LED Front Turn signal Switchback write up - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Appearance / Detailing
Old 11-06-2012, 06:36 PM   #1
wintershrinkage
wintershrinkage's Avatar
Post LED Front Turn signal Switchback write up
Hey everyone,
So i just installed my LED Switch back turn signals and i noticed that there arent really any detailed step by step instructions on how to install them. So i thought that i would make one
Just a quick note:
-You will not have to remove your headlight assembly
I bought the "6K TYPE 2 DUAL COLOR CHANGING WHITE AMBER SWITCHBACK 92 TURN SIGNAL BULBS 1157 2057 "
http://www.vleds.com/1157-wa-hv-6k.html39.99 from V-LED
***NOTE: They no longer carry the 92 LED turn signal bulb I had put into my car. I have since then upgraded to the V3 TRITON lights. the link above will take you to the "42 HIGH POWER LED TURN SIGNAL."***
as well as "6 OHM 50W 2 BULB LOAD EQUALIZER RESISTORS LED TURN SIGNAL BLINKER FIX | 1 PAIR"
http://www.vleds.com/resistors/led-l...ix-1-pair.html
Some things that you will need for this:
-Pliers
-Electrical Tape
-X-acto knife
-Rag (to whip hand of grease)
-Small flat head screw driver
-And a flashlight or work light
Pre-Step(Optional): You can disconnect the negative terminal to the battery if you want. I didnt because i didnt want to have to constently connect and disconnect it while testing the the lights.
Alright, on to the show
We will start with the driver side. You will want to remove your stock/aftermarket intake system. If you dont know how to do that there are, many threads out there that tell you how to do that.
Once you have the intake out, disconnect the headlight wiring harness. In order to do this, take your flat head screw driver, and place it between the red clip and the main black harness.
Carefully twist the screw driver so that you are able to stick the screw driver in a bit more and pry up on it. Once it is pulled up enough to be able to stick your fingers in there, put your finger into the clip and pull up on the red clip until it wont go up anymore. Once you have done that grab hold of the black harness and pull out. You should have this in your fingers:
Once you have done that, remove the electrical tape from the start of the harness till you hit the intersection of the wires. You want to do this so you can have access at the wires inorder to apply the blue wire taps to them.
Now that this is done, you want to remove the stock turn signal bulb. In order to do this reach into the engine bay to the right were the headlight assembly is. Feel around till you feel this:
Twist the bulb and gentle pull it out. Now that you have done that, push gentle and turn the bulb to take it out. Insert your new switchback bulb and carefully insert it back into the housing and locking it in place.
The next thing we are going to do is apply the resistor to the wiring harness to prevent hyper flashing. In order to do this you must find the white and blue wire put your wire tap on the wire and put your resistor cable in the other slot. grab your pliers and firmly squeeze down on the clip so that the metal piece is flush with the surface of the wire tap.
Next we then want to connect the other end of the resistor to the ground cable. There is 3 black ground cables, you can connect your wire tap to any of the black ones. So just put your wire tap on the ground cable and put the other end of the resistor. Take the pliers again and press down on the metal piece till it is flush with the surface of the wire tap.
In the end it should look like this:
Now that this is all connected, plug the harness back into the headlight. To do this place it on the headlight connector and press down on the red clip.
Lets the headlight now. Go to your car and turn your headlight knob to parking breaks. If all works well, the light should light up as white. If not check your wire taps to make sure that they are connected properly.
The next test is to see if the turn signal works and doesn't flash. Turn the key to pre-ignition(turn before the engine start), turn the left turn signal on and see what happens. If it blinks at normal speed after three blinks then your connect is good. If it hyperflashes after 3 blinks, your resistor isn't connected properly to your wires.
Now that everything is working you want to mount the resistor. You want to mount it on double sided tape and put it in a secure place where it wont interfere with any of the engine parts. When you look in your engine bay there is a metal shaft that runs front to back, i mounted my there.
