New tires, now tire fault - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > Wheels / Tires
Wheels / Tires Sponsored by: Discount Tire
Old 11-13-2012, 07:12 PM   #1
RockyMtG8GT
Moderator
RockyMtG8GT's Avatar
Default New tires, now tire fault
Spent $1200 for a new set of tires at Discount Tires and ever since I have a tire fault and no pressure reading available on any tire in the DIC. I never had any issues before this and have brought the car back twice for them to fix but they don't know why and telling me ill have to buy two new sensors.
WTF?!!??
Anyone else have this issue? I'm not giving them another penny since I've been a loyal customer for years and it was working just fine before I gave them $1200 two weeks ago.
I'm thinking about complaining to manager and demanding they replace and fix the issue free of charge or I will take my tire business elsewhere from now on....
What should I do next?
2009 G8 GT
Kooks LT's 1 7/8", catted X pipe to GXP mufflers
Rotofab intake, Avant Garde staggered summer wheels
Pat G tuned
2003 Corvette coupe
6spd Manual, lowered on C6 wheels
Long tube headers, Corsa catback
Heads/cam, Hurricane intake
RockyMtG8GT is offline   Reply With Quote
Old 11-13-2012, 07:31 PM   #2
ColdFuzion
Drop by a dealership and ask them to scan the tires to get readings for the tpms, takes like 5 minutes. Discount tire "should" be able to do it, but they have had about a 50% success rate with tires I have bought there. I would not recommend doing the process yourself, its a pain in the ass.
2009 White Hot GXP
2009 Stryker Blue GT
ColdFuzion is offline   Reply With Quote
Old 11-13-2012, 08:11 PM   #3
richm52
Have you tried to reset the TPMS yourself? It takes less than 5 minutes.
2009 G8 GT Maverick Silver Metallic
Premium and Sport Packages
Holden Radiator Cover
GXP Front Fascia and Rear Diffuser
GXP Rear Sway Bar and Mufflers
V6 Tail Lights
Pedders XA Coilovers, Sub Frame Connectors and Radius Rod Bushings
DBA T-3 Slotted Rotors and Hawk Ceramic Pads
richm52 is offline   Reply With Quote
Old 11-13-2012, 08:47 PM   #4
RockyMtG8GT
Moderator
Yes, the left front tire beeps after a few seconds deflating but front right just keeps deflating and does not. Same happens when the tire guys use the handheld. Both passenger side wheels aren't working...
2009 G8 GT
Pat G tuned
2003 Corvette coupe
Old 11-13-2012, 09:07 PM   #5
wyome
wyome's Avatar
Do they have tpms on em??
09 G8 GT in Stryker Blue Metallic
Mods
Go: Vararam CAI, SLP Headers, ATI 25% UDP, Magnaflow 12468 mid-muffler, PM-FL Axleback & FE3 Shocks N Struts.
Tuned by MAC Autosports of Parker, Colorado
Show: Little Trees US Flag Vanilla Scented Air Freshener; SLP Firehawk wheels...
The Track
Best 1/4: 13.969 @ 102.70mph @ Pueblo Motorsports Park
DA of 3921', with an actual elevation of 4662'
Pueblo, Colorado
wyome is offline   Reply With Quote
Old 11-13-2012, 09:34 PM   #6
RockyMtG8GT
Moderator
Yes sir
2009 G8 GT
Pat G tuned
2003 Corvette coupe
Old 11-13-2012, 09:42 PM   #7
wreckwriter
9 Second G8
wreckwriter's Avatar
If a dealer can't beep them the monitors are shot.
2011-13 G8 King
wreckwriter is offline   Reply With Quote
Old 11-13-2012, 10:56 PM   #8
RockyMtG8GT
Moderator
Since they were working fine when I brought it in could it be they broke them?
2009 G8 GT
Pat G tuned
2003 Corvette coupe
Old 11-13-2012, 11:07 PM   #9
LiquidR3D
They wear out after a while. Probably just their time. Our 09 G6 has non working sensors, tires have 80,000miles. never been off the car. just stopped working. buy new ones.
N/A Best Passes
2.014 / 12.666@113.73 - DA +9' 4/19/14
Roto-Fab/LMS Tune/Drag Radials
2.025 / 12.768@110.94 - DA +2,357' 8/9/14
Roto-Fab/LMS Tune/MRT CatBack/Drag Radials
LiquidR3D is offline   Reply With Quote
Old 11-13-2012, 11:16 PM   #10
JimmyJazz
JimmyJazz's Avatar
When I rotate my tires I always have to let a ****load of air out of the RF,RR,and LR but the RF seems to need the most. It seems like about 8-10 psi before I get a honk.
'09 Pacific Slate G8 GT "stock" 1900 Magnacharger, 441 rwtq, 441 rwhp. Rotofab intake, Kooks 1 7/8" lt's,cats, midpipe, Solo axle back exhaust. Pedders lowered touring package. Baer Pro front brakes, Breyton GTS AV 19x8.5, Michelin Pilot Sport a/s tire's. '78 ElCamino. 2008 model Blue Heeler.
JimmyJazz is offline   Reply With Quote
Old 11-15-2012, 07:46 PM   #11
WhiteHotG8GT
I've heard that the TPMS are fragile and real easy to break.
2009 Pontiac G8 GT, White Hot, Premium, Sport. Tune is "Down Under" by Men At Work.
WhiteHotG8GT is offline   Reply With Quote
Old 11-15-2012, 08:05 PM   #12
wreckwriter
9 Second G8
They're not terribly fragile. They do, however, contain batteries which wear out. Run by any GM dealer, they won't charge you much to beep them. It takes about 3 minutes.
2011-13 G8 King
