Transmission filter? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-01-2012, 03:27 PM   #1
Oneg808
Oneg808's Avatar
Default Transmission filter?
I just got a call from the dealer, they've dropped my pan and don't have a filter in stock and have to order it. The guy went on to tell me that I don't "HAVE" to change the filter, and that it wouldn't hurt anything. So should I tell him to order the filter or just roll on like it is? It only cost me 70.00 to change transmission fluid by dropping pan!? I don't want to spend more than I have to! I've done some research but cant find an answer on this one! Thanks
2008 G8 GT, Vararam, H&R's, Straight Pipes, Pace Setter Long Tube Headers, Pat G tune, Pat G custom cam, DOD delete from pace performance, TSW Valencia Wheels; 20X10 Rear, 20X8.5 Front, Brembo brakes with drilled and slotted rotors, 5% tint "So you can't see up in my windows!", debagged, Smoked out, GXP diffuser, GXP front facia, HID Kit 12K, HPJUNKIE HID fogs, and more to come!
Oneg808 is offline   Reply With Quote
Old 11-01-2012, 03:36 PM   #2
silentlegion
how many miles on the car?
Mods: HID's, New Engine, New Tune, VCM OTR CAI, 1 7/8 ARH to Solo exhaust, Spoiler, Gxp rear defuser, Custom Sound System, Suspension, Brakes, and lowered.
silentlegion is offline   Reply With Quote
Old 11-01-2012, 05:03 PM   #3
Oneg808
Oneg808's Avatar
59,000 miles
Old 11-01-2012, 05:37 PM   #4
keptman
I would get it changed. They can change the pan fluid without droping the pan via plug. It doesn't drop all of the fluid when doing this. So they could charge you for something they aren't doing.
Even when droping the pan there is still about half of the total fluid still in the transmission.
09 Pontiac G8GT rebadge to a Holden VE SSv
Rotofab, 1-3/4 long tube w/ full KOOKS exhaust. VMS ecm/tcm tune. CTSV brake Upgrade. CTSV wheels 19x9 on all four.
07 350z Nismo, Stillen headers, injen long tube intake. Leather seats.
90 300zxTT Major build est 450hp on low boost, 650hp on high boost. 99 spec front end, have yet to install the wing and tails.
85 Rx7 12a street port with holley 565 est 190hp
keptman is offline   Reply With Quote
Old 11-01-2012, 05:49 PM   #5
Oneg808
Oneg808's Avatar
I'm confused... SOrry, I have no clue what this all consists of I just told them I wanted to pan dropped because of information I've read on these forms and what other people were doing. I only paid 75.00 so I'm guessing this filter is gonna cost 130 or so? because he said 200.00 for everything. I'd rather not do it if it's not gonna effect anything. My buddy who is a mechanic said theres really no need to change the filter at least right now at a little less than 60,000 miles.
Old 11-01-2012, 05:59 PM   #6
Monte8009G8GT
Monte8009G8GT's Avatar
Its up to you really, yes you can get it changed it shouldnt hurt anything really it should help. But if its to much yes you could skip it, They say the trans is good to 100k miles before any changes needed. But it all depends on your driving style impo.
2009 G8GT:
364--forged rods/pistons stock crank.(Rick Crawford) Ported Heads,(Modified) Intake, TB. Vararam, Custom Cam, Kooks 1 3/4 LT, 2.5in custom exhaust, Yank 3000 TC, BMR SFC, H&R Springs. DDM HID's 8k-LB 3k-Fogs.
Dynoed 435whp 386wtrq with above setup 12.8@116 2.2 60ft BTTD.
Cam,Stall,LTH,CAI,Tune. Best time 12.7@110 1.9 60ft. Old Setup.
Dynoed 370whp 380wtrq
(w/LTH,CAI,Tune)Best time 13.1@105 Old Setup.
Monte8009G8GT is offline   Reply With Quote
Old 11-01-2012, 06:39 PM   #7
Joe'sFastG8
Joe'sFastG8's Avatar
I'm a little confused. You said in original post that the pan is already dropped? Usually it is around $70 for them to hook up the tranny flush machine and just change the fluid. The $200 sounds about right for them to drop the pan and replace the filter, but most of the additional cost is for labor not for the filter itself. I would say if the pan is in fact removed already you might as well have them replace the filter, if it's not then you should be fine just having the fluid changed.
