Whipple 2.9 Supercharger for the G8 - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-14-2012, 10:19 PM   #1
Calais57
Calais57's Avatar
Default Whipple 2.9 Supercharger for the G8
There is a Whipple 2.9 available for G8/VE in Australia from YellaTerra. It has a front drive and rear air flow entry.
Has anyone seen the Camaro and Corvette version (front drive and front air flow) adapted/modified for the G8?
[color=gray]Sent from mobile App
Calais57 is offline   Reply With Quote
Old 11-14-2012, 10:53 PM   #2
TyG8GXP
TyG8GXP's Avatar
Haven't seen anyone do it.
I would have LOVED a Whipple, but I was worried about the amount of fabrication to get one to work, as the hood clearance issues you'd probably run into.
2009 M6 G8 GXP - Sold
710rwhp/742rwtq
TyG8GXP is offline   Reply With Quote
Old 11-15-2012, 12:10 AM   #3
thebeast
It's too tall for sure. A Maggie 2300 pulley already rubs the hood liner. With the height difference of the whipple, I'd say it won't work
2008 LR G8 GT
TSP Forged LS3-D1-221/232 RCR Cam-Ported L92's-Squash-Kooks-Solo 3in-BMR-SS wheels and brakes-Kicker-Demon 8 Designs Gauge Pod-BC Racing Coilovers- Custom Earls Tranny Cooler
613/543 old worn out numbers
11.6 at 123 1.92 60ft
New numbers coming soon..........
thebeast is offline   Reply With Quote
Old 11-15-2012, 12:30 PM   #4
jonbridge
I just bought a 2008 g8. It has 63k miles.
I'm a big German car driver, so American is new territory for me. I'm looking for mid 11s in the quarter. What's the most reliable way to do this?
Keep in mind this is my every day driver so it has to relatively easy on the motor.
jonbridge is offline   Reply With Quote
Old 11-15-2012, 01:45 PM   #5
Blanky
Blanky's Avatar
I wanted a whipple. Cam/dod delete Maggie should be easiest
2009 G8 GT
D1 Procharged
11.69@119
Redline
Blanky is offline   Reply With Quote
Old 11-16-2012, 02:00 AM   #6
Calais57
Calais57's Avatar
The Yella Terra guys Down Under have a rear feed version of the 2.9 and 3.4 Whipple that fit under the hood of a 6.0 litre VE /G8.
http://www.oztracktuning.com/news/
Anyone in the USA doing this?
Old 11-16-2012, 04:49 PM   #7
Nothin_But_Tail_Lights
Nothin_But_Tail_Lights's Avatar
I already have the maggie 2300, but would be very interested to see if this can be done and at what cost.
2008 Black G8 GT - R.I.P (Totaled May 2012)
New ERA OTR Intake, Kooks LT Headers, Koxks X-pipe & Axel Back, Tein suspension
2009 Red G8 GT - Daily driver
Maggie 2300 @ 9 psi with rear 1:1 cog drive, KB BAP, Livernois Stage 1 Cam Kit, 3 Bar Map, Milled Heads, Ported TB & Intake, Doug Thorley LT headers, Borla exhaust, Roto Fab CAI, Eibach lowering Springs, BMR Trailing Arms, BMR Toe Rods, GXP Front Fascia and Rear Diffuser, Tuned by Livernois Motorsports...
592rwhp & 544rwtq
Nothin_But_Tail_Lights is offline   Reply With Quote
Old 11-16-2012, 06:14 PM   #8
Calais57
Calais57's Avatar
I am told that a Whipple 2.9 kit with front air feed that is available for the Corvette will bolt straight on, but that you need to "drop the subframe" a bit. What does this mean? What subframe and how would you do this?
Old 11-16-2012, 10:31 PM   #9
I'm pretty sure the subframe is a separate frame to support the engine and or transmission. It either bolts up or is welded to the frame. I'm sure they mean to drop it so that it will lower the whole engine, providing room for the bigger 2.9 whipple. Well I shouldn't say I'm sure, more I'm guessing haha. But I have no idea how that would be accomplished if its welded without some serious fabrication. I don't even know how it'd be do e if its bolted for that matter. Someone with some more knowledge then me chime in
592rwhp & 544rwtq
Old 11-17-2012, 06:59 AM   #10
ksiu71
ksiu71's Avatar
Search is your friend.
http://www.g8board.com/forums/showth...hlight=whipple
SBM GXP -390/399 (CAI/Tune only)
Rotofab CAI, Kooks 1 7/8, HF Cats, Corsa Catback, Jeremy Formato tune
ksiu71 is offline   Reply With Quote
Old 11-17-2012, 08:05 AM   #11
Eric_GT
Eric_GT's Avatar
Maggie and cam.
