Torque mgmt timing during coastdown? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > PCM Tuning / Dyno Results
Old 11-09-2012, 10:10 AM   #1
blkscooby
blkscooby's Avatar
Default Torque mgmt timing during coastdown?
With my recent cam install, I have found that my car uses the TqMgt timing during closed throttle coastdown at low speeds, like under 25. If i keep the TqMgt reasonable like 0* the timing oscillates between 0 and something like 20* while coasting and then the car will surge when I come to a stop and it downshifts into 1st. If I increase it to 8*, then the timing is 8* during coastdown and no surging but of course the shifts are harsh and tires bark.
I do have the Idle air dialed in and it doesn't surge on idle, so that's not the issue
Why does it use TqMgt timing and not coastdown timing table? In my logs, the timing pulled due to TqMgt matches what is occurring and I have experimented by changing TqMgt so I definitely know that is what is happening. But why?
Sent from my DROID RAZR using AutoGuide.Com Free App
NEW- 2009 PSM GT- Vararam/ RCR 219/227 cam/ Kooks 1 7/8" LT/ 3" exhaust/ 3200 Yank/ 3.45 gears/ HSW Nitrous/ HPT self-tune
SOLD- 2008 LR G8 GT /
Intake / HPT self-tune / E85 / 160* stat / Kooks mids / Dynomax ST axlebacks / Xpipe / 219/233 Comp Cam
blkscooby is offline   Reply With Quote
Old 11-09-2012, 10:42 AM   #2
DRUMSBH
Super Moderator
DRUMSBH's Avatar
try shooting G8-4-Speed a PM, he fixed mine.
08' Pontiac G8 GT PBM
11.323@121.66 Rock Falls Raceway 10-11-14
N/A RCR car.
DRUMSBH is offline   Reply With Quote
Old 11-09-2012, 11:37 AM   #3
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
That's interesting Jeremy , do you have a log ?
Can you post a print screen with your Trans TM settings ? or post your tune, or email me your tune. ?
Mine was doing that after the verter install, but it was also affecting my initial WOT punch in any gear. Tqmgt was closing down my TB upon initial WOT, fairly ****ty feeling, especially after doing a mod, i thought something was messed up
Old 11-09-2012, 01:39 PM   #4
blkscooby
blkscooby's Avatar
Email sent.
Old 11-09-2012, 01:43 PM   #5
blubyya
blubyya's Avatar
Post results, I'd like to see what the reason is too. I believe I might have something similar.
2008 gt, lsa 9psi, meth, rcr blower cam, Lingenfelter ls3 heads, ls7 maf, crawford tb, kooks headers &mid pipe magnaflow mufflers, spohn toe & lowers
10.38 130mph 1.56 60ft PB
11.29 122pmh 1.67 60ft (old n/a setup)
blubyya is online now   Reply With Quote
Old 11-09-2012, 05:57 PM   #6
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Jeremy, this is something different than what i had. Your TB is not closing like mine, your engine timing is just bouncing, just after tqmgt kicks in, i guess from CT tqmgt because your tps remains shut constant.
Old 11-09-2012, 06:42 PM   #7
blkscooby
blkscooby's Avatar
I'll test it on the way home by disabling all CT Downshift TqMgt
Old 11-09-2012, 07:08 PM   #8
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Disable the master CT tqmgt and see what happens.
Old 11-09-2012, 07:18 PM   #9
gtp6515
gtp6515's Avatar
Subscribed...mine is rough on 2-1 as well.
219/223 .625 .625 112 "Little Lunati", 11.78 @ 119, 440/421 dynojet, Crawford heads, tb, intake. Kooks 1 3/4 lts and solo Mach balance catted with added Solo resonators, VCM, 3.45's, stock stall.
gtp6515 is offline   Reply With Quote
Old 11-09-2012, 07:30 PM   #10
DRUMSBH
Super Moderator
DRUMSBH's Avatar
mines fine now... didnt you have Rick fix it? No surge cruising anymore as well.
N/A RCR car.
Old 11-09-2012, 08:51 PM   #11
blkscooby
blkscooby's Avatar
Disabling CT had no effect. Tried Sport shift and it was somewhat better. I'll send a log tonight
Old 11-10-2012, 02:27 AM   #12
blkscooby
blkscooby's Avatar
Could have something to do with the torque follower tables. I haven't changed these from stock yet.
Here's a quick log from tonight with the CT TqMgt disabled.
Old 11-11-2012, 03:16 PM   #13
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
In the logs she seems to do this during the 4-3 downshift, with no throttle. it's interesting that the master switch didn't do anything. If it's not CT downshift, because the master TM switch didn't do anything, then perhaps it'll be flare tgmt ?
re-enable the CT tqmgt master, and set the flare tqmgt downshift to none, dang stupid trans TM parameters we have , hope you get it resolved.
Old 11-11-2012, 11:31 PM   #14
blkscooby
blkscooby's Avatar
Thanks Dario. Ill try tomorrow.
Old 11-13-2012, 09:19 AM   #15
blkscooby
blkscooby's Avatar
Looked at the tune again last night and realized I hadn't disabled the Master CT TqMgt switch. Tried that and it seems to have solved the issue.
Here's a log from this morning.
Old 11-13-2012, 12:07 PM   #16
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
, glad to see you nailed this down Jeremy.
Now that you have figured the issue is the CT Downshift TM, you could try to re-enable the master switch, and disabled the tip in/flare CT downshift TM (set it to none) and see if that still prevent the CT TM from causing the issue. if that doesn't do it, then put this switches back to how you have them now, and disabled the CT downshift master switch again, it's better to use the smaller TM switches first, if that doesn't do anything, then the master will be fine. don't know why would we have TM in CT, but oh well, dang stupid trans TM parameters we have , i'm sure some of them are there for a reason.
Have fun.
Old 11-13-2012, 10:21 PM   #17
gtp6515
gtp6515's Avatar
I was hoping this would help me as well. My ct downshift is already disabled.
Old 11-13-2012, 10:25 PM   #18
blkscooby
blkscooby's Avatar
Yeah next is determine why DOD is not engaging...
Old 11-21-2012, 08:11 PM   #19
blkscooby
blkscooby's Avatar
Bluegoat informed me that DOD doesnt function if COT is disabled.
Old 11-21-2012, 08:50 PM   #20
bluegoat06
HPT Pro Tuner
bluegoat06's Avatar
Enjoy
