Cam in higher mileage L76? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-11-2012, 01:13 AM   #1
357TANK
357TANK's Avatar
Default Cam in higher mileage L76?
I'm planning on doing a livernois stage 1 cam/dod delete over winter but a little concerned cause I have 120k on the car. I currently have good oil pressure. Don't burn any oil. No leaks. Occasionally a couple seconds of lifter tick on cold mornings but I'm sure that's just the dod lifters. IMO it's a very healthy engine and don't think it will be a problem but just wondering how many people have done higher mileage LS cam swaps.
4" Intake with ls7 Maf. 160 stat. Pacesetter LT, H-pipe to straight pipes. Self ported TB. SLP UD pulley. DOD delete. 223/231 .610/.617 112+0. ls3 intake valves. BTR .660 dual spings. BTR pushrods. BTR Trunion. Cometic .040 gasket. Heads milled .020. Pat G tune. AEM wideband. HPTuners. Catch can. Camaro deep trans pan. B&M trans cooler. Avant Garde m310 19X9.5 +33 BFG KDW 275/35/19
357TANK is offline   Reply With Quote
Old 11-11-2012, 01:25 AM   #2
8ualive
Experimentalist
8ualive's Avatar
I put mine in at 112,000 and I have nearly 118,000 now. No probs here. I didn't start modding till after 100k ha!
2008 White Hot G8 GT (SOLD and missed)
- Tuned with HP Tuners (93 octane)
- Vararam CAI
- Solo Performance axle backs w/j pipes and x-pipe
-3.27 Camaro differential
- Kooks 1 7/8 mids w/HFC
- Thumpr cam 219/233 553/536 114lsa
Comp Behive Valve Springs
Circle D 3200
Ported TB (BoWhite)
Rick Crawford ported intake
7.78 @ 90.0 with 1.70 60' corrected to 7.70 DA-1100
-373hp 370tq (before TC) (90 degrees with 3000DA)
12.465 @ 114.06 with 8.03 @ 90.61 (1/8) and 1.90 60'
8ualive is offline   Reply With Quote
Old 11-11-2012, 03:40 AM   #3
thebeast
You are just fine. Besides, all the parts that could fail, you are replacing with new, high performance parts anyways. Just do it and enjoy the results
2008 LR G8 GT
TSP Forged LS3-D1-221/232 RCR Cam-Ported L92's-Squash-Kooks-Solo 3in-BMR-SS wheels and brakes-Kicker-Demon 8 Designs Gauge Pod-BC Racing Coilovers- Custom Earls Tranny Cooler
613/543 old worn out numbers
11.6 at 123 1.92 60ft
New numbers coming soon..........
thebeast is offline   Reply With Quote
Old 11-11-2012, 06:04 AM   #4
Buford
Buford's Avatar
^^^^ this is a great time to do a cam swap. Nothing like taking the heads off, checking everything out, putting nice parts back in, then driving it for another 100k miles problem free.
2008 ProCharged/Pedders G8 - 633rwhp/525rwtq
P1-SC, E85, 10psi, baby cam, Yank 3200
For Sale: http://www.g8board.com/forums/showthread.php?t=65635
Buford is offline   Reply With Quote
Old 11-11-2012, 01:16 PM   #5
gr8t gt
gr8t gt's Avatar
I would install light weight LS3 intake valves and new valves seals.
Rare '09 MGM GT7 ONYX/RED
TVS1900 @ 6.5psi, Kooks LT, Cats, SLP Powerflow Mufflers, Swiss cheese stock air box, LS9 Cam and Injectors, BAP
516 rwhp-462 rwtq (time for larger injectors and more boost)
'11 Silverdo LTZ DuraMax
Stock (for now)
'12 Mustang GT/CS
Loud Ass Flowmaster's (wife's car)
gr8t gt is offline   Reply With Quote
Old 11-11-2012, 02:16 PM   #6
357TANK
357TANK's Avatar
Those are the type of responses i was hoping for. I am defiantly planing on putting in new valve guide seals and at least getting the heads resurfaced and a valve job. was considering getting heads ported, milled, and different valves but wasn't sure it was all that necessarily. I'd like to hit 410-440 whp range after the cam and headers are done. But more importantly i'd like to be running mid 12's. I'd go with a bigger cam but can't afford to do headers, cam, stall, tune, etc... all at once. and the livernois stage 1 cam seams to be pretty good set up with supporting mods.
