Firebird raceway 11/16/2012 - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > Regional Forums > South Western
South Western So CA, NV, AZ, NM
Old 11-12-2012, 12:35 AM   #1
STAGEUP
Default Firebird raceway 11/16/2012
I'll be going to see what I can get out of my GXP. Anyone else wanna join?
PBM G8 GXP M6-Self tune,VCM cai, OBX LTs, Kooks axleback, Monster Stage 3 clutch, flex fuel 11.83@116.7 1,353 D.A
2007 TBSS-Self tune, bolt ons 13.06@106.7, 2,200 D.A
1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
STAGEUP is offline   Reply With Quote
Old 11-12-2012, 12:28 PM   #2
jbak
jbak's Avatar
I'll give it some thought !
White-hot G8 GXP...stock stall, 1c cam, NicD tune, Kooks mids, xpipe, Solo axle-back
Maggie w/3.0 pulley added 9 Apr 2015 - 518 rwhp
2.9 pulley added 30 Apr 2015 - 535 rwhp ?
12.2 @ 116 on DRs at SWIR, DA = 4000
jbak is offline   Reply With Quote
Old 11-12-2012, 12:35 PM   #3
blkscooby
blkscooby's Avatar
I going to wait until I get my new headers installed
Sent from my DROID RAZR using AutoGuide.Com Free App
NEW- 2009 PSM GT- Vararam/ RCR 219/227 cam/ Kooks 1 7/8" LT/ 3" exhaust/ 3200 Yank/ 3.45 gears/ HSW Nitrous/ HPT self-tune
SOLD- 2008 LR G8 GT /
Intake / HPT self-tune / E85 / 160* stat / Kooks mids / Dynomax ST axlebacks / Xpipe / 219/233 Comp Cam
blkscooby is offline   Reply With Quote
Old 11-12-2012, 12:46 PM   #4
Silverado777
Silverado777's Avatar
If I can get my gears installed and a retune by then I'll be there.
05 Silver Birch Silverado- Blown 383 Stroker
504 RWHP 627 RWTQ (Sold)
08 IOM G8 GT -VCM CAI, e85 Tune, 3.27 gears, SLP UDP, HSRK, 1 7/8 LT, 3" X Pipe, SOLO Axle Backs, 07 CTS-V Brembos F&R, BMR Sways, BMR Diff, Rear Cradle & Radius Rod Bushings - Dynod 335hp 352tq on base tune, PB 12.99 in the 1/4 (Sold)
2010 Black Raven CTS-V. M6, Full Build, 771whp / 716wtq
09 Pearl Mirage White GSX-R 750, Micron Exhaust, K&N Intake, Power Commander 3, Geared
1/4 Mile - 10.3
Silverado777 is offline   Reply With Quote
Old 11-12-2012, 08:03 PM   #5
desertg8
30 percent chance i will be there. new sfi flex plate installed after exploding the stock one. 3600 stall restalled to 4000 just shipped today from yank. that is the hold up. if it reaches my mechanic thursday i think we will make it. if not i will probably get car back next monday. my drag radials are no longer holding on the track. if they do i am looking to get kicked out.
I will definitely be there the 30th! Good luck! You should go.
WildhorsePass,AZ 12/11/2015
11.48 @ 118.71 DA 2000 feet
Tucson Dragway, AZ 12/31/2015
11.7 @ 119.1 DA 4000 feet
"Silver Shadow"
416 with Lunati crank/rods. wiseco domed pistons. 11.3 to 1 compression. gmpp heads with a little work. 3600 circle d triple disc stall, rotofab, FAST 102 with matching t.b. underdrive pulley, 3.27 Camaro diff., 1 7/8s mids with full 3 inch exhaust. drag radials. (other mods for strength and handling; but not for speed)
desertg8 is offline   Reply With Quote
Old 11-12-2012, 08:07 PM   #6
STAGEUP
4,000 stall?? Wow you're serious! I bet its like a sling shot!