Eric_GT is offline   Reply With Quote
Old 11-17-2012, 08:17 AM   #12
BigZub
BigZub's Avatar
Interesting. One thing the Yella Terra site says is that for them to make it fit, they used engine mounts from an LS1/2. No need to drop the subframe. If that's the case, then I would worry about header clearance....
The current front inlet units from Whipple for the Camaro and Corvette seem interesting as well...
'09 Pontiac G8 GXP, A6, Sunroof, MGM, #1664 of 1829
GMM RAMJET OTR CAI, Livernois E/TCM Tune, Kooks 1-7/8" LTs, catted mid-pipe, Hooker Polished SS MaxFlow mufflers - 394RWHP/386RWT
BMR Rear LCA's, stabilizer bars, end links, front LCA bushings, rear toe links and trailing arms, Pedders Street II kit, including subframe and diff bushings.
Hawk Ceramic pads, Brake Performance slotted and dimpled rotors, Russell stainless lines, Super Blue fluid.
Best 1/4 time - 12.52 @ 114.47, 1.94 60ft.
BigZub is offline   Reply With Quote
Old 11-17-2012, 12:20 PM   #13
iisme13
iisme13's Avatar
Yea because that would lower the motor quite a bit. I'm already low as it is and my headers scrap everything.
09 VE SS-V
Performance:
404ci Lunati Crank and Rods, Wiseco Pistons,TSP 235/239,Dallas performance LSA Heads, Yank 3600SS Stall
Appearance: SS-V conversion/ Brembo's/ XXR 522's/tein springs/ HSV gauges
Old Numbers 378hp/365tq
New numbers 501rwhp\467rwtq
iisme13 is offline   Reply With Quote
Old 11-17-2012, 02:28 PM   #14
Black_Ice
Black_Ice's Avatar
It wouldn't really make the sub frame closer to the ground , it would raise the body more .
Depending on the spring rates .
09 PBM M6 G8 GXP
08 Solstice M5 GXP
05 GTP CompG
88 Fiero Formula
81 Turbo Trans Am
76 Trans Am 455
Black_Ice is offline   Reply With Quote
Old 11-17-2012, 04:45 PM   #15
jonbridge
So basically livernois stage 1 cams. Axle back exhaust and a 2.9 whipple supercharger?
Old 11-17-2012, 11:49 PM   #16
Calais57
Calais57's Avatar
Originally Posted by ksiu71 View Post
Thanks ksiu71, saw that thread but it is more about KB's and didn't provide anything useful about options with whipples.
Does anyone have more info about how to lower the sub frame (and therefore the engine) in a G8? I don't think I would really do this - just curious. I imagine it would lower ground clearance of the exhaust/ cats, so not a great option I guess??
Old 11-19-2012, 04:49 AM   #17
Calais57
Calais57's Avatar
Picture posted on another forum of a Camaro Whipple installed in a VE in South Africa. The guy said he "dropped the subframe".
[/IMG]
Old 11-22-2012, 05:48 PM   #18
Calais57
Calais57's Avatar
I am told that the engine sits in a separate subframe that is secured to the body by 4 16mm bolts and that it can be lowered by adding some washers or other spacers. It does obviously lower the sump closer closer to the ground.
Old 11-22-2012, 06:46 PM   #19
1gr8ate
1gr8ate's Avatar
Just do the VE conversion with a cowl hood and you'd done or fab up a cowl hood!!
1gr8ate is offline   Reply With Quote
Old 11-22-2012, 07:47 PM   #20
MGM GT
MGM GT's Avatar
How tall is the Whipple? I fit a single plane and elbow which was taller then the Maggie under the stock hood, granted I removed the useless hood liner.
Just another 9 second family car...
Capital City G8 Club /// DriveShaftShop /// Powerhaus Performance
MGM GT is offline   Reply With Quote