Once you have that mounted get your electrical tape and rap up your cables on the wiring harness. Like so:
Once it is all done it should look and function like so:
[YOUTUBE]http://youtu.be/cEf3c9ikyjs?hd=1[/YOUTUBE]
Now on to the passenger turn signal. This one is a bit more tricky as it requires you to come in through the wheel well inorder to gain access to the turn signal bulb without having to take the headlight out or the fuse box out. First you want to turn your wheel all the way to the left to gain access to the front wheel well. Once this is done remove the 3 clips holding the plastic piece to the car.
Now here comes the tricky part. In order to remove the turn signal bulb, you have to reach up into the housing to grab the knob for the turn signal. Insert your arm about half way into the engine bay through the tire well , you will then feel or even see the passenger side horn, you have to go around the hard to get at the turn signal bulb. It is a little difficult and took me a while to get at it, but with a little time and patience you will get at it.
Once you have the bulb, twist it, and carefully remove the bulb. Once it is removed and out of the car, take the stock bulb out and replace it with the switch back bulb. CAREFULLY insert it back into the housing with out damaging the bulb. This will take you time.
After installed, do what we did earlier to disconnect the harness: take your screw driver, pry up on the red connector, pull the harness of, unwrap the electric tap from the wire, put your wire taps on to the wire harness and the resistor, and then test your lights.
If they all work, mount your resistor(remember to use double sided tape), wrap out the harness in electrical tap, and test again to make sure everything still works. If all goes well you can put your car all back together. Put the pins back into the wheel well cover and there you go.
ALL DONE!!
Hope you enjoy your new LED switch back turn signalss
If you have any question regarding anything, dont hesitate to write on this forum or PM me.
Have a good one everyone!
2009 Panther Black Pontiac G8 V6
Performance: AIRAID Throttle Body Spacer, Roto-Fab Cold air intake, Pacesetter Headers, HFC, Solo Catback, Overkill Tune
Apperance: Chrome Camaro wheels, Quad-Projector Retrofit,35w HID fogs, V-LED led's all around
Sound System: Subs-Rockford Fosgate P3-2X12, Speakers-Rockford Fosgate P165, Amps-Rockford Fosgate R1200-1D and P600-4
wintershrinkage is offline   Reply With Quote
Old 11-06-2012, 10:52 PM   #2
Rubbabubi
Rubbabubi's Avatar
Looks awesome! I've been debating on doing this and I'm wondering if anyone has any preference on the V-Led switchbacks vs. the autolumination ones. I know you used the V-Leds on your car, but they are double the price of the autolumination ones.
-Dallas
2009 Pontiac G8 GT Liquid Red Premium/Sport, 20" MRR GT1 Staggered wheels, Superchips Cortex, Vararam OTR, Solo Axle-back w/ 3.5" tips, x-pipe, 20% tint all around, 6000K DDM HIDs, LED fogs, TS|S Fender Badges, GXP Diffuser, Spare tire kit, Maverick Man CF Spoiler, Blacked Out Front Grills, Belkin Bluetooth Audio
Rubbabubi is offline   Reply With Quote
Old 11-06-2012, 11:57 PM   #3
JCMG8
Fwiw, I have been running autolumination AW switch backs for past two years or so, the whole time they have also been my DRLs. No problems.
9.5 RPM (Red Passion Metallic) Sport /Premium
ICOM 208H
"Experience is what you get when you didn't get what you wanted."- unknown
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. -red green
<img src=http://www.g8board.com/forums/signaturepics/sigpic9701_2.gif border=0 alt= />
JCMG8 is online now   Reply With Quote
Old 11-07-2012, 09:12 AM   #4
wintershrinkage
Im not to sure about autolumination bulbs, but i have heard great things about them!
Old 11-07-2012, 07:36 PM   #5
Blakeg8gt
MRG82U
I haw been planing on geting these, so thanks for the write up def will help
Blake Faucett 2009 White hot g8gt
just a 4door with a little boost
Blakeg8gt is offline   Reply With Quote
Old 11-07-2012, 08:00 PM   #6
JCMG8
the write up is good, I suggest avoiding the vampire connects in environments with moisture exposure, especially salt exposed, as corrosion may have you chasing gremlins sooner than you think. The tape job will look good today but will not stop moisture longterm unless you use some 3m 2155 rubber splicing followed with some super 88. Keep those connections as dry as possible.
