Doing Bilsteins, need help with Kings - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-06-2012, 12:32 PM   #1
TheStevo
TheStevo's Avatar
Default Doing Bilsteins, need help with Kings
Ok so as the title states im doing a Bilsteins setup.
Im wondering what are the differences of the HD and non HD king springs???
Also, i was recommended to use super pro strut mounts, anything else?
TheStevo is offline   Reply With Quote
Old 11-06-2012, 12:34 PM   #2
jpG8GT
jpG8GT's Avatar
Where did you get your Bilstiens? Sorry for thread jacking.
Sent from my fresh lubed iPhone
2009.1 Evoke Gray GT prem. sport no roof. CTS-V Brembos front and rear with CTS-V wheels, FE3 and Eibachs, Grill mod with custom brake coolers. Tranny cooler, Power steering cooler, RotoFab Intake. Pacesetter LTs, Custom Hooker MaxFlow Axlebacks, SS clone tips. HP Tuners and Rick Crawford tuned with Little Lunati Cam.
jpG8GT is offline   Reply With Quote
Old 11-06-2012, 12:54 PM   #3
TheStevo
TheStevo's Avatar
Ordering them tonight
and through GSL Rallysport, you can look them up on FB.
Old 11-06-2012, 01:47 PM   #4
GT Drew
You want the regular Kings. IIRC from an old thread. Kings are 30% stiffer than stock. HD's are 50%, really track only stuff.
Old 11-06-2012, 04:31 PM   #5
Monaro@JHP
Site Sponsor
Monaro@JHP's Avatar
50%, really track only stuff ???
and ALL G8 coil overs 150%-250% stiffer than stock and not track only stuff ?
There is no stock in the US.
For all stock, pricing, availability and time of shipping to US, please contact JHP Australia directly.
http://www.jhpss.com/Pontiac-G8/ContactUs.htm
I can only answer technical questions (on my own time).
Monaro@JHP is offline   Reply With Quote
Old 11-06-2012, 05:17 PM   #6
TheStevo
TheStevo's Avatar
So then what would the HD's be for?
Old 11-06-2012, 06:41 PM   #7
TheStevo
TheStevo's Avatar
also monaro, do you have all the king springs in stock? also do you have the super pro strut mount bushings with bearings in stock?
Old 11-06-2012, 06:41 PM   #8
Monaro@JHP
Site Sponsor
Monaro@JHP's Avatar
it's called options. What's the V8 engine for? What's leather interior for? It's all about how much you're willing to sacrifice your performance for the right quality. But calling them track only is ridiculous. Because if they are track-only, then all coilovers should be driven on rails only.
Old 11-06-2012, 07:28 PM   #9
pinhead66
pinhead66's Avatar
Agreed with Monaro. 30% stiffer than stock is noticable but no where near uncomfortable. I have the Pedders OE height springs and they are not too stiff at all. Now I kind of wish I went with a 50% stiffer spring. I'll have to check out the King HD stuff for sure.
So which HD Kings would give close to OE height? I'm guessing the 150SLHD and the 152SLHD?
Also are the HD King springs progressive rate or linear?
pinhead66 is offline   Reply With Quote
Old 11-06-2012, 08:22 PM   #10
TheStevo
TheStevo's Avatar
ugh me and monaro posted at the same time lol, the post from me right above yours was for you lol
Old 11-06-2012, 08:31 PM   #11
Monaro@JHP
Site Sponsor
Monaro@JHP's Avatar
HD still progressive
OE height is ~395mm
Old 11-06-2012, 08:54 PM   #12
Monaro@JHP
Site Sponsor
Monaro@JHP's Avatar
king fronts are 180-280 and if I remember right HD is 240-360
The soft portion is about only one inch of initial suspension travel meaning that if the bump on the road is over an inch tall, you will feel it more, but if the bump is less than an inch tall, you won't notice much difference from the stock height.
Old 11-07-2012, 01:19 AM   #13
TheStevo
TheStevo's Avatar
Or dont answer my question...
Old 11-07-2012, 02:07 AM   #14
5litrarag
The Mustang dude
5litrarag's Avatar
theres nothing wrong with a higher rate spring as long as you have dampers to match them.... I'd go HDs with those bilsteins.
95 Mustang GT convertible 347 stroker
95 Cobra coupe Rotrex supercharged
The new baby - 09 White Hot G8 GT
Tinted, badges deleted
5litrarag is offline   Reply With Quote
Old 11-10-2012, 12:42 AM   #15
TheStevo
TheStevo's Avatar
Just to let you guys know, ive ordered A set of Bilsteins with king springs and I will be doing a review on them once they are installed and everything.
Old 11-13-2012, 06:44 PM   #16
Todasi
Todasi's Avatar
What were the part numbers for those Bilsteins you ordered? Why didn't you get the Bilstein springs? You should ask Bilstein which springs to get.
-Chad H.
09 G8 GT, White Hot
Suspension: VMR 19" V701 255/40/19, 285/35/19 Conti DW's
Eibach, Koni, Lovells, BMR
Brakes: Brembos Black/White
Engine: VCM OTR, RCR TB/Intake/Heads,
223/231 .625 .622 111+0, RCR tuned
Kook's
Coan Triple-Disk 3100, 3.45 fd
11.770 @ 118.11 mph 4130 lbs
Todasi is offline   Reply With Quote
Old 11-14-2012, 01:06 AM   #17
TheStevo
TheStevo's Avatar
Dont think there are exact part numbers in a Bilstein catalog for them.
Dont think Bilstein makes springs for our car since everybody recommends Kings.
Old 11-14-2012, 07:24 AM   #18
hayabusa160
This is just the struts not coil overs
So they don't have springs
http://www.g8board.com/forums/signaturepics/sigpic4288_1.gif
Kooks long tubes, Kooks axle backs, rotofab cai, ported tb, koni yellow shocks, h&r springs, bmr bushings kit, rear toe and traction arms. Bmr sway bars. forgestar f10 20x9.5 35 offset 275/30/20, 20x10.5 42 offset 285/30/20
hayabusa160 is offline   Reply With Quote
Old 11-14-2012, 08:47 AM   #19
JonRobbinSS
JonRobbinSS's Avatar
The insert for the front is PE3-H509. Since it is a B8 insert (shock only) Bilstein only suggests that this is good for lowered applications. They also give the nod to full ride height for its use. Spring choice is up to you with King, H&R, and Eibach being some of the popular choices
09 SRM GXP M6 Onyx VIN# 208718
#13 of 1829 GXPs
#2 of 171 SRM GXPs
Consolidated list of Mods to the car
JonRobbinSS is offline   Reply With Quote
Old 11-15-2012, 11:29 AM   #20
Todasi
Todasi's Avatar
Not trying to thread-jack, just trying to get more info about other suspensions available for our cars.
Thanks for the input folks, been following thestevo on this as I was the first person to buy Bilstein (B12 kit) for my Acura TSX (same as Euro Honda Accord) a while back and they where awesome riding. My contact at Bilstein can get anything as long as I can get him the product number.
Looking at some of the Australian forums they seem to like the Boge shocks struts, H&R set-up and the Bilstein set-up.
Anyone have any input on the Boge set-up?
I read the H&R set-up (threaded shock/strut) is built by Bilstein and in $2380 down under, any info on that either?
-Chad H.
09 G8 GT, White Hot
Kook's
