Time to loose some weight? - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Wheels / Tires
Wheels / Tires Sponsored by: Discount Tire
View Poll Results: What's your opinion?
A. F:18x8.5" ET35 - 20.10 lbs, R:18x9.5" ET58 - 20.65 lbs 5 33.33%
2. F:18x8.5" ET35 - 20.10 lbs, R:18x10" ET43 - 21.95 lbs 1 6.67%
C: F:18x9.0" ET42 - 20.75 lbs, R:18x10" ET43 - 21.95 lbs 3 20.00%
4. F:18x9.0" ET42 - 20.75 lbs, R:18x9.5" ET58 - 20.65 lbs 6 40.00%
Voters: 15. You may not vote on this poll
Old 11-09-2012, 04:22 PM   #1
SRG963
Its Good To Be Tha King
SRG963's Avatar
Question Time to loose some weight?
I've been thinking about getting a new set of EC-7 wheels and shed some wheel weight, about 5 pounds per corner.
I know option A is safe, no rub. I think option 2 is about the same as what I'm currently running, just a bit wider towards the inside on the rear if my math is correct...and I think C may be pushing it on the front offset. What's your opinion?
I plan on mounting 275/40/18 all around.
My options are:
C. F:18x9.0" ET42 - 20.75 lbs, R:18x10" ET43 - 21.95 lbs
(Options 2 and C have a more concave rear wheel, which I really like)
I'm currently running:
F:19x8.5" ET45 - 26ish lbs, R:19x9.5" ET50 - 28ish lbs
Trigger - Fully Loaded 2008 Stealth Blue Pontiac G8 GT
Rotofab/Cortex/BMR/Pedders/VMR/
Adams/OBX/Nitto
PRAISE THE LOWERED
SRG963 is offline   Reply With Quote
Old 11-09-2012, 04:31 PM   #2
SRG963
SRG963's Avatar
Options 2 and C would have the second profile on the rear, so it would be a bit more concave on the rear than the front. I really like that look, so I'm leaning towards 2 or C.
Adams/OBX/Nitto
PRAISE THE LOWERED
Old 11-09-2012, 04:56 PM   #3
Slizzo
Slizzo's Avatar
Go option 4, will fit perfect on the car, don't worry about the fronts. You could do a 9.5" on a +40 and be fine.
2011 Radiant Silver Metallic CTS-V Wagon - Corsa Axleback, AirAid Intake
2008 Panther Black Metallic G8 GT *Sold 6/11/14*
Slizzo is offline   Reply With Quote
Old 11-09-2012, 11:39 PM   #4
JESUSFREAK702
JESUSFREAK702's Avatar
The +58 will tuck too much IMO.
I'd say option 2.
Mods
Tuned by Frank @ Revolution Raceworks
Rotofab CAI
Pacesetter LTH 1 3/4
cat delete
Pypes Violators w/magnaflow x pipe
Staggered 20" STR101
245/35R20 and 275/30R20 Delinte D7
D2 Coilovers
5% tint
JESUSFREAK702 is offline   Reply With Quote
Old 11-10-2012, 12:01 AM   #5
Slizzo
Slizzo's Avatar
I'd say option 2.
Won't tuck too much. CTS-V rear wheels are a 9.5" wide on a +56et offset...
Old 11-10-2012, 03:37 AM   #6
pinhead66
pinhead66's Avatar
Do the 18's clear Brembos? It looks like you want to stay with a staggered setup right? If so then my vote would be 4.
If I had to do this I would do a 18x9.5 +43 all around with a 3mm spacer up front. Then I can do 275's on all 4 corners and able to rotate tires.
pinhead66 is offline   Reply With Quote
Old 11-10-2012, 08:14 AM   #7
SRG963
SRG963's Avatar
I can do 275's all around with all my options
Rotating is just a waste of time IMO.
Updated first post with tire info.
Adams/OBX/Nitto
PRAISE THE LOWERED
Old 11-10-2012, 08:25 AM   #8
SRG963
SRG963's Avatar
So I checked my math, and 2 and C will push the rear out 13mm, and I'm only loosing 5mm with the tire, so it's now between option A and 4. A is more than a half pound less...
Adams/OBX/Nitto
PRAISE THE LOWERED
Old 11-10-2012, 09:36 AM   #9
Zodiac
Sarcasm Personified
I voted A. The weight difference was better and I think that setup will look best.
2015 Mustang GT Auto, 3.55, recaro seats, spoiler delete, Solo catback, SVE Drift 19x9.5 w/ 275/40/19's.
2015 Jeep Cherokee Latitude V6
Zodiac is offline   Reply With Quote
Old 11-14-2012, 11:02 AM   #10
matthewo
if you want to do 275s all around why not just do 9 or 9.5s all around. if you do 9 up front and 10 in the rear, or 8.5 up front and 9.5 in the rear with 275s all around, your front tires are going to look larger then the rears, and that just doesnt look right.
there are the nurburgrings, and 18x9.5 et 40mm is a perfect offset for 9.5 and 275s all around. they are 20lbs each too, and clear the brembos.
matthewo is offline   Reply With Quote
Old 11-14-2012, 08:14 PM   #11
PSMG8GT
PSMG8GT's Avatar
Cough cough TSW NURBURGRING cough cough
MODS:
CORSA CATBACK EXHAUST
DBA 4000 SLOTTED ROTORS W/ HAWK CERAMIC PADS
GXP DIFFUSER
FULLY DEBADGED
TSW NURBURGRING 20X8.5/9.5 WITH NITTO INVO 255/35 285/30
PSMG8GT is offline   Reply With Quote
Old 11-24-2012, 11:53 AM   #12
LuminaME
LuminaME's Avatar
If weight reduction is your target ... don't miss to consider new tires weight.
from brand/line to another there might be as much as 5-8lb per tire extra weight.
Michilen and Conti are known for lower weight tires in general.
2007 VE Lumina (V6)
Transformation
LuminaME is offline   Reply With Quote
Tags
apex , ec-7 , lightweight wheels
