GXP Wheel Alignment Specs - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 10-18-2012, 01:59 PM   #1
acasualobserver
acasualobserver's Avatar
Question GXP Wheel Alignment Specs
Are the factory specs the same for G8's, GT's, and GXP's? If not, where can I find documentation?
I just replaced my tires with Bridgestone Potenza 760 Sports at nearly $300 a pop OTD and was told the alignment is the same for all G8's. Want to confirm before tearing up more tires.
acasualobserver is offline   Reply With Quote
Old 11-20-2012, 08:56 AM   #2
Link112
Link112's Avatar
+1 also at stock height and stock suspension does someone have some performance alignment specs please?
'09 G8 GXP / M6 / MSM / Onyx / Roof / #806 of 1829
Dominator 2 cam and custom tune, 468 RWHP, Kooks LTH, Corsa HFC & Exhaust, MGM Shifter, Rotofab CAI.
'08 Bullitt Mustang #765 (gone)
Link112 is offline   Reply With Quote
Old 11-20-2012, 09:55 AM   #3
MFE
MFE's Avatar
In what way were your last set of tires "torn up"? That will have a big impact on what the alignment diagnosis/prognosis is.
MFE is offline   Reply With Quote
Old 11-20-2012, 02:20 PM   #4
GT Drew
A G8 is a G8, regardless of the engine, trans or wheel size. You are aligning the chassis suspension, not the tires. Control arms, tie rods are ALL the same.
Old 11-20-2012, 02:54 PM   #5
spartan466
spartan466's Avatar
Forget where I pulled this from, but when I last got my alignment done, Belle Tire pulled up the specs in their computer for my GXP and it matched what this says (assuming FE2 and FE3 are the same). I only needed toe adjusted so I didn't pay TOO much attention to the other specs.
Todd
2009.5 G8 GXP, M6, Liquid Red, Sunroof #1769
Show: CTS-V Wheels, HSV Sliding Console, HSV Triple Gauge Pod with Front Smokers Pack
Go: TVS2300, Kooks 1 7/8 Mids with HFCs, Corsa Cat Back, RotoFab CAI, Livernois Tune, McLeod RXT Twin Disc, gForce 750HP Axles
528 RWHP 498 RWTQ
11.69 @ 123.25 (1.94 60' Spinning)
spartan466 is offline   Reply With Quote
Old 11-20-2012, 03:47 PM   #6
JonRobbinSS
JonRobbinSS's Avatar
The HSV settings in Todd's chart look good to me.
The problem with most factory specs is that huge range they allow as "tolerance" like that camber setting for the G8/FE2 anything -.01 to -.67 is good. So your car is on the rack and the right wheel is -.01 and your left is -.67.. They would both be in the green.
Those HSV settings are a little more focused using tighter tolerances. If you notice the settings in the HSV column mostly fall within the range of the FE2 settings, the only exception really is a little more front camber.
09 SRM GXP M6 Onyx VIN# 208718
#13 of 1829 GXPs
#2 of 171 SRM GXPs
Consolidated list of Mods to the car
JonRobbinSS is offline   Reply With Quote
Old 11-20-2012, 04:47 PM   #7
Bo White
Bo White's Avatar
Correct, just because your cars is within spec doesnt mean its in alignment. I done alignment work for years and seen it on a weekly basis were someone got an alignment and it wasnt in true alignment and had either wear and/or driveability issues.
Old 11-20-2012, 05:29 PM   #8
Link112
Link112's Avatar
Ok so if being in spec or "green" does not mean it is always in alignment. Then should it be down the middle of these values? I have been searching around for the last couple days, but i am trying to understand what to ask for when I go to get this done tomorrow, or what spec to be checking for off the print off. I know this may change from driver to driver, but I enjoy spirited driving on the back roads and this is my daily driver. Tire life is important, but I also want to feel connected to the road. Anyone have. I will use the HSV settings, but if I can get the tech to dial it in, does anyone have some they have found to work well? I am probably over thinking this, but have had bad luck with local alignments in the past.
Thanks in advance!!
Old 11-20-2012, 05:39 PM   #9
MFE
MFE's Avatar
If you enjoy spirited cornering, increase the negative camber to -1.0 degrees, and go to the low end of the toe-in specs. 1 degree negative camber will keep the outside tires more squarely planted in hard cornering without hurting tire wear, if you dial the toe-in back a little. If you notice the outer edges of the tires wearing, either give it even more neg camber or slow the hell down If you find the inside edges wearing, take more toe-in out of it.
