Potential Brake Upgrades Worth It? - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-16-2012, 08:46 AM   #1
SeeD65
Senior Member Mike
SeeD65's Avatar
Default Potential Brake Upgrades Worth It?
Good day!
I was thinking about upgrading my brakes to Brembos/CTS-Vs. But then I asked myself, why do I want Brembos? Why not just upgrade rotors and pads when the time comes and be done with it. Do I really need Brembos?
This is why I am posting this question so that you all can help me.
My G8 is my daily driver and my commute is rather short. However, I enjoy taking my vehicle out on weekends and go around the typical fun roads around the area. I do not plan on tracking my car. I have not pushed my brakes too hard knowing from past experience from my GTP that I can go through pads rather easily over a short time with aggressive driving. I just want to have a brake system that does not fade and provides good bite during and after fun road courses.
All that said, if I upgrade to Brembos I will also have to get rid of my stock 19" wheels since the Brembos do not fit. I planned on using my stock 19s with all seasons for my winter set-up and purchasing some Nuburgring TSWs for my summer set-up . Hence my other thread on what wheels clear Brembos.
Would it be worth upgrading to Brembos or just getting better rotors/pad combo? Are the Brembos THAT much better?
I know the ultimate decision is mine...I just want to real world knowledge and not bravado
Thanks!
2009 G8 GT - Premium and Sport Packages
Mods - Roto-Fab Intake, BMR Front and Rear Sway Bars, BMR RTAs, BMR Steering Rack Bushing, BMR Rear Cradle Bushing Inserts, and Cortex Tune. Summer set-up - 18x9.5 TSWs - Cooper 275/40/18 RS3-S, squared, LS3 Cam, Kooks Mids....and others.
SeeD65 is offline   Reply With Quote
Old 11-16-2012, 09:01 AM   #2
bostonf4$
I went w/ stainless steel lines for more pedal feel, DBA slotted rotors, and hawk ceramic pads plus flushed the fluid. This is a major difference over stock, and unless you're autocrossing the car more than you will need. The G8 GT even in stock form stop ridiculously well...like german super sedan well. 60-0 in as little as 109' has been documented, compare that to ANYTHING and you will be impressed. It is the fade and feel that is a problem w/ the stock setup, w/ the mods I listed that will help in those departments.
A larger caliper w/ more pistons will always be "better" but not necessarily needed nor will it yield better "panic stop" results in the real world.
Old 11-16-2012, 09:17 AM   #3
whatnext
My GT brakes are currently stock, like you and am in a similar thought process but not considering Brembos.
I am going to stick with stock type rotors and hear the Carbotech 1521 pads are pretty fade resistant for a street pad. They even held up for some limited track duty. I did debate the ~$350 cost vs ~$250 for Hawk Ceramics but someone who ran the Hawk Ceramics did say that they do fade with spirited driving and preferred the Carbotechs.
So given that limited track duty and spirited driving really upper bounds what I will do with my GT, I will go with Carbotech 1521s on my stock rotors. Then if the stock rotors go to hell, then evaluate better rotors.
whatnext is offline   Reply With Quote
Old 11-16-2012, 09:19 AM   #4
dandragonrage
Plastidip is awful
I went to EBC USR rotors and Redstuff pads. I'm liking them a lot, but they're dusty. Then again, most good brake pads are. Hawk are too, and I'm not a fan of Hawk. I like Akebono brake pads but those aren't available for the GT. They are for the Brembos.
I previously had ****ed up both OEM pads and Bendix pads pretty quickly. These RedStuff have been handling heat a lot better so far.
I was actually really, really intent on upgrading to Brembo calipers myself, but I didn't because I have three sets of wheels for the car and not a single set would fit with the Brembos. But so far I am glad I didn't do that. The EBC setup is working well.
Going to be trading in my G8 in January or February, 2013. It's been a good run. Thanks all. See you in the for-sale section soon as I pawn off some parts...
Car audio sale - now | Wheels & parts sale - soon
dandragonrage is offline   Reply With Quote
Old 11-16-2012, 09:22 AM   #5
Silver Bullet
Super Moderator
Silver Bullet's Avatar
For the average person (myself included) the upgraded stockers would most likely perform well enough. Its the different look that makes me want to go with some brembos instead. I hate the look of the stock brake calipers on our cars.