Old 11-12-2012, 08:13 PM   #7
desertg8
it will if the drag radials will hold. but they will not with the 3.27s. i need to reorder the hoosier drag radials. those are the only ones that hold. when i went to firebird a few weeks ago the track was not holding anything. i hope it is better prepped this time. i talked with dave, the owner of yank, and he said i will not even notice the difference on partial throttle. with hp tuners i am doing a lock up at partial throttle at 20 mph in third so that helps alot. i was scared to with what people were telling me. my wife drove the 3600 stall and never even knew i had it in there. right now tracking is just stating a label has been created. so the odds are i will not be there. you will have fun. go.
"Silver Shadow"
Old 11-13-2012, 09:08 PM   #8
desertg8
I may have my car back on Friday. If so I will head on up to Chandler.
"Silver Shadow"
Old 11-18-2012, 11:03 AM   #9
STAGEUP
It was nice meeting some of you guys on Friday. The night wasn't too bad. D.A was at 2,400 ft, temp was 70 degrees. Ran my car three times, and hit the limiter on the 1-2 shift on every run. I guess I was a little aggressive. Haa. I feel it was good baseline for the first time taking her out to the track. Ive had very little seat time in her, so go easy on me. :-)
1st run: 13.3@107
2nd run: 13.1@108.5
3rd run: 13.1@107
Hopefully I can stay off the limiter next time out. :-)
Old 11-18-2012, 01:00 PM   #10
desertg8
i heard it was warm. my car was not ready. i will be out there in two weeks. considering your car is an M6 those are fantastic times! the best i have seen an automatic gxp do with a rotofab and some exhaust work was a 12.9 with a lower da. Good job!
"Silver Shadow"
Old 11-18-2012, 03:07 PM   #11
blkscooby
blkscooby's Avatar
Good runs.
Old 11-18-2012, 06:28 PM   #12
08G8GT6A
1st run: 13.3@107
2nd run: 13.1@108.5
3rd run: 13.1@107
You're doing good with that 13.1,,, I was only able to go 13.4 with the car granted it was not cool out when I did it. My wife ended up running her S4 around 10 PM but we got DQ'd because she went 13.6 with no helmet and me in the pass seat The S4 is a quick car but still not as fun as the GXP...
09 PBM GXP M6 roof onyx. Sold
08 IOM GT sport premium onyx # 869 of 888. Gone but not forgotten
96 Impala SS LS1 swap
08G8GT6A is offline   Reply With Quote
Old 11-18-2012, 08:40 PM   #13
Silverado777
It was a pretty good night. Would have been better if it was a little colder. Best I could get was a 13.5 with a butt load of wheel spin on the 1-2 shift. Plus I need to get it retuned for the 3.27 gears, seems like the car did not want to shift out of 3rd.
1/4 Mile - 10.3
Old 11-18-2012, 08:58 PM   #14
desertg8
common problem. if you have hp tuners go into your mph shift tables. on the third to fourth gear shift lower your mph by 2. do it in both columns. i bet that helps alot. if it sort of works lower it by 1 more mph. it is a tuning issue.
"Silver Shadow"
Old 11-18-2012, 10:14 PM   #15
Silverado777
Thanks for the tip! I haven't bought HP tuners yet. I probably will here pretty soon.
1/4 Mile - 10.3
Old 11-19-2012, 11:43 AM   #16
STAGEUP
Thanks, I was a bit disappointed in my times to be honest. I kept banging the rev limiter, and for some reason, the limiter was coming in at 6100 rpms, but on the street I take her up to 6600 with no problem. Weird. Anyway, it was an okay baseline. The car is strong, I just need more seat time I guess. I've only driven her a little over 300 miles since I bought her.
Old 11-19-2012, 01:35 PM   #17
jbak
jbak's Avatar
Looks like my prediction on AZDG was pretty accurate !