2009 G8 GT
Road course and racing school junkie, high-performance car control instructor, 8350 miles on 17 tracks and counting
Old 11-20-2012, 07:28 PM   #10
spartan466
spartan466's Avatar
Thanks in advance!!
Yeah, I think a good alignment guy will shoot for the actual spec and not just get it anywhere in the alignment "window". The guy at Belle Tire actually did a good job of getting it pretty darned close to the spec and it seems to track better now. Right from the factory it seemed to want to follow every imperfection in the road, so I'm not even sure it was set all that well when I bought it. Good to go now though with factory specs! I don't do road courses or anything like that, so wasn't too concerned on trying to improve on factory settings.
Todd
528 RWHP 498 RWTQ
Old 11-20-2012, 08:19 PM   #11
Link112
Link112's Avatar
Thanks everyone! Feel much better on what to look for tomorrow. This forum is great as are the members!
Old 11-21-2012, 10:17 AM   #12
spartan466
spartan466's Avatar
Good luck! And as long as you take it to a reputable place, you can always bring it back to have them re-do it for free if it doesn't feel like it's driving right. I think the place I took it to had a 12 month warranty or something like that.
Todd
528 RWHP 498 RWTQ
Old 11-21-2012, 10:49 AM   #13
BigV8
BigV8's Avatar
Pedders has this on their site. I used it for oe and after I got the supercar coilovers on.http://forums.peddersusa.com/local_l...catid=4&id=101
Sold and wish I hadn't.09 GXP SRM A6 w/sunroof. Mods:Livernois Maggie 2.3, 3.0" pulley, 160 stat, KB Bap. Rotofab,Corsa, Kooks 1 7/8 mids, BMR,Pedders supercar coilovers, all Brembos, CTS-V rims, Hids, halos, leather console lid. HSV gauges. 502rwhp,479tq#873 of 1829 and 1 of 169 in SRM.
BigV8 is offline   Reply With Quote
Old 11-21-2012, 01:13 PM   #14
Bo White
Bo White's Avatar
I had an elderly man drop off an early 80s F150 for an alignment one time that brought it back because the steering wheel was straight.
He said that the old way with the wheel being off center it was confortable for him to prop his arm on the door handle and cruise down the road and now with the steering wheel straight the cross bar was in the way for his hand to be lol. I pulled it back in and put the wheel were he wanted it
Old 11-21-2012, 01:52 PM   #15
spartan466
spartan466's Avatar
lol... that's awesome...
Todd
528 RWHP 498 RWTQ
Old 01-09-2013, 06:18 PM   #16
RJKmotion
RJKmotion's Avatar
can i use the pedders perf. spec alignment even thought i dont have the full bushing kit like it stats??? im only doing all new struts, springs, strut mounts and possibly new control arms as well. thanks guys! also the car is getting lovells struts all the way around and still undecided on h&r, lovells, or pedders springs. i want a 1.5" on the front and a tad less in the rear. the rear i will be able to adjust the height if i need to because of the lovells rear strut set up.
RJKmotion is offline   Reply With Quote
Old 01-11-2013, 04:39 PM   #17
RJKmotion
RJKmotion's Avatar
anyone??? know if i can use the pedders perf alignment spec, even though it says with full bushing kit??
Old 01-11-2013, 04:57 PM   #18
Flatfoot
Flatfoot's Avatar
You may want to drop Rob a line and ask him. (Wretched Motorsports). He did both my Pedders install & my alignment. He is one of the best I've ever had the pleasure of dealing with. Cheers.
GXP Sun & Stick
Flatfoot is offline   Reply With Quote
Old 01-11-2013, 10:53 PM   #19
Vz28
I ran -1.4/-1 front/rear camber with a tiny bit of toe-out up front on my stock GXP for over 20k miles on the OEM summer tires, rotating front to back occasionally, with fairly even wear and no odd behavior. A little extra negative camber adds a noticeable amount of grip, especially up front. Keep in mind I do not take the car to the track, but it saw some spirited driving and some autocross.
YMMV
2009.5 g8 gxp m6
Vz28 is offline   Reply With Quote