-2009.5 MSM Premium GT-
Mods: Brembos, OBX Headers to Maxflows, VCM, RCR Intake, HSRK, LS7 Maf and tuned by Pat G.
In The Garage: Yank 2800 stall, SLP UDP, Pedders Coilovers
10.59 at 100.31 in the 1000.....8.33 at 88.13 in the 1/8....1.99 60 ft
Silver Bullet is offline   Reply With Quote
Old 11-16-2012, 09:40 AM   #6
romeyjdogg
Not a brake expert, but the stock system is pretty darned good. Then again, those Brembos do look really sweet, but the price is ridiculous
2009 G8 GT
35W HID, LED fogs, custom front/rear Pontiac symbol badges, sharkfin, BlueStar Bluetooth, GXP front end, GXP diffuser, x-pipe, straight through mufflers with helmholtz chambers, RotoFab intake , Eibach springs, FE3 shocks/struts, BMR rear subframe inserts
romeyjdogg is offline   Reply With Quote
Old 11-16-2012, 11:38 AM   #7
SRG963
Its Good To Be Tha King
SRG963's Avatar
2007 CTS-V front brembo calipers/2010-present Camaro front rotors with Bendix CQ pads and SS lines all around work well IMO. Complete brake overhaul for around a grand (rear retains stock calipers).
You can always add a 5mm spacer on the front wheels for winter time
Trigger - Fully Loaded 2008 Stealth Blue Pontiac G8 GT
Rotofab/Cortex/BMR/Pedders/VMR/
Adams/OBX/Nitto
PRAISE THE LOWERED
SRG963 is offline   Reply With Quote
Old 11-16-2012, 12:08 PM   #8
Eric_GT
Eric_GT's Avatar
Paint them black and you'll never even notice them.
Eric_GT is offline   Reply With Quote
Old 11-16-2012, 12:25 PM   #9
romeyjdogg
That's on my list to do. Just hate getting the car up on jack stands.
2009 G8 GT
Old 11-16-2012, 04:04 PM   #10
SeeD65
Senior Member Mike
SeeD65's Avatar
Hmmm! So a 5mm spacer will allow me to use Brembos on my stock front 19s, and the rears will clear without any spacers?
If this is true, then that sounds simple ansd make my decision easier. But...Is it really THAT simple?
Old 11-16-2012, 04:34 PM   #11
PhillyG8
I was gonna go with upgraded GT pads, and rotors but I got a set of front 2010 ss calipers, pads, and rotors for 350$ so I jumped on the deal. Already had replica camaro 20's on there so I figured it was worth my while for the price. I just have to get em coated and figure out what knuckle needs to be drilled and mount em. Also Im wondering if I should go with stainless brake lines or just use the lines that came with em.
PhillyG8 is offline   Reply With Quote
Old 11-16-2012, 10:43 PM   #12
DougHG8
Stock brakes have been fine for me; I'm at 97k miles with 7 hard road course track events behind me using track pads, still have the stock original rotors except for one I screwed up. They have some surface cracks from the high heat from the HPDE's but no functional issue. With very high horsepower and the abuse I've put into these brakes, I don't think you need Brembo's, want Brembo's, then go for it!
2009 Hot White G8 GT, CTS-V v1 fronts, Camaro 20's, BMR Sways, Eibach Springs, Rear Cradle bushings. GXP FE3's, BMR rear susp. Kooks 1 7/8 LT headers, RCR custom 3 exhaust, ported LSA blower, 2.38 pulley; Ported heads and TB; LS7 MAF, Racetec pistons, Scat rods, CTS-V crank; FAST 85 injectors; RCR Lunati cam: 223/238 .615/.601, 116 +2 LSA. CTS-V pump/VaporWorx cntlr. Built trans, Methanol injection. Rick Crawford built and tuned. Best 1/4 9.90 @140, 1.45 60'.