Old 11-01-2012, 09:18 PM   #8
todds87ss
Car RamRod
todds87ss's Avatar
this filter costs no more than 40bux.
Let them button it back up, tell them you will bring them a filter. Order the camaro deep pan and filter from Pace performance. Bring it to them, and have them change it.
GMP-24250062
cost-69 bux including the new pan. Why do anything else?
todds87ss is offline   Reply With Quote
Old 11-01-2012, 09:51 PM   #9
silentlegion
best suggestion with that many miles and if you havnt done it yet is to do it.
Old 11-01-2012, 11:49 PM   #10
bostonf4$
GMP-24250062
Why the camaro pan? Is it better in some way? I imagine most dealers won't change parts (especially driveline warranty covered parts) that don't belong on the car. He may have to go to an independent shop for that.
Old 11-02-2012, 12:34 AM   #11
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
Yes they will.
Old: 353.8
New: 632/530 Mustang Dyno
Old 11-02-2012, 09:04 AM   #12
Monte8009G8GT
It allows more fluid which in return will take more of the heat out. Also the filter has a bigger pickup on it. Thats about it really. And yeah the dealer should have no issue its just a pan and filter that fits the same style transmission.
2009 G8GT:
Old 11-02-2012, 09:23 AM   #13
wreckwriter
9 Second G8
wreckwriter's Avatar
Pretty stupid to drop the pan before checking to see that they had a filter.
Sent from my DROID2
2011-13 G8 King
wreckwriter is offline   Reply With Quote
Old 11-02-2012, 09:31 AM   #14
Oneg808
Oneg808's Avatar
They've already ordered the filter for my car, it wont be here for 5 days. I'm thinking about calling them and canceling that and purchasing the camaro filter, is there a particular year camaro filter?
Old 11-02-2012, 10:10 AM   #15
Monte8009G8GT
Your best bet is to get in touch with greg @ pace. He more than likely has the camaro pan and filter in stock ready to ship. If you need the part number Todd up above posted it. Google search it and it will take you to pace's web page. Also you dont need to worry about the pan sitting below the frame rails it just barely clears.
If you do go with the camaro pan and filter just make sure you let them know that it will need more fluid.. they should know this but sometimes forget or dont notice.
2009 G8GT:
Old 11-02-2012, 11:01 AM   #16
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Yep, Pace sells the thing as a kit, 6l80e trans pan kit, it comes with then pan, filter and gasket, it might take 3-5 days to deliver though. i bought the kit from them.
You can also check with your local GM dealer, see availability and ask for a discount.
Pace sells the kit under part# GMP-24250062
But you can piece them together, perhaps cheaper, pace doesn't have great deals most of the times like other GM online dealers, or same or a litte more buckos, depending where you buy and how much discount you can get, a local delaer might have the parts right away, or it might take them only one day to have them. Perhaps the local dealer can sell it as a kit as well, ask them.
Camaro Trans pan kit Part#s
GM 24250062 is the Trans Pan
GM 24236933 is the filter
GM 24224781 is the gasket
Old 11-02-2012, 12:03 PM   #17
Oneg808
Oneg808's Avatar
Thanks a lot for the help! Appreciate it!
Old 11-02-2012, 11:04 PM   #18
todds87ss
Car RamRod
todds87ss's Avatar
Cannot just fit the camaro filter under the G8 pan. You need to change them both. The part number above is for BOTH. IIRC, the fluid costs more than the parts.
Old 11-08-2012, 09:04 AM   #19
Oneg808
Oneg808's Avatar
Alright, my parts came in for the the transmission filter and I am confused as what GM did while I was there. Apparently they emptied 5 quarts out by dropping the pan and also told me they cant get all 12 total quarts out without flushing the system, is this correct? Also if they took 5 quarts out already why the hell did they not put 5 quarts back in, because I didn't get charged for fluid yet, I have only been charged for parts? Someone help me here, thanks.
Old 11-08-2012, 09:16 AM   #20
Monte8009G8GT
Yes that sounds correct you would need a flush to clear all the fluid out. After dropping the pan you still have fluid in your lines, torque converter, and stock cooler. If im thinking correctly the TC holds quite alot of fluid I want to say around 5 quarts or so. If they took oil out they more than likely put it back with oil but could of forgot or something along those lines, maybe they decided not to charge you for the fluid since you had to wait for the filter? And now there trying to press you to get the full system clean and make more money. This would be my guess or something along those lines.
2009 G8GT:
