ASE-TURBO kit - Pontiac G8 Forum: G8 Forums - G8Board.com
Old 11-17-2012, 06:33 PM   #1
iisme13
iisme13's Avatar
Default ASE-TURBO kit
Ok guys. I have done a lot of research and tons of emails to the guys at ASE about their turbo kit for the VE Commodore. Next year I will be jumping on this kit. Kit is the gt1000 (gt-51) kit
Garrett GT4502R turbo
Tial 44mm Wastegate
600x300x75 core size, intercooler
3 inch intercooler piping and silicone joiners with hoseclamps
Oil drain kit including turbo feed lines
Water feed kit
Custom made washer and coolant overflow reservoir
K&N pod air filter
HPC coating
I plan on doing a engine build to support this kit as well as fuel and tranny. I was told by them with a fully built motor and 20+ lbs of boost I could be looking at 850-900hp. My plan is to dd this car at 10lbs and make 500-600 street and on race tune, e85 and 20lbs 800hp.
What are your thoughts on this? And would any of y'all be interested in this kit if I did become the ginniepig on this?
09 VE SS-V
Performance:
404ci Lunati Crank and Rods, Wiseco Pistons,TSP 235/239,Dallas performance LSA Heads, Yank 3600SS Stall
Appearance: SS-V conversion/ Brembo's/ XXR 522's/tein springs/ HSV gauges
Old Numbers 378hp/365tq
New numbers 501rwhp\467rwtq
iisme13 is offline   Reply With Quote
Old 11-17-2012, 06:37 PM   #2
Scorpious
G8 fiend
Scorpious's Avatar
single turbo not twin? im kinda thinkin u wont get those numbers with a single turbo set up
<a href=http://s98.photobucket.com/user/repozone/media/DSCN0298.jpg.html target=_blank><img src=http://i98.photobucket.com/albums/l259/repozone/DSCN0298.jpg border=0 alt= /></a>
Scorpious is offline   Reply With Quote
Old 11-17-2012, 06:51 PM   #3
iisme13
iisme13's Avatar
That's what I thought. But they have told be because of the size of the turbo and how's it's fed. It spools up very quick and the power is very good.
09 VE SS-V
Performance:
Old 11-17-2012, 08:03 PM   #4
Scorpious
G8 fiend
Scorpious's Avatar
i guess they kinda like the house of boost turbos (no turbo lag) but its really starts low rpms. well the one u wanna talk to is Daniel Linnett bout his set up he had upgraded everything on his set up but he had twins and ran 10s
but im guessing ur gonna swap out the pulleys for race time and dally driver days running 20lbs constantly not always a good thing also if u run twin u can run the turbso on lower psi
Old 11-17-2012, 08:04 PM   #5
Daniel Linnett
Daniel Linnett's Avatar
Single will be fine. Spool will also be good with it up front. Should be alot of fun.
Sent from my iPhone using AutoGuide.com Free App
427 LSX Block, custom diamond nitrous pistons, Ultra Billet rods, Lunati Crank, Jessel Rockers, Solid Rollers, All Pro cathedral Heads, Mast 4500 Cathedral Intake, 6061 Elbow, Nitrous Outlet Stinger plate and much more!
Hunting 8s
Sponsors: East Texas Muscle Cars; Henson Racing Engines; FTI Converters and Transmissions; Comp Cams; Mast Motorsports; BMR Suspension; Nitrous Outlet; 6061.com
Daniel Linnett is offline   Reply With Quote
Old 11-17-2012, 08:13 PM   #6
Scorpious
G8 fiend
Scorpious's Avatar
[QUOTE=Daniel Linnett;961165]Single will be fine. Spool will also be good with it up front. Should be alot of fun.
/QUOTE]
single to get the numbers hes looking for seems like a lil bit of a stretch...no?
Old 11-17-2012, 08:20 PM   #7
Crazy_8
Crazy_8's Avatar
I am assuming the built motor part is the part that makes the possible.
Keep us updated Vic.
2009.5 Liquid Red G8 GXP A6
For mods list, honk 3 times.
Crazy_8 is offline   Reply With Quote
Old 11-17-2012, 09:02 PM   #8
iisme13
iisme13's Avatar
Yes. I'm planning for 416ls3 or doing a 402ls2. I'm not sure just yet I know with a stroker motor my upper rpm will be limited. But I plan to have heads fully ported. Nice turbo cam. And big exhaust. And also be running e85 So that should help a lot.
09 VE SS-V
Performance:
Old 11-17-2012, 10:29 PM   #9
Blanky
Blanky's Avatar
Must be a nice motor on 20psi streetcar. Rear/trans will be fun might wanna swap to 4l60. Single turbo will be fine it might just take a sec to spool
2009 G8 GT
D1 Procharged
11.69@119
Redline
Blanky is offline   Reply With Quote
Old 11-17-2012, 10:38 PM   #10
TyG8GXP
TyG8GXP's Avatar
Unless your compression is low, you'll make more than 500-600 on 10 pounds.
2009 M6 G8 GXP - Sold
710rwhp/742rwtq
TyG8GXP is offline   Reply With Quote
Old 11-17-2012, 10:45 PM   #11
iisme13
iisme13's Avatar
Yea I'm planning on doing a very low compression motor. Ad trans. Idk yet. Maybe a zl1 6l90 or th400.
