08 G8 GT
This thread has an awesome write-up on the L76, including how AFM works. FWIW, I'm one of the many here who have had the AFM lifters fail, resulting in a new cam and valvetrain at about 30K miles, covered under warranty of course. I'm just over 50K now with no issues, but still plan on a DOD delete at somepoint...
http://www.g8board.com/forums/showthread.php?t=22509
'08 G8 GT is offline   Reply With Quote
Old 10-07-2012, 08:39 PM   #11
DougHG8
Some of us have kept the DOD delete AND done high horsepower mods. My tuner/installer (G8-4-Speed) says I have the later and better DOD/AFM lifters; mine have been fine now for 94k miles (40k with the supercharger and DOD compatible cam). He kept his as well and has had no issues so far. Some have had problems with the Eaton lifters while others have had problems with the non-DOD lifters as well so I think it's a coin-toss as far as reliability but that's just my impression based on what I've seen and experienced.
2009 Hot White G8 GT, CTS-V v1 fronts, Camaro 20's, BMR Sways, Eibach Springs, Rear Cradle bushings. GXP FE3's, BMR rear susp. Kooks 1 7/8 LT headers, RCR custom 3 exhaust, ported LSA blower, 2.38 pulley; Ported heads and TB; LS7 MAF, Racetec pistons, Scat rods, CTS-V crank; FAST 85 injectors; RCR Lunati cam: 223/238 .615/.601, 116 +2 LSA. CTS-V pump/VaporWorx cntlr. Built trans, Methanol injection. Rick Crawford built and tuned. Best 1/4 9.90 @140, 1.45 60'.
DougHG8 is offline   Reply With Quote
Old 10-07-2012, 08:44 PM   #12
Buford
Buford's Avatar
Reliability you say? No issues here, could probably crack out 30+ more horsepower if I wanted to lean on her. DOD has been in place over the past 4 years and 30k miles of boost. Not one issue.
2008 ProCharged/Pedders G8 - 633rwhp/525rwtq
P1-SC, E85, 10psi, baby cam, Yank 3200
For Sale: http://www.g8board.com/forums/showthread.php?t=65635
Buford is offline   Reply With Quote
Old 10-07-2012, 08:55 PM   #13
redhot8
redhot8's Avatar
Great thread, lots of useful info. I may try a DOD delete and see how much difference it makes MPG wise with the different tunes.
2009 LR GT Pypes Axle backs, Pypes TriY headers, Magnaflow X pipe with cat and resonator delete, Spectre CAI, Chenry Motorsports tune, and a full set of Chenry Motorsports splitters.
2008 WH GT Spectre CAI, BBK shortie headers, Cortex tune, Mid muffler/resonator delete with x pipe, DMH low profile cutouts and a full set of Chenry Motorsports splitters.
redhot8 is offline   Reply With Quote
Old 10-07-2012, 09:22 PM   #14
Buford
Buford's Avatar
You'll notice a bigger change in MPG by adjusting your right foot than deleting the DOD or turning it off.
Old 10-08-2012, 09:35 AM   #15
GXPaycheck
GXPaycheck's Avatar
When I had my GT I had it tuned out. Car ran and felt MUCH better. Only lost 1.5 mpg. If I had kept it, I would have done the delete, especially after hearing about all the lifter issues.
In the end, I did the ultimate DOD delete. I bought a GXP!
RIP Charlie, The GRRRR8 One
2009 G8 GXP, #715 0f 1829 (one of 38 as optioned), Magnetic Silver, 6M, Sunroof, Onyx/Red
VCM, Magnaflow axle-backs, WAMS IWM/VIM, Back-up camera with JHP autoswitch, Homelink by Snakey, Pedders bushings
2014 Chevy SS, Mystic Green, roof. One of 144
Forum junkie at the G8Board and "The G8 Forum That Shall Not Be Named"!
GXPaycheck is offline   Reply With Quote
Old 10-08-2012, 09:54 AM   #16
G8-5150
G8-5150's Avatar
My take on this is; I bought a V8 car because I wanted a V8 car, not a V8 sometimes car, so I turned off my AFM.
G8-5150 is offline   Reply With Quote
Old 10-08-2012, 10:48 AM   #17
I ARMY RECON I
Thanks for the link! Now I have to explain to the wife lol
Old 10-08-2012, 04:05 PM   #18
camopaint0707
DOD is turned off when you go into sport mode right?
camopaint0707 is offline   Reply With Quote
Old 10-08-2012, 04:47 PM   #19
09G8GT09
THE1ONE
Manual mode only.
Sold and missed 2008 G8 GT
JBA long tube headers X-pipe stock mufflers,SNL tuned with 93 octane, Rotofab intake RWHP:340, Pedder's Sway Bars, Breyton GTS 20x8.5 Front 20x10 Rear
New 2009.5 Red G8 GT Premium Package Vararam Intake w/ Cortex Tuner for now..
09G8GT09 is offline   Reply With Quote
Old 10-11-2012, 01:25 PM   #20
GT Drew
Before GM had the Delphi lifter to replace to defective Eaton lifter, DOD delete was your only performance choice. Now you have a choice. If you are building something really wild and not a DD. Deleting AFM is a must.
Many have proven you can have a strong street/strip car and keep DOD.
If you still have Eaton Lifters, most delete DOD when they swap cams.
