Cam options with stock stall!? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-11-2012, 08:05 PM   #1
glanzergtx
glanzergtx's Avatar
Default Cam options with stock stall!?
What options do we have for cams when running a stock stall?
Your normal 600whp+ 4dr family car
glanzergtx is offline   Reply With Quote
Old 11-11-2012, 08:14 PM   #2
gr8t gt
gr8t gt's Avatar
I would say none. Even with the stock cam you loose a lot of low end because the converter is so tight.
Rare '09 MGM GT7 ONYX/RED
TVS1900 @ 6.5psi, Kooks LT, Cats, SLP Powerflow Mufflers, Swiss cheese stock air box, LS9 Cam and Injectors, BAP
516 rwhp-462 rwtq (time for larger injectors and more boost)
'11 Silverdo LTZ DuraMax
Stock (for now)
'12 Mustang GT/CS
Loud Ass Flowmaster's (wife's car)
gr8t gt is offline   Reply With Quote
Old 11-11-2012, 08:28 PM   #3
DavesWhiteHot
DavesWhiteHot's Avatar
^^^ huh?? There are plenty of options out there for aftermarket cams while still using your stock converter. I have a stock converter and the VMS 1.5 cam and it works fine. I also have another cam, new in box, that I am needing to sell. I bought it intending to try it out in my car to get some extra midrange torque, but I just don't have the time to swap and really need the $ for other things that have come up (tires, brakes, fix this dang airbag fault). It's 223/227 duration, .610"/.613" lift on LSL lobes, and 114 + 2 LSA. It's a 3 bolt.
If interested shoot me a PM. It would be a great choice for an intake header car with a stock converter.
New: '12 Mustang GT 5.0 6MT (SR lowering springs, Borla Touring axle back, CAI, Bama tune, 3" O/R H pipe)
***SOLD :"( ***
'09 White Hot G8 GT, Pat G cam (.634"/.608", 223/230, 112 + 2), Pat G tune, HSRK, Rotofab CAI, Magnaflow Catback, DT Tri-Y LT's, Rick Crawford intake, throttle body, and ported/milled heads, stock gears & stock stall, H & R springs, Lovells poly strut mounts, VMR V710 wheels, 11.86 @ 120.32 mph (1.94 60')
DavesWhiteHot is offline   Reply With Quote
Old 11-11-2012, 08:36 PM   #4
glanzergtx
glanzergtx's Avatar
^you got pm sir!
Old 11-11-2012, 09:20 PM   #5
Troy Trackbeast
Super Moderator
Troy Trackbeast's Avatar
Mine does great on the stock stall. My dyno video has the cam specs.
Sent from my iPhone using Autoguide.com App
Troy Trackbeast is offline   Reply With Quote
Old 11-28-2012, 07:11 PM   #6
IceIceRedHot8
What about stock stall and AFM hardware still in place with 1.85 rockers?
Glanzer are you deleting the DOD?
08 GT/Vararam/OBX LTH/catless/DoDdelete/TSP(229-236).623.617
CompTrunion/TSPpushrods/160therm/AEMWideband/Hp Tuners
IceIceRedHot8 is offline   Reply With Quote
Old 11-28-2012, 07:16 PM   #7
Troy Trackbeast
Super Moderator
I've seen people have some real good results with that as well.
Old 11-28-2012, 07:16 PM   #8
glanzergtx
glanzergtx's Avatar
Yeah. I got a Texas-speed cam.
Old 11-29-2012, 08:09 AM   #9
cacsrx1
Which one?
SRM GXP M6
Rotofab
Kooks 1-7/8 LT's catted X and stock GXP axelback
BMR Trailing Arms and Toe Rods
PatG Cam Motion 226/234 114+4 cam and tune
BTR springs and pushrods
cacsrx1 is offline   Reply With Quote
Old 11-29-2012, 11:20 AM   #10
MSU120
MSU120's Avatar
Livernois 1c cam here. Works great with stock stall.