09 VE SS-V
Performance:
Old 11-17-2012, 11:37 PM   #12
SpeedRacerX
Now it's a Party
SpeedRacerX's Avatar
Did they say how much this kit costs?
2009 GT, Kooks 1-7/8 Mids, RPM Tune, Borla, Vararam, HSRK, P&P TB, UPR CCan, Mobil 1, Speedhut Gauges, FE3, Whiteline, Pedders, Summer MRR on 255/295, Winter Beyern on 245, CTS-V Fr Brembos, SS Rotors, Akebono Pads, Rolled/Pulled Fndrs, BMR Sways, Spohn Links & Arms, Sprt Pedals, Pont Shifter, Camaro Trans Pan, Pont Mats, Glove Box Light, MSM Lower Grills, CF Tail, GXP Diff, VG Fin, 20% Tint, 6000K HIDs, LED Fogs, GrafxWerks, Black Trim/Mirrors/Grills, Diffusr Lens/Amber Lens/Lowr Tails Tint
SpeedRacerX is offline   Reply With Quote
Old 11-17-2012, 11:41 PM   #13
iisme13
iisme13's Avatar
I can't discuss price right because we are in the process of getting a price. I'm trying to get them to make this kit Available to us here in the states. But once I get pricing I will post it.
09 VE SS-V
Performance:
Old 11-19-2012, 03:38 AM   #14
MH.
MH.'s Avatar
will be interesting to see the kit fitted and produce some nice numbers. Good luck.
CSV CR8, 462rwhp 424rwtq
MH. is offline   Reply With Quote
Old 11-19-2012, 10:10 AM   #15
drewdog
drewdog's Avatar
this bad boy ?
http://www.aseturbo.com/HOLDEN-COMMO...E/prod_91.html
'08 PBM GT
Roto-Fab CAI, SLP Headers, GXP Catback, Tuned
Pedders Street I, FE3 Struts
Tints, Sharkfin antenna, passenger seat mod
drewdog is offline   Reply With Quote
Old 11-19-2012, 10:17 AM   #16
Nothin_But_Tail_Lights
Nothin_But_Tail_Lights's Avatar
If you're wanting it for a dd, why not just go Maggie 2300 with a rear cog drive. That what I did on stock engine (other than livernois stage 1 cam kit) stock driveline and rear end and put down right at 592 rwhp. Plus it's real fun to drive because I'm already over 500 ft lbs tq at 2200 rpm. Just my 2 cents.
2008 Black G8 GT - R.I.P (Totaled May 2012)
New ERA OTR Intake, Kooks LT Headers, Koxks X-pipe & Axel Back, Tein suspension
2009 Red G8 GT - Daily driver
Maggie 2300 @ 9 psi with rear 1:1 cog drive, KB BAP, Livernois Stage 1 Cam Kit, 3 Bar Map, Milled Heads, Ported TB & Intake, Doug Thorley LT headers, Borla exhaust, Roto Fab CAI, Eibach lowering Springs, BMR Trailing Arms, BMR Toe Rods, GXP Front Fascia and Rear Diffuser, Tuned by Livernois Motorsports...
592rwhp & 544rwtq
Nothin_But_Tail_Lights is offline   Reply With Quote
Old 11-19-2012, 01:55 PM   #17
iisme13
iisme13's Avatar
Drew dog. Yes that's the kit. And I don't wanna go with a supercharger. That will not single me out in a crowd. Everyone is doing Maggie or procharger. Why not change it up and do a turbo setup. There are twin set ups roaming around here but you don't see a single. There is maybe 2-3 people that I know of that have done a single turbo kit. I'm not a follower. I'm a LEADER!!!!!!!lol
09 VE SS-V
Performance:
Old 11-19-2012, 02:05 PM   #18
adamsar
adamsar's Avatar
Turbo is the way to go, that GT4502 is a beast! I like being the only one in my area, but I like my turbos down low for some weird reason.
2009 G8 GT Twin Turbo
Forged LS3, 6465 turbos, Tial 38mm waste gates, Tial 50mm blow off valve, full dual 3 stainless exhaust, Eboost2, FMIC, CircleD 6l80e, CircleD 3200 stall converter, Triple staged 392 Walbro pumps, Fuel lab regulator, Aeromotive rails, FIC 127lb injectors, 3.27 rear with Wavetrac diff, Gforce 750hp axles, BMR full bushings kit.
adamsar is offline   Reply With Quote
Old 11-19-2012, 03:15 PM   #19
Lol, I can understand that, but I would like to think i'm a tiny bit unique. Most of the GT's have the 1900 while the GXP's have the 2300. Also, not many went with the cog drive, so a 2300 with rear cog drive is a least a smidge unique haha. But I know what you mean, a single turbo is indeed very rare in our cars.
592rwhp & 544rwtq
Old 11-19-2012, 06:43 PM   #20
SpeedRacerX
Now it's a Party
Nice setup. I believe Vegasnate is the same: GT, 2300, rear cog drive, CAM. I believe that's what I saw, heard and drove-in when I saw the car in person in Vegas. LOL.
I'll take any FI but a turbo would be unique.
