After cam, how to get to the dyno? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-11-2012, 10:46 PM   #1
357TANK
357TANK's Avatar
Default After cam, how to get to the dyno?
So I'm going to be doing a cam swap over winter. Now In spring when i pull her out what's my best way to get to the dyno for a tune that is an hour away.
I know I'll have to plug in my old dod valley tray so it's not running on 4. and
I was planning on selling the cortex when I put the car away so I wouldn't have that to tell the computer not to try to engage dod.
Will it try to engage dod even tho the stuff wont be there?
can I drive it to the dyno?
do I need persuade my friend to tow it there?
should I keep the cortex to turn off dod on computer side of things?
4" Intake with ls7 Maf. 160 stat. Pacesetter LT, H-pipe to straight pipes. Self ported TB. SLP UD pulley. DOD delete. 223/231 .610/.617 112+0. ls3 intake valves. BTR .660 dual spings. BTR pushrods. BTR Trunion. Cometic .040 gasket. Heads milled .020. Pat G tune. AEM wideband. HPTuners. Catch can. Camaro deep trans pan. B&M trans cooler. Avant Garde m310 19X9.5 +33 BFG KDW 275/35/19
357TANK is offline   Reply With Quote
Old 11-12-2012, 08:30 AM   #2
OrngG8
OrngG8's Avatar
When I had mine done I was able to drive the car to the dyno but I did have DOD shut off. The car was not happy at all though. Everytime I came to a stop it would shut off the Traction Control and the dash would chime. If your drive is mainly interstate it probably wont be too bad but I have no idea what will happen if you still have DOD turned on in the tune.
Vararam, TSP LS3 cam, DOD delete, Livernois dual springs, Comp trunion kit, 1 7/8 Kooks, Ultra-flows, Holley valve covers, MNM catch can, tuned by Mike Norris Motorsports
Eibach springs+FE3 suspension, BMR tunnel brace, Subframe connectors, and trailing arms, Asetto Garra 18s, BFG Sport Comp2s
TSS Concept darts
OrngG8 is offline   Reply With Quote
Old 11-12-2012, 05:33 PM   #3
joeygr8gt
joeygr8gt's Avatar
Rent a u haul trailer an trailer it. Better safe then possibly damage someting
Sent from my iPhone using Autoguide.com App
kooks LT headers, hi flow cats, x pipe, corsa exhaust, Vararam CAI, ported TB/intake manifold, underdrive pulley, catch can, qtp electric cut outs, 160 t stat, HSRK, H&R lowering springs, BMR sway bar
12.6 @109-old tune
joeygr8gt is offline   Reply With Quote
Old 11-12-2012, 06:00 PM   #4
orangeg8
Offshore Prositute
orangeg8's Avatar
see if you can borrow his hp tuners and do a base tune on it so you can drive it. I think that would be the best option. Example if his shop is closed on sunday, go late saturday, tune it sunday, and go back to him early monday?
Don't complain about life, if you do, try death, nobody has complained yet.
I am no Challenger to this game, I don't go Chargering away, and it is more than just ponies in this beast.
orangeg8 is offline   Reply With Quote
Old 11-12-2012, 06:12 PM   #5
DRUMSBH
Super Moderator
DRUMSBH's Avatar
Turn off DoD. Then just drive easy to tuner. I did mine this past winter and had VMS turn off DoD then drove 1 1/2 hours to a tuner up north. As long as you don't beat on it you should be fine. Depending on how aggressive your cam is or if your adding a stall it could be a bit more of a hassle. Obviously drivability won't be there but your driving it easy because you also don't know what your afr is as well.
Sent from my PG86100 using AutoGuide App
08' Pontiac G8 GT PBM
11.323@121.66 Rock Falls Raceway 10-11-14
N/A RCR car.
DRUMSBH is offline   Reply With Quote
Old 11-12-2012, 06:49 PM   #6
ExpLiciTSainT
Cars are my hobby...
ExpLiciTSainT's Avatar
If you can't turn DOD off, drive in manual mode... DOD will not activate in manual mode.
Old: 353.8
New: 632/530 Mustang Dyno
Old 11-12-2012, 07:24 PM   #7
357TANK
357TANK's Avatar
Thanks guy!
I completely forgot dod doesn't try to activate in manual mode. lol. It's just going to be a livernois stage 1 with a little head work and no stall at this time.
Old 11-12-2012, 08:49 PM   #8
768MPH
768MPH's Avatar
Lol, I kept reading and reading wondering why nobody mentioned this.
2014 SS "Houston Stock"
Rotofab
RCR Intake/RCR TB
LS7 MAF
SW LTs-3" catted X
Corsa Mufflers
Pat G Tune
12.08@114.45 (stock tires suck)
768MPH is offline   Reply With Quote
Old 11-13-2012, 12:15 AM   #9
ExpLiciTSainT
Lol, ironically, I was too.
Old: 353.8