SOLD--2009 G8 GT, Livernois "Mini Stroker" with 1C Cam
2300 Maggie, 1:1 Cog Drive, 60# Injectors, Roto-Fab Intake
Kooks 1 7/8 Mids with High Flow Cats, Borla Cat Back
ZL1 Fuel Pump, Kenne Bell BAP, 160 Degree T-stat
Camaro 3.27 Rear Diff, Livernois Tune
Monroe Sport GT Shocks/Struts with King Springs
BMR Front Sway Bar, BMR Strut Mounts and Bearings
Camaro Transmission Pan
Staggered Bretyon GTS-AV Wheels, Nitto NT05 Tires
605rwhp and 569rwtq
MSU120 is offline   Reply With Quote
Old 11-29-2012, 11:43 AM   #11
jpG8GT
jpG8GT's Avatar
DRUMSBH on here is running cam, ported heads and Rick Crawford intake on stock stall. Ran a 12.05 on street tires. Awesome setup! I think it is most all in who tunes your car with a stock stall. PatG and Rick Crawford know there stuff. Thing was a monster at GONE this year. Thats the route i'm gonna go since i'm not a drag racer and love the road course. Don't want to lose any DD from a stall.
2009.1 Evoke Gray GT prem. sport no roof. CTS-V Brembos front and rear with CTS-V wheels, FE3 and Eibachs, Grill mod with custom brake coolers. Tranny cooler, Power steering cooler, RotoFab Intake. Pacesetter LTs, Custom Hooker MaxFlow Axlebacks, SS clone tips. HP Tuners and Rick Crawford tuned with Little Lunati Cam.
jpG8GT is offline   Reply With Quote
Old 11-29-2012, 12:03 PM   #12
Troy Trackbeast
Super Moderator
yea he has gears also...
Rick built my car from the ground up and I ran a 12.1 @ 118.48
Old 12-01-2012, 08:53 AM   #13
gardnertroy
gardnertroy's Avatar
if you want to keep your stock stall then i would go with Vector Motorsports 1.5 cam. it is perfect for a stock stall. you can even add a stall later on with that cam if you decided to. guys are running low 12's with it and ive had nothing but good experiences with vector they got me down to 11.68 at 116mph in the quarter with the 2.5 cam
RCR 223/231 111+0
RCR heads
RCR ported intake/TB
Kooks 1 7/8 LT's.
Kooks x pipe
Magnaflow axle back
Vararam / RCR Ram Plate
Airaid 4" housing/ ls7 Maf
Slp pulley
Fe3/BMR
Yank SS4000
3.45 gear
Drag pack
Crawford tuned
N/A pb
11.15@120 1.48 60ft
gardnertroy is offline   Reply With Quote
Old 12-01-2012, 10:04 AM   #14
matt82
matt82's Avatar
I have the same cam as DRUMSBH with an Vararam, tune, and full exhaust I ran 12.5. Its a great cam for a DD, but honestly it would be fine to go a little bigger with a stock stall.
09 MGM G8 GT
Comp cam
PaceSetter 1 3/4 Coated LT
MagnaFlow Cat-Back
Vararam Intake
Yank SS3200
11.95@ 116.64
matt82 is offline   Reply With Quote
Old 12-01-2012, 12:38 PM   #15
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
223/227 .610/.614 113+1 in my pick for a stock stall with ported heads or even without...the 223/231 is a great cam but it takes a better tuner to get the drivability right. I got Troy's idling at 700 with a 223/231 112+0 cam but it isn't easy.
2009 G8 GT- Rick Crawford
1.50 60ft, 10.41 @ 131.4 Comp 234/243 111+0 6.4 N/A
1.53 60ft, 10.59@ 129.7 ALL MOTOR!!! N/A G8 Record Holder
G8-4-Speed is offline   Reply With Quote
Old 12-01-2012, 01:01 PM   #16
Eric_GT
Eric_GT's Avatar
This contradicts everything I have read from 'quality' engine builders.
Eric_GT is offline   Reply With Quote
Old 12-01-2012, 01:24 PM   #17
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
Stock gear, stock converter have cut 1.99 60ft with a 223/231 112+0 cam. Doesn't seem like it lost much......Under 2000 rpm you probably loose a little but the converter stalls at 1800 so how long are you under 2000rpm?
Old 12-01-2012, 01:44 PM   #18
Bo White
Bo White's Avatar
I would spend money on a stall before a cam.
Old 12-01-2012, 02:11 PM   #19
G8-4-Speed
Advanced Member
G8-4-Speed's Avatar
Depends on where you want to be faster, on the street or the track. A stall with a stock cam will get run-over on the street from a roll. MPH rules on the street....et rules at the track.... ET at the track also requires drag radials.
The one area a stall really helps at when using stock gear is at 30 mph and 60 where you are at the bottom of 2nd or 3rd gear. I prefer the 3.45's which you in a better rpm for normal street and highway down-shifts.
Old 12-01-2012, 03:31 PM   #20
Bo White
Bo White's Avatar
Like you said, depending on what MPH and what rear gear you have on weither it will be faster or not with a stall and stock cam.
