Code PO 496 (Evap system) - Pontiac G8 Forum: G8 Forums - G8Board.com
Go Back   Pontiac G8 Forum: G8 Forums - G8Board.com > G8 Tech > V6 Engine Tech (LY7)
Old 11-17-2012, 04:00 PM   #1
Bennie77
Default Code PO 496 (Evap system)
Been getting this code a few times lately. Evap flow during a non purge condition. Any help would be appreciated.
Bennie77 is offline   Reply With Quote
Old 11-17-2012, 04:16 PM   #2
Agose25
Agose25's Avatar
Check your gas cap. Untighten it and then tighten it back hearing the clicks several times. With the weather changing from warm to cold this is usually when gas caps get loose.
If your code doesnt go away check back in here...
Old 11-17-2012, 04:52 PM   #3
Bennie77
Will do. Thanks.
Old 11-17-2012, 09:14 PM   #4
Bennie77
Well, I removed the neg battery cable to clear the code, tightened gas cap but the check engine light came on again.
Old 11-17-2012, 10:32 PM   #5
todds87ss
Car RamRod
todds87ss's Avatar
purge valve stuck open?
Disconnect it and blow through it. you should not be able to.
You can also connect a 12vdc source to it and verify it opens.
You can choose to be anything you want on the internet...why choose to be so stupid!
todds87ss is offline   Reply With Quote
Old 11-17-2012, 10:32 PM   #6
GOPHERIT
My read is saying, that the EVAP system is seeing a higher vacuum in the system, than it should. If the purge solenoid valve does not shutoff correctly, the intake manifold will keep adding vacuum to the fuel tank to the point that it exceeds the desired level, an will trip that fault code.
That purge solenoid valve sounds like its starting to fail. Its located just forward of the oil fill spout. If everything looks good from the outside (electrical connection and plumbing etc), maybe you could rap on it a little, to see if might temporarily correct itself. If so, you would then know what to buy, unless this is still covered by GM.
Old 11-19-2012, 06:14 PM   #7
Bennie77
I am not sure what I am looking for. Does someone have a diagram showing the part?
Thanks
Old 11-19-2012, 06:34 PM   #8
GOPHERIT
^^^^ I don't, but you couldn't ask for an easier part to get to and see. Remove your engine cover (if its still on), lift up the 2 heater hoses just a touch, where they pass by the front of the passenger side valve cover. There you will see a black plastic module about 2x2 in size. A vac line in and out, plus an elect connector attached to it. That *is* the purge valve.
Old 11-19-2012, 08:10 PM   #9
Bennie77
I appreciate all the help, but at the risk of sounding stupid, I am confused. One says in front of oil fill on drivers side, the other in front of valve cover on Passenger side. I am stumped.
Old 11-19-2012, 08:49 PM   #10
GOPHERIT
^^^ Well I checked my post #6, to see if I goofed, but it only says *oil spout*. I don't know where the *drivers side info is coming from.
Added info---- I'm talking about this under the assumption that your car is indeed a V8. The fault, and cause is the same for a V6, but the valve is in a different location.
Old 11-19-2012, 10:58 PM   #11
todds87ss
Car RamRod
todds87ss's Avatar
Bennie, do a google image search for purge solenoid or purge valve on the G8. you will see what it should look like. It is an easy check.
Old 11-20-2012, 01:18 AM   #12
JESUSFREAK702
JESUSFREAK702's Avatar
Make sure there are no cracks in the gas cap. The evap code is almost always the cap. Its an emission code so the battery disconnect doesn't always work.
Mods
Tuned by Frank @ Revolution Raceworks
Rotofab CAI
Pacesetter LTH 1 3/4
cat delete
Pypes Violators w/magnaflow x pipe
Staggered 20" STR101
245/35R20 and 275/30R20 Delinte D7
D2 Coilovers
5% tint
JESUSFREAK702 is offline   Reply With Quote
Old 11-20-2012, 02:54 AM   #13
Bennie77
No. I have a V6! Oil spout is on drivers side. I am in V6 tech forum, correct?
Old 11-20-2012, 11:13 AM   #14
GOPHERIT
Bennie77, you are in the correct posting location. I have a habit of reading the thread, without verifying what section it is located in (my bad). If I read the diagrams correctly, the purge valve is located just above a couple of the spark plug coils, on the passenger side. It looks to be a cylindrical shape with a vac line at each end of it.
Old 11-21-2012, 01:48 AM   #15
todds87ss
Car RamRod
todds87ss's Avatar
p0455 is the cap code.
Old 11-21-2012, 03:42 AM   #16
JESUSFREAK702
I humbly stand corrected.
http://www.obd-codes.com/p0496
Mods
Rotofab CAI
cat delete
D2 Coilovers
5% tint
Old 11-21-2012, 07:54 AM   #17
HotRodG8
HotRodG8's Avatar
Replace the EVAP purge solenoid. P0496 is EVAP purge during non-flow operation, which means the system is seeing vaccum while the system is being commanded sealed. this is caused by a purge solenoid being stuck open. part is $50 and is located on the pass side close to the intake manifold near the cowl... p0455 is EVAP large leak usually a cap left completely off or a EVAP vent valve stuck open.. P0442 is a EVAP small leak, usually a gas cap.... hope this helps
Owner @ MJD Performance "If you can dream it, we can build it"
2009 PBM G8 GT
Premium, Sport, Sunroof
LS3 Swapped
Lingenfelter Ported Heads
MJD Performance Custom Cam
RotoFab CAI
American Racing headers w/ GXP mufflers
PATC Custom 3400 Stall
Built 6L80e with 6L90e internals
FE3 Suspension
CTSV Coupe Wheels with Michelin PS2 rubber
473hp/459tq NA
--All New Setup in the work's for 2015 !!--
HotRodG8 is offline   Reply With Quote
Old 11-21-2012, 08:15 AM   #18
Bennie77
Well, I did check the gas cap previously. It looked fine. Anyway, got gas last night, and after filling up, the cel is no longer coming on. Coincidence? Maybe. I will keep an eye on it, and if the code returns, will look into the evap purge valve. Thank you all for your help!
Old 12-06-2012, 09:19 AM   #19
Bennie77
Well, the cel has come on intermittantly so I got a new purge valve. Now, any tips on getting the connectors off? Don't want to break anything. I was able to disconnect the electrical connector, but not sure how the others come off.
Thanks
Old 12-06-2012, 12:53 PM   #20
GOPHERIT
Wouldn't you know, they can't make it easy. They show you need a removal tool (the tool in the GM service manual is P/N EN-46843) It looks like a device that would slip around the pipe coming out of the valve an under the hose locking collar attached to it. It probably probably forces a locking ring outboard, so you could then pull the hose away from the valve over the raised retaining lip on the pipe. There might be an after market vendor that sells a tool, that will do what is needed here, say from an auto parts store. Might be a tough find. If a lot of GM cars use this same type of disconnect technique, maybe finding a tool won't be that hard.