ICOM 208H
Old 11-08-2012, 04:05 AM   #7
wintershrinkage
The resistors i used contained a special compound that doesn't allow moisture or salt into the clip. But your right i should find another way to ensure not moisture or salt is ever collected in the wire taps
Old 11-08-2012, 02:36 PM   #8
TurboMike
I had VLeds and had two of them fail. They started blinking/strobing when doing a turn signal on a hot day or if I've been driving a long time at night. I assume it was heat related. After replacing the bulbs twice Vled told me they wouldnt be warranteeing them anymore. Switched to Autoillumination bulbs and never had a problem since.
I mounted my resistors under the dash near the BCM. Four wires to each turn signal wire, then the other four ends of the resistors to a ground (four because I did the back bulbs LED at the same time). Then I just replaced the turn signal bulb, no need to remove the headlight or do any wiring there.
TurboMike is offline   Reply With Quote
Old 11-09-2012, 12:18 AM   #9
wintershrinkage
Which bulbs did you get from autoilluminations?
Old 11-09-2012, 12:21 AM   #10
SmokeyBear911
SmokeyBear911's Avatar
The 60 LED's are the brightest of them all from autolumination....
Had them for 3 years now and ZERO issues...
Liquid Red GXP, Sun and stick !
#611 of 1829
SmokeyBear911 is offline   Reply With Quote
Old 11-09-2012, 12:25 AM   #11
wintershrinkage
Do you know the exact name of it on the site so i can see it? Do you have any picture of them or videos i could see?
Old 11-09-2012, 12:46 AM   #12
SmokeyBear911
60 Led SMT Tower
http://autolumination.com/1156_1157.htm
When I put the turn signal on it goes white yellow...
If you need video...let me know...
#611 of 1829
Old 11-12-2012, 03:48 PM   #13
wintershrinkage
Mind if i could see a video as well?
Old 11-12-2012, 10:55 PM   #14
SmokeyBear911
I'll shoot some video after I here in a little while...
#611 of 1829
Old 11-13-2012, 12:42 AM   #15
SmokeyBear911
Well.. here ya go...
http://youtu.be/g8mqk2JczPA
First half of the video is beter white balance.
Good enough?
#611 of 1829
Old 11-13-2012, 01:16 PM   #16
wintershrinkage
Thanks!
Old 11-14-2012, 02:19 AM   #17
hazer396
Facebook Moderator
hazer396's Avatar
who's supra in the back?!
BC Racing Coilovers/6;4 Brembos/Tons of BMR Goodies/One-off Hazerwerks Lights/GXP Bumper/Holden Spoiler/Forgestar F14s/Much more!
3.6 V6: Headers/Intake/Insulators/Exhaust/Tune 242whp 260wtq 15.3 @ 92
6.0 V8: Pypes Headers/Solo 3"/RCR Blower Cam/Adam Schwab Heads and Intake 409whp 389wtq 12.2 @ 114
6.0 LSA:
12.5psi/Wiseco Pistons/Compstar Rods/Meth Injection Numbers coming soon!
hazer396 is offline   Reply With Quote
Old 11-14-2012, 06:42 PM   #18
SmokeyBear911
No Idea, he moved... Was trash...
#611 of 1829
Old 11-15-2012, 02:16 AM   #19
hazer396
Facebook Moderator
hazer396's Avatar
damn what a waste
6.0 LSA:
Old 11-19-2012, 06:32 PM   #20
Rich G
Rich G's Avatar
great write up appreciate it thanks...
2009 SBM Pontiac G8 V6
Mods tints 35's front 5's rear
Solo Mach Shorty Cat back with a J Pipe
Colour Shifting Halos AAC STYLE...
Spyder LED Tail Lights
GXP Rear Diffuser
Bohnman front Splitter
Blue Lamin-X Fogs
Roto-Fab CAI
Third Shift Studios Concept Dart
MRR GT5 wheels 19x8'5/19x9'5
Hankook Ventus V12 evo's
255 40 19's front 275 35 19's rear
Video in Motion Courtesy Zepcom Performance
Overkill Tune
OGOC Member
Rich G is offline   Reply With Quote