DougHG8 is offline   Reply With Quote
Old 11-16-2012, 11:14 PM   #13
whatnext
Thanks, this validates my plan to stay with stock rotors and get Carbotech street pads.
Old 11-17-2012, 12:38 AM   #14
MFE
MFE's Avatar
I love Carbotechs and I've been run several of their compounds on my hybrid street/track '92 Mustang for over a decade. I've found every compound I've used, from 1521's to XP10's, to be extremely rotor-friendly for every level of performance they bring to the table. The tradeoff is they make a corresponding level of dust, but it's generally easy to remove, it's not partially made up of rotor material like the dust from Hawk's traditional compounds seem to produce, and it's a tradeoff I'm happy to make IF I need the performance.
Here's the catch: As good as the 1521's are, you may hit their limits sooner than you think at a road course track day with a car this heavy. Meanwhile they'll be making rather expensive dust while you use them on the street. I would really consider leaving stock-like pads on for the street, assuming you're not reaching their limits within street usage, and then swap out to a heavier-duty pad for track days.
MFE is offline   Reply With Quote
Old 11-17-2012, 07:00 AM   #15
whatnext
Great input on Carbotechs! Not planning any track time with 1521s. My motivation for 1521s is that a route I take frequently has a ton of deer and if I can spot them I need to scrub speed off really fast and the stock pads don't have any initial bite.
So based on that and another goal to avoid fade for spirited driving, are 1521s recommended? Hawk ceramics are next on my list.
I don't put a lot of miles on the G8 only 17k miles now, so I'm not concerned about eating expensive pads up in daily driving.
Old 11-17-2012, 02:42 PM   #16
MFE
MFE's Avatar
Give the 1521's a shot, I think you'll like 'em.
Old 11-17-2012, 03:45 PM   #17
MnIrishJr
MnIrishJr's Avatar
MFE lol I knowww youuuu.
2009.1 G8 GT Hot White - SOLD!
2011 5.0 Brembo 3:73's
1989 Foxbody - 331 Stroker Complete Restoration
MnIrishJr is offline   Reply With Quote
Old 11-17-2012, 10:52 PM   #18
I12XLR8
Proud OGOC member!
I12XLR8's Avatar
Brembo's should be considered a 'look' mod for your situation. So would any rotor other than stock. Pads, fluid, and MAYBE lines are all that you need to do what you want, and can handle much more.
...and yes, a 5mm spacer will allow the stock 19's to fit over Brembo's as they allow my stock 18's to fit although it is DAMN close. New studs and a 10mm spacer and your set.
"I have dreamed a dream, and now that dream has gone from me" - Morpheus of the Nebuchadnezzar, and Grant of I12XLR8.
'Luskville is a cool experience, Calabogie is incredible, Mosport is life altering'
I12XLR8 is offline   Reply With Quote
Old 11-18-2012, 06:09 AM   #19
SeeD65
Senior Member Mike
SeeD65's Avatar
Thanks for confirming that the stock 19" wheels only need a 5mm spacer. Is the spacer only needed for the fronts?
Also, does this mean that they do not require new studs like the 18"rs require?
So based upon all this good information, here is what I will do:
  • I will keep my 19" stock wheels since I will be able to adapt the fit for Brembos....IF.... I decide to go that route. Knowing about the 5mm spacers gives me more freedom of choice when the time comes to switch out.
  • There are many non Brembo options that will fit my needs and we shall see how much money I have at that time. It looks like the DBA4000 rotors and Carbotech 1521 pads may be a good route.
  • I will sell my stock 18"rs that I was going to use as my winter set-up since I will be using my stock 19"rs for that purpose and start saving for the TSWs!
Many thanks for all the good information!
Old 11-18-2012, 01:10 PM   #20
I12XLR8
Proud OGOC member!
I12XLR8's Avatar
I can only 100% confirm the 18's but believe the 19's would be the same. You only need the spacer on the axle with Brembo's.
18's don't need studs with the 5mm spacer but if you get longer studs and a 10mm spacer you will never have any issues. I had some rubbing on a track day when throwing the car into a tight corner so bought 3/4" studded spacers to avoid this issue and still keep my stock studs for my Camaro 20's.
