spark plug gap for tr6 - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-17-2012, 02:12 PM   #1
Dark98z
Default spark plug gap for tr6
hi, i am going to change my plugs on my g8, i only have vararam intake and long tube headers. i am going to try some tr6 cuz off all the heat from the headers, what would be a good gap to start with? thanks.
Dark98z is offline   Reply With Quote
Old 11-17-2012, 02:51 PM   #2
Enginerd
Enginerd's Avatar
Fwiw - running headers has no real effect on combustion temps...ie, unless you're switching aspiration types or fiddling w/boost levels a spark plug temp range change isn't really necessary...but you'll be safe w/a 1mm gap, ~40 thousandths.
---------------GXP M6 #595/1829---------------
Enginerd is offline   Reply With Quote
Old 11-17-2012, 03:14 PM   #3
Dark98z
koo thanks, i had the plugs lying around for a while so i thought just put them to use.
Old 11-17-2012, 10:37 PM   #4
todds87ss
Car RamRod
todds87ss's Avatar
I also run tr6p plugs.
and i agree, gapped at .040
You can choose to be anything you want on the internet...why choose to be so stupid!
todds87ss is offline   Reply With Quote
Old 11-18-2012, 03:18 AM   #5
Dark98z
there already in, gaped them at .040
Old 11-18-2012, 02:01 PM   #6
The Yeti
'Mod'erator
The Yeti's Avatar
.040 for me
Pat G Tune & DOD cam, RCR Intake & TB, 4IN MAF
Ported stock Heads, 2600 Stall, VCM, OBX, UDP
H&Rs, Konis, BMR, Brembos, Slotted/Drilled Rotors
3.27 Gears, ZL1 pump, LSA awaiting install
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.2 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
second gear pull
The Yeti is offline   Reply With Quote
Old 11-18-2012, 04:54 PM   #7
Dark98z
hey yeti i think a saw your g8 at the car meet @ fremont they had on june nice looking g8 btw i was looking for a hot white before i got mine.
Old 11-18-2012, 10:07 PM   #8
The Yeti
'Mod'erator
The Yeti's Avatar
I was out at one event in Fremont. I rolled in with the Maro Boyz that night. There was two other white G8's out there but they were pretty stockish, and probably not as fast
After Stall
Zex 125shot
second gear pull
Old 11-19-2012, 01:41 AM   #9
Dark98z
yeah one was a gt and the other was a gxp, that was the first gxp i ever seen in person lol.
